3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a cheap backyard ice-skating rink
Step 5Applying the Tarp (liner) and Water
Here we go again, another hard part...
To add the liner (tarp) first lay down the 6 mil plastic liner over top of the PVC frame and then snapped the PVC cap over the plastic liner. The cap provides a duel roll, holding the liner in place and providing protection against skate blades. From this picture you can see why the liner has to be larger than the frame. 4 foot extra on the sides is plenty to not lose any sides.
Make sure to keep the caps at least 2" away from the corners. Later I plan to make a triangular piece from wood to sit over the corner to protect it (if you make one please post a pic of it below). Notice the piece of wood under the corner. Use small blocks to shim the height of the frame so it is all at the same level.
I had some comments about the toughness of the PVC when playing hockey, or skating on it. The PVC its self is pretty sturdy and tough, and you could probably get a good 3-5 years out of it. It really all depends on what your using it for.
Once again, if you have any questions, just post a comment below and ill Try to get to them.
2 comments
Jan 15, 2012. 7:58 PMjaypeak says:
I've been making my rink following your instructions; so far so good. Did you end up making anything to go over the top of the corners? You mentioned maybe doing a wood triangle piece. I'm worried about skates cutting the plastic there. Thanks.
Oct 22, 2009. 9:18 AMtherealmebige says:
Caps? what caps do they come with the pipe or do you have to buy them separate?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:instructors
