3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a Wide Sturdy Handle With The Portuguese Sinnet
Messenger bags are great but sometimes the long shoulder strap gets tangled when you're trying to make a quick exit or easy entrance. Since they all seem to have a couple of 'D' rings on the back, I decided to make a quick short strap that won't get hung up on stuff as I drag it out of the car to avoid the coming zombie apocalypse.  But the problem is that if it's too narrow, it's too uncomfortable to use zombies or no. So, enter the Portuguese Sinnet (also known as Solomon Bar and referenced as knot #2496 in Ashley's Book of Knots).
Step 1The Setup:
The Setup:
Here's the front and back of my messenger bag. The distance between the middle of the 'D' rings is about 6.5 inches (16.5cm for those metricly inclined). I started with a length of #550 paracord 82 inches long (2.08m). I also had the following:
x. lighter
x. scissors
x. 2 12.5 inch (35cm) pieces of thin (2 mm) cord
47 comments
1-40 of 47next »
Aug 10, 2011. 12:15 AMSouban Tahir says:
nice Its too Easy. . .
May 4, 2011. 1:59 PMMorpheus says:
Is there a formula for determining how much cord to use for a specific span between the anchors when making a Portuguese Sinnet?
May 17, 2011. 8:27 PMkona334me says:
For every inch to be stitched figure about a foot of cord. So for a 8inch handle 8 feet would be needed. Hope this helps.
Nov 10, 2010. 8:41 PMbuellboy492 says:
Great instructable. You have inspired a project for me. Maybe I will take pics and make another 'able!
Sep 3, 2010. 8:14 PMjimmiek says:
Hmmmmm, I have been wondering for several years how I'm going to fix the broken handle on my Autoharp case ..... this looks like the answer! THX
Aug 30, 2010. 4:36 PMbennelson says:
Here's my shot at it. I have been wanting a strap for my coffee mug for a while with nothing metal touching the cup. I already had a carbiner and the paracord around anyways. Still need to tidy the ends of the cord though.
Aug 29, 2010. 7:49 PMRaNDoMLeiGH says:
I have had an Israeli paratrooper bag for uh.. oh god, 25 years. (feels old..) I got it in high school, carried through 10 years of grad school, and used it to drag my laptop all over the world. Then the frickin' *strap* wore out, dag-nabbit! But I didn't want to throw out my bag. It went too many places with me to just be trashed. So it's in the bottom of my "tote bag tote" in the hall closet. I was going to fix the strap with some webbing like they use for belts, but that stuff is hard to sew and tends to unravel. WTF is WRONG with me, I make macrame and chinese knotted jewellery, and I have a ton of paracord in my studio. Duh duh duh... I love you, man. I really do. That was my favorite bag evAr. Now I can use it again. *SMOOCH*
Aug 26, 2010. 9:01 AMawilliamsid says:
Hemostats are a nice alternative to this method!
Aug 26, 2010. 8:47 PMawilliamsid says:
Ahh. Well I weave the 'stats into the knot much like you do your pieces you pull through. Then I tighten with a pair of rounded pliers: http://www.beadandbuttonbazaar.com/images/round-nose%20pliers.jpg
Aug 3, 2010. 8:09 PMmysss says:
nice! Is your method of finishing holding up well? It looks great.
Jun 25, 2010. 6:59 PMdent244 says:
Its also called a cobra weave.
Jun 23, 2010. 7:08 AMCalliopeya says:
Portuguese? i'm from portugal and see nothing portuguese about this, just for the info, this is an art called macramé, meaning "the art to make nots" and it was invented by arabian people not by us portuguese ppl, we learnt it from them, ok it's used a lot by us, by the navy and the airbourne forces, and portuguese women to make wristbands and stuff like that. i just wanted to add the info. BTW i love the airbourne pouch, if it would be green it would be perfect
Jun 23, 2010. 2:25 PMCalliopeya says:
So, still i guess i've instructed you in some way, at least now you know how it is called. Thank God i'm not turkish cause i haven't met any good turk and i've spoke to some (not that the other humane races are any better). And it would be perfect if it would be green for me because my country is mainly green, at least I wouldn't die here with a green pouch.
Feb 12, 2010. 8:36 AMGrumpyOldGoat says:
I'm IMPRESSED!
Maybe if you laid the 'pull back' lines with the first knot as suggested below, then measured and cut the lines and burned the ends prior to pulling them back through it would give you a neat end without doing the cutting and burning after pulling the ends through?
I really like the design and plan on a longer strand for a specific purpose.
Thanks!
Apr 15, 2010. 4:46 AMNutandBolt says:
Very nice addition to the bag. You can also make another layer of paracord  some call it "king cobra" . nice bag too I think I recognize the symbol on it from my old days in the army.
http://paracord-projects.blogspot.com/
Sep 11, 2009. 1:26 PMRe-design says:
Excellent instr.
Jul 22, 2009. 6:16 PMsnipir says:
aha that's awesome! I have the same bag :P I'll give your sinnet a try. Thanks!
Jul 21, 2009. 4:22 AMindikagamage says:
great !!
Jun 12, 2009. 12:29 PMaxiesdad says:
What if you were to lay in the two 12 1/2 pieces right after the first knot and then proceed to the finish, covering them as you go? This would let you pull the ends all the way through the handle, giving it more fullness, and no bulge where they stop.
Jun 8, 2009. 8:30 AMcopiesofcopies says:
This instructable is almost exactly what I'm looking for to replace the busted top-carry handle on my backpack. Unfortunately, I don't have pre-installed D-rings on mine (the erstwhile handle was sewn into seams, which is part of why it broke). Do you have any advice for adding D-rings to a D-ringless bag?
Jun 11, 2009. 8:20 AMtw0nst3r says:
I wouldn't use D-rings...split rings, used for keys and sold cheaply at hardware stores, are stronger, longer-lasting, and multifunctional if needed for something else in a pinch.
Jun 11, 2009. 9:04 AMAud1073cH says:
The D-rings here came with the bag, and look plenty strong. If you are making your own anchors, there are D-rings available that are stronger. Although split rings work OK for keys and light loads, you'd never use a split ring for rigging. the spring steel will flex, and pull the ring apart. A D-ring rated for the weight of your load is better. You can also use stainless steel shackles -They look cool too.
Jun 11, 2009. 11:20 AMtw0nst3r says:
I've used split rings for some camp/backpacking rigging, but now that I think of it, it's always been for lighter loads. Thanks for the clarification!
Jun 11, 2009. 11:24 AMtw0nst3r says:
Sorry to reply to my own post, but I've also had D-rings fall apart. Replacing them with split rings worked for those applications (duffle bags, tent guy stays, etc). This is why I posted what I did earlier. Again, thanks for the info!
Jun 11, 2009. 4:37 PMflio191 says:
Yeah, it just depends on the rating of those D-rings again, and what you're carrying, and directionally, which way the ring is being pulled because each one has their own specific usage, but for this case, i think D rings just look better because the flat side allows for that flatness of the straps to stay straight (and when straps stay straight like this, it usually lasts longer because there's equal tension on the straps across. I don't think it's that serious of a difference here though, just cause it really only matters when you're rigging large objects... like theater lamps and stuff. iunno, im talking too much.
Jun 11, 2009. 3:30 PMDr_Romulus says:
What about using a carbiner? I've seen a few smaller one with little snapdown "lock bars" to keep them from coming open...
Jun 11, 2009. 1:07 PMsrilyk says:
One thing that you can't see terribly well is that the piece has an "X" sewn into it - that adds strength. If you're using a sewing machine, you can go slowly (and use the little reverse button when you start out to stitch back over itself) and even "regular" needles should work. Or just get a thimble and go to it! (a penny taped over the pad of your thumb also works in a pinch)
Jun 11, 2009. 2:38 PMDr-G says:
Very nice and clean! I like it.
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:keng
