Remove these ads by
Signing UpStep 1Glue together Wood
48"X1/2" Oak trim piece
24"X1/2" Poplar trim piece
bottle of gorrila glue
Stanley hand planer
bundle of jute rope (In the future, hemp would probably be better)
The hand planer from lowes turned out to be just the ticket for shaving down the bow arms to what I needed. Its only 6 bucks and its about 3"X1" big. Any bigger would probably turn out to be too unweildy. Any sort of wood glue would work really.. as a matter of fact, gorrila glue is probably not the best one to use. The wood was just some project wood or you could use trim wood too, I guess.
This is pretty self-explanatory, just make sure you get the glue more evenly spread than it is in this picture. Use sticks and rope as a clamp and the piece until its cured enough to release. This should actually take a few hours but since I'm really impatient, I waited for half an hour and then started carving. Dont do that, it just messes things up in further steps. Whatever you do, don't try bending the bow until the glue is dry either. This just makes them pop apart.
You need 3 layers, however, and the middle layer is traditionally not made of one single piece, but multiple small ones, which serve, together with a fairly elastic glue, as a means of lending more flexibility, coupled with a higher strength, to the bow. Or at least that is what I gleaned from looking at them, and using them.
http://www.instructables.com/id/Red-Oak-Board-Bow/ Granted, I built mine a little more "properly".
Aside from that, there are other cheap choices. Yew is rather expensive and I would put more effort into making a proper bow with yew wood. (shaping, tillering, backing, finishing, good bowstring)
And besides, by the time you hear one crack, it's too late and you'll need to start over. With anything other than a whisper crack you don't want to risk it blowing up in your face. Bend the wood slowly, progressively further, forming the compression in the wood with short and repeated pulls of the string.
i make bo staffs for my mates and charge them $60 and i use meserti or bamboo if you can suggest a cheaper wood that would be great.
would i be able to buy this stuff online??
could you give me a direct link?
if you just press on the A key, the mph will go on forever!!!!
