loading
Step 2: Prepare to build
Before you start building, you should probably lay out a design for you're iron. The one that I am using to show you is just a quick one that I made for the sake of this Instructable. I am currently planning a nicer one but I wanted to do this Instructable before someone else takes my ideas. I put a diagram on here to give you a basic layout on how to assemble the iron. This iron draws up to 1.7 amps so don't use any components that can't handle that. Most can though, so don't worry about it to much. I could have put a schematic on here, but since this is supposed to be an instructable that most people can understand. Try to collect all the materials that you need and see if you can find a nice enclosure for it. As you can see, I modified, and mounted components on that. What I will eventually do is to use a fancy necklace box and mount everything in there. That make it fancy, portable, and easy to change the batteries. You just flip open the cover. I'll post a picture of my started project with this enclosure. Also, if you want to make this a plug in iron, you will need to replace the battery pack with a 6 volt 1.5-2.0 amp D.C wall wart.
My Instructable has been featured on <a href="http://hackaday.com/2012/04/16/diy-battery-powered-soldering-iron/" rel="nofollow">hackaday.com</a>!&nbsp;Im actually pretty exited about it. <a href="http://hackaday.com/2012/04/16/diy-battery-powered-soldering-iron/" rel="nofollow">Heres the link.</a>
What soldering iron tip? The links are broken. :/
<p><a href="https://www.amazon.com/RadioShack%C2%AE-GH-150-Soldering-Cat-6400039/dp/B005N9JABI" rel="nofollow">https://www.amazon.com/RadioShack%C2%AE-GH-150-Sol...</a></p><p>This one, according to the Internet Archive of the link.</p>
ita a great project but i cannot find any of the materials on radioshack <br>are they available a t a ebay or amazon
<p>I looked the parts on Amazon, here are the links:</p><p>Pre assembled cordless soldering iron<br>with light ($15): <a href="http://amzn.to/1VxvqJv" rel="nofollow">http://amzn.to/1VxvqJv</a></p><p><br></p><p>Altoids tins (12 pack):<br><a href="http://amzn.to/1JQjo7c" rel="nofollow">http://amzn.to/1JQjo7c</a> </p><p>E10 Bulb Bases (12 pack):<br><a href="http://amzn.to/1VxwfC0" rel="nofollow">http://amzn.to/1VxwfC0</a></p><p>E10 Soldering iron head (1 pack):<br><a href="http://amzn.to/1VxwHjY" rel="nofollow">http://amzn.to/1VxwHjY</a></p><p>4xAA battery holder (2 pack):<br><a href="http://amzn.to/1Vxwugs" rel="nofollow">http://amzn.to/1Vxwugs</a></p><p>Momentary push button switch (6 pack):<br><a href="http://amzn.to/1VxxvFf" rel="nofollow">http://amzn.to/1VxxvFf</a><br><br>I'm looking to build a more compact unit. Do you think a 3.7v 35A 2900mAh high drain e-cig battery could power it? 3.7 x 35 = 129.5 watts</p><p>Battery: <a href="http://amzn.to/1VxyEgb" rel="nofollow">http://amzn.to/1VxyEgb</a></p><p>Holder: <a href="http://amzn.to/1VxyEgb" rel="nofollow">http://amzn.to/1JQkRdW</a></p><p> I figure it can heat multiple coils red hot, wouldn't it have enough juice to heat up the tip sufficiently to solder? </p>
<p>could u give links for these things to amazon or ebay? radioshacks online store is down.</p>
Hi, could i use the same circuit only instead of the battery, use a USB cpoweer supply @ 5V with 500mA? Or do i need to modify the circuit in any way? Thanks a million, anyhow! Very good and clear instructable!
<p>Your links with pics of what each item to buy looks like are broken. ..can you fix this? </p>
This is a great idea! I will be making an instructable soon about a battery powered soldering iron inspires like yours! Keep on creating and inspiring!
<p>Can i use it to solder wires to my micro usb cable? Working on a project and my soldering iron doesn't seem to work.</p>
<p>Wow, what a great idea. The final pictures actually look really sleek, probably my favorite altoids tin project!</p>
Would it be possible to run a series-parallel battery pack made with 3.7 v lithiumbatteries as the power source.
what is the tip made of??
what is the min and max power requirements for the soldering tip? along with amperage
From my testing, I found that the Iron will work down to 3 volts, and will safety operate up to 7.5 volts. The lower the voltage is, the lower the temperature of the iron will be. It should ideally be run anywhere from 3 to 6 volts, because that is what the tip was designed for, but if you will not be keeping it on for a long period of time, 7.5 should not be a problem. The ideal amperage is 1.5 to 2 amps. You may be able to run it at a lower amperage, but you risk stressing your power supply, or not getting sufficient heat output on the iron.
can u tell me a link from ebay.com which has this type of tip tnx
<a href="http://www.ebay.com/itm/RadioShack-GH-150-Soldering-Tip-for-Cat-6400039-8203307-/161049447137?pt=LH_DefaultDomain_0&hash=item257f4b8ae1" rel="nofollow">Here you go!</a>
Adam, great post, I even saw you got some press on the hackaday site. Nice! <br> <br>I built one this weekend and had it working great on a couple sets of 3 AA batteries all weekend. (so much easier and better than my finicky butane torch iron! And more precise) <br> <br>I tried using a 16 VDC wall wart, the smallest one I had laying around, and it wont heat up. In fact using more than three AAs seemed to give me problems too. <br> <br>Any ideas? I wonder if the heater is somehow voltage regulated above around 6 volts. I also tried using a single 9 Volt thinking it would keep the size down, but that only lasted a few minutes before it stopped working. Perhaps some internal battery resistance challenges? <br> <br>Anyway, great write up, thanks!
Thanks for the compliments! Try not to supply the tip with over 6 volts to avoid shorting it out. 7.5 volts may be ok, but it can possibly shorten the life of the tip if used for extended periods of time. Also, it seems that the other power supplies you are using might not supply enough current to power the iron. Typical AAs supply around 1 amp hour of current, while a typical 9 volt battery would supply around half that. The wall wart you are using is probably not rated for at least 1.5 amps, which should be the minimum capacity for the power source for this to work properly.
I did build this now ^^ <br> <br>But only with 3 x 1.5V works fine though!
I'm glad you got it working! I hope it turns out to be use full someday.
Well yeah, I tried to burn some Weed with it. Works ^^ So I use it as the heating element for my vaporizer now :p
why not use a switched jack socket rather than a relay to disconnect battery power when running from a wall wart? 3.5mm mono audio jack, for example.
I was going to head over to All-elecronics to buy just that. However, I decided on using a relay for some reason. I don't remember why though. :P
Oh, I remember. I think it was because I wanted to use a relay with multiple switches, so when I plugged in the wall wart, it would also switch on a charging circuit for rechargeable batteries. I have never gotten to this point. I king of gave up on the project. I will resume soon though.
Parece mesmo bastante simples. Minha dificuldade: ponto 1 da lista de material. E como mero hobbysta, pergunto: eu poderia utilizar a ponta de um ferro de solda comum - 15 watts? E se puder, solicito orientac&atilde;o de como proceder! Agradecimentos antecipados ao&nbsp;expert pela dica. &nbsp;
Usted lamentablemente no se puede usar cualquier punta. Usted debe usar el de Radioshack que muestro en mi instructable. No s&Atilde;&copy; de ning&Atilde;&ordm;n otro que va a funcionar. Lo siento. La raz&Atilde;&sup3;n de esto es porque el calentador est&Atilde;&iexcl; incorporado en la punta. <br> <br>(English) &quot;You unfortunately cannot use any tip. You should use the one from Radioshack that I show in my instructable. I don't know of any other one that will work. Sorry. The reason for this is because the heater is built into the tip.&quot; <br>
Ah! bom, macho, assim at&Atilde;&copy; eu! A ponta j&Atilde;&iexcl; pronta, &Atilde;&copy; muito f&Atilde;&iexcl;cil! (Brincadeirinha, Z&Atilde;&copy;). E outra coisa: eu sou brasileiro, macho, pra que aquela ruma de espanhol? Tamb&Atilde;&copy;m &Atilde;&copy; s&Atilde;&sup3; onda, Z&Atilde;&copy;? Agora &Atilde;&copy; s&Atilde;&copy;rio! Eu j&Atilde;&iexcl; li tanto esses instructables e coment&Atilde;&iexcl;rio de voc&Atilde;&ordf;s, inclusive o cold iron, que eu, nem que seja por osmose, j&Atilde;&iexcl; t&Atilde;&acute; at&Atilde;&copy; sentindo no clima! Eu tenho outra pergunta. T&Atilde;&iexcl; preparado? Ent&Atilde;&pound;o, l&Atilde;&iexcl; vai: voc&Atilde;&ordf; disse que a liga&Atilde;&sect;&Atilde;&pound;o da ponta &quot;pronta&quot; parecia com a de uma l&Atilde;&cent;mpada de lanterna. Algumas das l&Atilde;&cent;mpadas que ligamos na rede el&Atilde;&copy;trica seguem o mesmo princ&Atilde;&shy;pio (gostou do principio?), sendo que seu filamento aquece, antes de brilhar. Ser&Atilde;&iexcl; que uma ponta de cobre n&Atilde;&pound;o chegaria, pelo menos ao aquecimento, se a lig&Atilde;&iexcl;ssemos nas suas baterias ou na rede el&Atilde;&copy;trica? N&Atilde;&pound;o vale tirar onda! Eu t&Atilde;&acute; falando s&Atilde;&copy;rio, eu j&Atilde;&iexcl; disse que sou hobbysta, portanto, leigo. Blz. Mas s&Atilde;&sup3; em voc&Atilde;&ordf; haver respondido, satisfez a minha curiosidade, e eu agrade&Atilde;&sect;o, sinceramente, pela considera&Atilde;&sect;&Atilde;&pound;o. Obrigado, mesmo.
u speak portueguese
I am terribly sorry, but I was not able to translate what you were saying. Is there a way that you could translate it to english?
Ah! Well, brother, so until I! The tip of the iron made, is very easy. (I am kidding, brother).And another thing: I'm Brazilian, man, Why buy the whole Spanish ? ate've read both these Instructables andcomments from you, including the cold iron, which, even by osmosis, I'm going into theatmosphere (beginning to understand). I have another Question Are you aware? So pay attention. You said that the binding of iron tip was similar to the binding of a flashlight bulb, SOME of the lamps that we connect the power grid follow the same principle (Like thebeginning?), And its filament heats beforeShine. Does a copper tip come in, at Least, heating, if the lig&Atilde;&nbsp;ssemos OR IN THEIRbatteries in the electric grid? Not worth takingwave! I'm serious, I said that I am hobbyist, solayman. Blz. But not until you have answered, satisfied my curiosity, and I thank sincerely forconsideration. Thank you, really. EDITING: I replace some terms by the adjective &quot;brother&quot;, which is almost the same thing, but do not havethe same amount of sarcasm. Let's see now is a little better.
Desculpe sobre o espanhol. Traduz Google deu-me a linguagem errada. Se eu entender que voc&ecirc; est&aacute; quest&atilde;o, voc&ecirc; est&aacute; perguntando como a dica funciona e como se relaciona a uma l&acirc;mpada normal. A rela&ccedil;&atilde;o apenas a uma l&acirc;mpada normal &eacute; que ele tem o conector mesma forma. H&aacute; um elemento de aquecimento no interior da ponta, mas eu n&atilde;o sei o que a tecnologia &eacute; utilizada. Eu sei que tem que ser eficiente para que ele possa ser de carbono. As duas liga&ccedil;&otilde;es est&atilde;o na parte inferior da ponta e da base inteira da ponta. (English) &quot;Sorry about the spanish. Google translate gave me the wrong language. If I understand you're question, you are asking how the tip works and how it relates to a normal light bulb. The only relation to a normal bulb is that it has the same shape connector. There is a heating element inside the tip, but I don't know what technology is used. I know that it has to be efficient so it might be carbon. The two connections are on the bottom of the tip and the entire base of the tip.&nbsp;
BEAUTY, I'll buy that tip. The mnha reciprocated, though, unless you have many thanks for abdais important, is not buying: it's learning to do. This is important, &quot;very important&quot; in addition to the exchange, another positive aspect. Although in this case, I have nothing returned, unless you many thanks for your time to have abdicated affordably. Grateful. Gratias. Thank you, very math. Greetings more.
TRADU&Atilde;‡&Atilde;ƒO ALIEN&Atilde;GENA, SINISTRA... VALEU GAROTO!
O google transformou o texto que eu digitei. O resultado voc&Atilde;&ordf; j&Atilde;&iexcl; viu: inintelig&Atilde;&shy;vel, que nem eu mesmo entenderia. Mas eu vou traduzir, substituindo alguns termos, sem alterar o sentido e mantendo todo o texto, inclusive algumas brincadeiras que est&Atilde;&pound;o no in&Atilde;&shy;cio, Ok? Espera s&Atilde;&sup3; um pouco.
Hey Man, I am Working on a SteamPunk Inspired Vaporizer, and this seems like one of my only Options for the Heat Source. <br> <br>Any though on this? <br> <br>I need it to be about 160 - 200 degrees CELSIUS. <br> <br>Feel free to email me oliverschoening(at)hotmail.com
Thanks for the design. I think I'm going to try this and have a couple of questions. You describe above how to get a hotter temperature using higher voltage. <br> <br>Would this work with 1, 2 or 3 batteries and put out less heat?
Yes! Im not sure how hot it gets under 3 volts, but for me 3 volts worked fine.
Have you seen this: http://eletronicos.hsw.uol.com.br/soldador-cold-heat1.htm It is similar to &quot;cold heat&quot; of Photoos (the method of welding), and also to your (the power - the batteries). Incidentally, the graffiti tip (cold heat) are isolated or make contact with the two copper strips? Thankx
Actually, I do not want to buy a soldering iron, because I already have six that EsAO defective, and I can not reattach them, because they do not understand how &Atilde;&uml; made &acirc;€‹&acirc;€‹CONNECTIONS coil (winding). If you can give ANY HINT ABOUT IT, it would be great. I work in public safety, higher education, and practice various hobbies (DIY away for a little xdepress&Atilde;&pound;o. I'm always looking for useful information, it takes me some practical knowledge: llidar with many tools and and all kinds of material: wood, metal, glass, plastic, PVC, fiber ... It works as a distraction and get several ways to help people: relatives, friends, poor members of the church
This is grate, and i need it, but i have one question: <br>Witch part here is the heater? Can you say something about the circuit? <br>Tnx!
The part that heats up is the tip itself. It has a built in heating element. The two connections to the heating element are on the part of the tip that looks like a flashlight bulb. Negative is on the bottom and positive is the base.
Could this be done with a 6v 8ah sla battery? Would there be any issues? I have a few lying around and have been trying to find a use for them...
Absolutely! I think that it would work great.
i like it.
What do you need to do in order to make a 30 watts soldering iron? Assuming you are able to connect the soldering iron to a wall plug in or a rechargeable battery. Great Instructable by the way!
Also, This is not a 15 watt iron. I't a 15 watt equivalent. That means that it gets just as hot as most 15 watt irons but does not draw as much power. This iron only draws 9-10 watts depending on your power source. On a wall wart this iron gets red hot, and this is warmer than batteries because batteries will not let it draw it's full amperage due to internal resistance. If you are looking to get this to about a 30 watt equivalent, then I would experiment with a 6 volt 2 amp wall transformer and see if that gets hot enough for you. If not move up to 7.5 volts. Can you tell me what you are trying to solder that needs a 30 watt iron? I'll test it for you and see if it works.
Well, for the most part 30 watts are needed for electronic soldering. Although 15 watts would work it will take longer to melt the solder.
This will work on almost anything you can throw at it. It is more powerfull than almost every other battery powered iton on the market. I wouldn't worry about solder not melting. I tested it on house wiring and lamp cord. Both worked fine.
I had some reservations since I have never worked with a soldering iron less than 30 watts. I will try to replicate your project. Thank you for posting!
About This Instructable
103,563views
176favorites
License:
More by Adam Manick:Make a battery powered soldering iron! In an Altoids tin? USB Rechargeable Flashlight
Add instructable to:
