3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a battery substitute power connector
After the batteries went dead in the middle of a shot using my new camera with double the number of megapixels and features, I discovered there was no external power connector. Once a shot is lost, it may be lost forever, so an external source of power can be a critical option.
This Instructable will show you how to work around a proprietary or a non-existent power connector by making a battery substitute power connector that will allow an external power source to be used.
Step 1The power supply
The power supply
Combine or Not?
In many devices, such as a flashlight, the batteries are wired in series. In these devices you may be able to combine the voltages with a single battery substitute connector and power supply that provides only the total voltage, hence one AA = 1.5 votls, so 2 x AA = 3 volts..
In other, more sophisticated devices like cameras the batteries may be wired, or look like they are wired, in series but the series connection between them may be tapped or non-existent. If you are making a battery substitute power connector for one of these devices then you might have to make separate 1.5 volt battery substitute connectors and supplies for each battery the device will use.
External Power Sources
A portable external power supply can be made using a bank of external cells wired in parallel to keep your device going all day.
If you don't need portability as with studio type work a wall wort type power adapter with a minimum rating of 1 amp can be made using a transformer, bridge rectifier and a voltage regulator. Most regulators will handle a supply of up to 36 volts so a wide range of transformers can be used. A large micro farad capacitor with various other circuit refinements can be incorporated to provide power that is smooth. A circuit diagram based on the 78xx voltage regulator series is shown below.
The other options are to purchase a used 1.5 or 3 volts power adapter at a thrift store or a new one from Radio Shack or Wal-Mart for a little more cash. Multiple output voltage adapters, if they have a 1.5 or a 3 volt output, can be used as well but may be more expensive. Be sure you have one that is rated for at least 1 amp output. Otherwise your device will probably not operate or will at some point do the very thing you are trying to over come, which is to shutdown.
I opted for a wall wort type power supply from Radio Shack because one was sitting in my drawer. (Its only rated at .3 amps so I replaced it with a bigger one.)
17 comments
Jan 8, 2012. 6:14 PMBatSub says:
Check out the new device at www.batsub.com; It's an adapter that'll help you with battery substituting. I think it's a step in the right direction.
Mar 6, 2008. 5:07 PMortho says:
yes dowel is what i used
Feb 18, 2008. 11:56 AMandreq says:
I've done the exact same thing some years ago to power my (now sold...) Sony MD player. I was eating so much power when transfering music to md that I've created a AA cell just like you did here... 1wood dowel with thumbtacks Nice instructable
Feb 23, 2008. 4:32 PMklee27x says:
You might be surprised with the newer cameras. I was extremely upset when I saw how small the battery is for my newest camera. But I have completely loaded and downloaded the memory once or even twice over without even losing a bar. I only put it on the charger after it gets a good workout and is down at least a bar or two... and that's not often.
Feb 23, 2008. 4:17 PMklee27x says:
My method would be to glue a 3 pin section of female pin header onto the outside of the camera, next to the battery holder. Then solder 30 AWG kynar wire directly to the battery terminals, connecting them to the port (middle pin positive, outer pins negative). This would create a nonproprietary power plug. Then use clear packing tape to hold the wires down to the battery case. It sounds hard, but it's probably easier than making fake AA batteries. I've done this many times. BTW, you only have to solder two wires, not four. Rarely, some test equipment might run from a +- 1.5V supply, but your typical device only uses the 3 volts in series; two of the leads in that battery clip are actually higly likely to be connected to each other (and to nothing else) and can be ignored, altogether. Actually, the way you wired it, you should be careful to not hook them up to the same 1.5V power source, as you will probably just short the power supply. If the camera has an easy to open plastic case, as yours appears to have, you can even solder your wires directly to the pcb. Then you could either make a tiny hole through which to route the wires, or you may even find enough space to cut a slot for the port's face and mount the entire port internally. Nice instructable!
Feb 18, 2008. 8:56 PMgarrettmikesmith says:
"contacks" - i like it. make sure you have the right amperage though. portable devices pull power out of batteries and wall wart transformers at whatever rate the device needs. batteries supply the device with pretty much any amount of amps needed, because they are drawn out of the batteries. in a wall wart transformer, this is not always the case. if the listed amperage is too high, that's fine, the device will only pull what it needs from the wall unit. if the listed amperage on the wall wart is too low, it will not have sufficient power and could lead to device malfunction.
Feb 19, 2008. 5:51 PMgarrettmikesmith says:
fo sho
Feb 19, 2008. 3:56 PMortho says:
I just made one a few weeks ago i was going to post it you beat me to it . what else do ya got?
Feb 19, 2008. 5:33 AMLinuxH4x0r says:
Awesome! I'll have to do this some time
Feb 18, 2008. 10:55 AMGorillazMiko says:
Intelligent idea. Great pictures, great detail, just great everything. This is truly just a great Instructable. :-)
Feb 18, 2008. 8:45 AMzupHC says:
Great! The use of the wood dowel and the pins is a great idea! Maybe with a thinner wire... A+++
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:thinkahead
