Introduction: Make a Wire Heart Finger Ring
Howdy!
This gurl thought she'd share the process of how to make a wire heart finger ring, just in case ya have a sweetie who'd like one.
Step 1: What You'll Need
You'll need wire (I used 20 gauge), round nose and cutting pliers and a glue stick or lip balm in order to shape the ring to fit your finger. You can always use your finger too! It may take you a few times to master this, so I suggest using scrap wire if you don't want to use up your red colored wire or precious metal wire.
Step 2: Cut the Wire
Cut a piece of wire apprx. 5 inches.
Step 3: Shape the Wire
Shape the wire on the glue stick or lip balm.
Step 4: Now You Have a U Shape
Now you have a 'U' shape.
Step 5: Bend Left Side
Bend the left side with your round nose pliers just a bit above where the ring will hit the top of your finger.
Step 6: Make a Larger Bend
Make a larger bend using your round nose pliers.
Step 7: Pull & Flatten
Pull the wire down for the first side of the heart and flatten it so it is on the top where it would lie on your finger.
Step 8: Repeat for the Other Side
Repeat for the other side.
Step 9: Connect
Using your round nose pliers, connect the left side of the wire to the base with a small loop. You want to make sure it's tight and cut any excess wire so it won't snag on your finger or clothing.
Step 10:
This is the side connected to the ring portion. The ring portion is the large circle part on the top left. Repeat for the other side by pulling the wire end up to the left and connecting.
Step 11: Connect Other Side
Your heart is shaped. Flatten down so it lies on top of your finger. You may have to wrangle the heart shape a bit to your liking. Clip any excess wire.
Step 12: Yer Done!
Yer Done!
