Make a cassette loop for about 6 seconds.
I saw this in a Punk-fan-zine, Just passing on the idea.
Step 1Un screw..
Unscrew the five screws and open the cassette carefully so you don't
loose any parts.
30 comments
Jun 26, 2009. 12:04 PMtheyoweusaliving says:
Hey, I have the zine that this came from! It was originally done in "How to Zine" published out of Richmond, then republished in Making Stuff and Doing Things (the zine collection book with Christy Roads' art on the front). If you got it from one of these and haven't read the other, check it out! They're both excellent!
Apr 23, 2009. 1:55 PMPlayPatterns says:
You know everyone thinks the weird one in the beatles was John, but it was Paul who started with all the crazy tape loops...
Feb 13, 2009. 4:55 AMtvvintage says:
Great I wanted so long ago to make this loop but didnt think it work now I got my loop anyway i didnt tape it I used uhu
Jun 29, 2008. 3:55 AMDerin says:
you dont need this for vw radios they automaticly reverse the tape
Feb 19, 2008. 11:22 AMmellotronfan says:
I'm thinking about building a "mellotron" similar to this:
http://mysterycircuits.com/melloman/melloman.html
using this technique.
Jan 19, 2008. 10:05 PMRockerx says:
this is great for driving people crazy! a never ending loop of myself making a really obnoxious noise! I Like It!
Dec 7, 2007. 11:21 AMconceptualstratagem says:
Whoa thanks for sharing this looping technique, this is right up my alley. I don't believe documentation is totally necessary to get this idea across.+
Jan 16, 2007. 10:51 PMOhm says:
That would be cool for an old school guitar loop/delay/echo. Now all I need is an old tape recorder to hack.
Jan 18, 2007. 12:03 PMbluey says:
I'd say a multi loop pedal (with the possibility to do 4 echo with adjustable delay controlled by the pedal release). This would involve a good micro controller programming though... ;)
Jan 18, 2007. 1:12 PMbluey says:
A mock device done in Inkscape... :-P
Jan 18, 2007. 2:29 PMbluey says:
The direction and duration could be adjusted too, controlling the motor speed (within the possibilities of the tape sound quality, etc).
Feb 18, 2007. 10:45 PMOhm says:
For more repeats all you have to do is feed the signal back from the read head to the record head with a pot which allows you to adjust the number of repeats.
Jan 25, 2007. 10:50 PMdaryl shawn says:
Instead of using multiple cassette players, I use loop cassettes (sometimes my own, sometimes answering machine tape) in four-track machines. I wrote a whole article about this technique, it's really interesting, and pretty damn cheap, these days.
I also have an ongoing project I call Repetitive Miniatures which is nothing but recordings of cassette loops I've built up with the four-track.
It's definitely a bitch to make your own tapes, but you can sometimes still find splicing blocks at Radio Shack which help a lot.
Jan 18, 2007. 11:38 PMelderek says:
tried it and it didnt work. tape kept slipping.
Jan 19, 2007. 4:04 PMcylver says:
Perhaps something could be worked out with a small roller on a lever arm, spring loaded to provide tensioning? That way, no matter the length of the tape (limited by the length of the spring, and the laws of geometry) the tape wouldn't go slack.
Jan 18, 2007. 5:10 PMb.scott says:
Don't forget to check out this instructables, too. I think we've worked out (in theory) most of the problems, I just haven't actually pulled it off (yet). You could amybe make some kind of multi looper with analog cassette tapes playing drones/crazy drum loops/walls of nosie, and the digital looper playing a chord progression/loop/more process beat.
http://www.instructables.com/id/EFKSQRX8Z0EP287017?ALLSTEPS
Jan 18, 2007. 2:15 PMcdog934 says:
Pretty sure the tape goes at 1 7/8 inches per second. You could make different sized loops by sending it over the other hub. Getting the tension right will keep the tape machine happier.
Jan 17, 2007. 3:07 PMGhauldin says:
Just made one with superglue and extremely cheap blank casette. looks good enough... Now I need a tape recording device to see if it works.
Jan 17, 2007. 2:23 PMcivvic2k1 says:
whats a tape recorder???
Jan 16, 2007. 11:42 PMnobody says:
I wonder if this is the trade secret that the ice cream man told me about...
Jan 17, 2007. 12:14 AMonemisterchristian says:
Is there any way to measure the exact section of music you want so that it is only what plays or is it more of a guess?
Jan 17, 2007. 6:58 AMrobot says:
this is great thing for techno music lovers :-D
Jan 17, 2007. 12:12 AMMr.Devious says:
Looks pretty cool
Jan 16, 2007. 7:56 PMroyalestel says:
Pretty neat. I'd recommend adding pictures for each step and fixing the capitalization for readability.
Jan 16, 2007. 8:07 PMPetervG says:
Real pictures, this looks really useful.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Aestheticxtattoos
You cab also visit my band site. http://www.myspace.com/theseviolentstreets
