Make a bottle-shaped candle
 by sladek
Featured
This instructable will show you how to make this funky candle with very little effort.
This'd make a nice home-made present for grandparents or something like that, but kids should not attempt this without an adult's help.
You'll need the following:
A glass bottle, any size or type
A load of candle wax from new, used or dead candles
A candle wick (or 100% cotton string)
A small weight such as a fishing weight or washer
and you'll also need:
Cooker hob to melt candle wax
A container to melt candles in, I'm using a fizzy drink can with the top chopped off
Gloves or something to handle the hot container with
A hammer or something to break glass with.
Step 1: Preparation
Clean out your bottle and make sure it's dry.
Cut a length of wick that is longer than your bottle's length, you can shorten it after.
Tie a weight to the bottom of the wick, this will help it stay straight.
Have everything close to hand and you'll need to work fast to make sure the wax doesn't harden.
Spencer101 says: Aug 27, 2011. 12:23 AM
I would just like to point out that heating wax over direct heat without a thermometer is very dangerous. Regardless of how low you have the hob turned on, wax can reach "flash point" VERY quickly if not monitored properly and a fire in your kitchen is less than ideal!!
maxman says: Feb 16, 2011. 9:43 AM
I like the magnet idea.
muzza182 says: Jun 22, 2010. 7:03 AM
You could try it with plastic bottles, some may start to lose shape because of the heat. You could use plaster of paris or something to make two parts to a mold around a bottle, when it's set, take them off, then you don't have to break a bottle every time, just use the two parts of the molds, tapped up, pour in wax, when its set, untape them, and there you have it.
redwren says: Jun 4, 2010. 6:28 AM
Instead of lowering the wick in and then draping it over something, try tying the wick around a stick first and then lowering it in until the stick rests on the top of the bottle, like you do to make rock candy. Just make sure that the wick hanging off the stick is no longer than the bottle, and trim off the tail so that it doesn't dip into the wax too. When you are done, just slide the stick out of the loop and untie it, or trim it off.
woutervddn says: Jun 1, 2010. 1:22 AM
you can do it with a plastic bottle.. I did it at the youth movement with plastic bottles. You just need to cut them open with a scalpel, you'll allways see a line where you cutted, so you can try rubbing it with a hot stick (not to hot, you just want it to get smooth not to be dripping again..)
TechNerd1012 says: Apr 23, 2010. 10:00 AM
you could also break the glass cleanly by scoring the glass, heating it up, then introducing some ice cold water to it somehow (such as a spray bottle). The thermal shock will fracture it right along the score.
pyrorower in reply to TechNerd1012May 19, 2010. 5:42 AM
The only problem with that is that in heating the bottle, you could melt/soften the wax...
TechNerd1012 in reply to pyrorowerMay 19, 2010. 11:21 AM
true
TechNerd1012 says: Apr 23, 2010. 10:01 AM
The color of this candle actually looks very similar to the color of real cola
you could play off that somehow lol
Jebotepatak in reply to TechNerd1012May 13, 2010. 7:48 AM
Cool idea thanks too bad i only have plastic bottles lying around -_-
TechNerd1012 in reply to JebotepatakMay 13, 2010. 5:53 PM
yeah
luckily theyre making more and more of the glass ones again, you can prob find some at Fred Meyer or something
Miscelinious says: Apr 24, 2010. 2:34 PM
Would it be better to put the wick and weight in first before pouring the wax?
OfficerKarl in reply to MisceliniousMay 8, 2010. 9:52 PM
 It might be a bit harder to pour the wax as Kryptonite said, but it would more likely mean that the wick wouldn't be straight, and the candle wouldn't burn evenly.
"Sorry about the poor light. Here you need to lower the wick into the wax. To keep it as straight as possible, I didn't let the weight touch the very bottom of the bottle."
Kryptonite in reply to MisceliniousApr 25, 2010. 3:49 AM
It would make it harder to pour the wax in though.
infernisdiem in reply to KryptoniteMay 7, 2010. 3:20 PM
I have a candle melting machine, that pours a very fine stream, where when I put the wick in first.
casman300 says: Apr 28, 2010. 9:49 AM
wo great idear would be even better if you could stensil on the logo and writing
could you also do this with the plastic coke bottles or would they melt to fast?
sladek (author) in reply to casman300Apr 28, 2010. 10:10 AM
Instead of stencilling designs onto the wax, if you get a bottle that's got embossed writing on it, then when you remove the glass, it'll have an embossed logo on the candle.
You could try plastic, it may melt which would get wax everywhere, also, unlike glass, you'd have to cut the plastic bottle away rather than smash it. This would probably result in score-marks all over the candle
casman300 in reply to sladekApr 28, 2010. 11:04 AM
thanks i will make one as soon as i can get a glass bottle
american-teen95 says: Apr 24, 2010. 6:48 PM
this is a great, easy gift. try it!
scraptopower says: Apr 23, 2010. 5:19 AM
You can melt the wax in that pot in a pan of boiling water to prevent if from over heating and burning.
Techy in reply to scraptopowerApr 23, 2010. 6:38 PM
I made one of these today and used this method. It was slower than putting it directly on the burner but I didn't have any of it burn. Good instructable for those days when you want to make something, but don't want to put a whole lot of effort into it.
sladek (author) in reply to scraptopowerApr 23, 2010. 6:17 AM
You're right, but the reason I used an old can is so I could make a spout.
The average pan doesn't have a spout, making it very hard to pour in to such a small hole.
danlab in reply to sladekApr 23, 2010. 7:45 AM
What reukpower was suggesting was that you put the can in a pot of boiling water to melt the wax, that way the wax won't get too hot and burn.
sladek (author) in reply to danlabApr 23, 2010. 8:37 AM
Oh ok, that makes more sense, and sounds like a better idea too
Ski999 says: Apr 23, 2010. 5:53 PM
Glue a small rare-earth magnet centered to the bottom of the bottle and use a ferrous weight. That should center your wick.
magickaldan says: Apr 23, 2010. 3:33 PM
Great job, would be a little cooler if you could make a mold of the bottle. to get the true shape of a popbottle.
sladek (author) in reply to magickaldanApr 23, 2010. 4:07 PM
It would, yeah, but also a lot more effort.
Koosie says: Apr 23, 2010. 2:24 PM
hahahahaha, that first picture made me think of a Molotov Cocktail!
Molotov Candle, it shines, VERY bright!
Arano says: Apr 23, 2010. 8:38 AM
i think wrapping the bottle with 1 layer of tape should make it safer (no small pieces of glass flying around when hitt too hard)
mwwdesign says: Apr 23, 2010. 8:26 AM
Great Instrucable!
Maybe suggest people put the bottle inside a bag of some sort to break the glass? Safer and easier to clean up afterwards.
Going to have to make one myself now!
craig3 says: Apr 23, 2010. 2:17 AM
You should probably add as a safety thing, to warm the bottle up a bit before hand, other wise the fast jump from cold glass to hot wax will crack and smash the bottle
sladek (author) in reply to craig3Apr 23, 2010. 3:20 AM
Noted. Thanks for the advice. I've updated the instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
