In this instructable, I'll teach you how to make a really cool rug, like the one pictured, from your old t-shirts! For me, this rug didn't cost any money because I used stuff I already had at my disposal. This project is a great way to put all of those colorful junior high track/soccer/rugby/quidditch shirts to use if you don't want to donate them.
Here's what you'll need:
- 5-10 old t-shirts, depending on how big you want this rug (I used 5.5 for a small bedside rug)
- a pair of scissors
- needle and thread
- sewing machine (optional)
The hardest part about this was how long it took to make, but it turned out cool enough that I wouldn't mind making another one. Keep reading to find out how I did it!
Step 1: Cut it
Select a few old t-shirts from your closet, a thrift store, or your Aunt Marcy's NASCAR t-shirt collection. I used 5.5 t-shirts to make a rug that is approximately 18" in diameter, but if you have more time and patience than I do or if you want a bigger rug, you could use more shirts. Next step is to prepare the t-shirts by cutting them and turn them into yarn. I used a method that I found on YouTube but I took some photos of this step for here.
You will want to flatten the shirt out in front of you, but face it sideways so that one sleeve points toward you and the other points away from you. Next, measure out every 2 inches from the bottom seam of the shirt (which is on the left or right side now), all the way to under the sleeves of the shirt. Mark with chalk or something that won't be obnoxiously permanent. You will want to start cutting on each mark or line you made, but leave 3-4 inches of the shirt still intact on the far side. Do this up to the sleeves, where you should cut all the way to the other seam. After you cut all of these lines, you can pick up the shirt and arrange it so it looks like a ribcage in front of you, as shown in the photos above. See that bit of fabric that you didn't cut? Now you're going to cut it diagonally so that you will end up creating one long piece of fabric from your t-shirt. This is really hard to explain, but as aforementioned, there are a crapload of YouTube videos explaining how to do this so feel free to search around if you need more coherent direction.
You should end up with a really long strip of fabric from your t-shirt. Stretch this out really, really well and wind it up into a ball so it is more manageable. Repeat for your other shirts.
Step 2: Braid it
After you have prepared all of your t-shirts and made them into yarn, it's time to start your braid. I used a sewing machine to start the braid and for all of my transitions, but it was only because I was so pumped to have just gotten the sewing machine that I "had" to use it. You could totally hand-sew all of these or knot them for a more care-free look.
I started by sewing the end of one yarn strip to the middle of a different colored strip to create a "T" shape. Those were the 3 pieces of the beginning of my braid and when I began to braid, it covered up the stitches (awesome!). Keep braiding until you need to sew on another color. I added a new color by sewing diagonally with the fabric placed right side to right side at a 90 degree angle, and trimming off the tiny corner. This way, when you stretch it out, the strand smoothly transitions from one color to the next. This kind of seam is used for binding in quilts also.
Keep braiding until you have added all of your shirts. You can use an office clip or a chip clip to keep the braid from unraveling if you get tired and want to take a (2 week) break, like I did. It helps to keep the yarn all balled up while braiding so that it doesn't become a big, tangly mess.
Step 3: Coil it
Start pre coiling your rug. Coil it somewhat gently so it doesn't pucker up into a braided t-shirt bowl (LOL), but try not to let any gaps show from one ring to the next. Pre coiling this braid will help you stay organized while you are sewing and will also give you an idea of how big your rug is going to be/if you need to add or remove shirts. I was meticulous (read: OCD) about my braid and made sure there was a distinct "top" side and "bottom" side while braiding, so it may be worth mentioning that I pre coiled with the "bottom" side facing up, as that was the side I wanted the stitching to be on.
Step 4: Sew it
Start sewing your braid together. I used a variation of a blanket stitch and started in the middle, working my way around and out of the spiral. This is the part that took FOREVER. Seriously. I was anticipating sewing this mofo on the machine, but lo and behold, the dang braid was too thick to even think about squeezing under the presser foot. So, hand sew I did.
When you get to the end of your blanket, weave in the ends of your braid into the previous ring and sew to secure it.
Step 5: Lay it
If you got through all of those steps, throw that rug down and relish in your own awesomeness! Whew.
Najwahamid says: Apr 25, 2013. 6:39 AM
Very nice ...
bethcdh says: Apr 17, 2013. 7:04 AM
Could you do the same thing with old blue jeans? Or is the knit fabric better?
suzelac (author) in reply to bethcdhApr 18, 2013. 11:30 AM
You could certainly do it with blue jeans! I would just cut it into smaller strips width-wise because denim doesn't curl up like t-shirt fabric. :)
lcatterall says: Sep 13, 2012. 11:57 AM
That's excellent!! :-)
bree247 says: Jul 20, 2012. 10:51 AM
Thanks, what a great idea!
Wish it would have left me save pdf but I guess ya have to pay for pro!
katvanlew says: May 28, 2012. 8:06 PM
very pretty rug!
Very pretty rug! I really want to make one of these!
Muhaiminah Faiz says: May 28, 2012. 4:17 AM
woww... very nice :D
rugshd says: May 26, 2012. 1:56 PM
I've seen this project before but you've laid it out very well, thanks for sharing!
ChrysN says: May 26, 2012. 11:33 AM
Pretty! I love the bright colours that you used.
suzelac (author) in reply to ChrysNMay 26, 2012. 1:15 PM
jessyratfink says: May 26, 2012. 12:58 PM
It turned out gorgeous. :D
suzelac (author) in reply to jessyratfinkMay 26, 2012. 1:14 PM
Thank you!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
