follow me on twitter! http://www.twitter.com/rohanlikhite
Visit my site => http://rohanlikhite.com
Remove these ads by
Signing UpStep 1Gather Required Materials
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
Thanks in advance :}
You just saved me a trip to Radio Shack, buying a cable splitter, and moving my cable modem and router. This gave the router the boost it needed to compensate for my new camera's body being beefier than the old one, interfering with the Eye-Fi card.
Maybe it ain't pretty, but it's off in the den. The other choice was putting the cable modem and router in the living room, which would be even uglier. So, yeah, it's beautiful. :)
Downloaded the PDF from urbanwireless.info, printed them out to scale & did the contact adhesive bit onto card (180gsm - metric (grams per square metre) - Rather thick card). Stuck the whole thing together (two of them) with the aid of hot melt glue ( the glue version of duct tape but not as strong but just as handy)...This all took about 15 minutes. As a professional RF engineer I hate to say it....It worked AND it worked bl**dy well. Too simple. I recommend this technique to everyone mucking around this stuff...Okay, it's not as good as the correct antennas but, hell, it can get you out of a tight spot without costing the usual arm & a leg until you can get back to the job with the pro' antennas. Thanks for posting this. Very, very useful. And many thanks to sn00ze for the link to urbanwireless.info.
gives you everything you need to know.
Electrical length, SWR, all of it.
http://www.freeantennas.com/projects/Ez-10/
http://img225.imageshack.us/img225/4282/antenna.png
Another it works comment. I made it out of Vinyl folder material, put it on the netgear router, and ba-bing, my signal strength was up. I was considering running cat5 before I tried this out...
On the transmission, it catches nearly half of the signal that's shooting out in all directions, and points it toward one direction. It's like the reflector behind an automobile headlight.
i also found my connection speed improved slightly.
well worth doing
stu
