Make a cheap electronic detonator!
You can use this to detonate a sonic grenade, firework, lights, anything! Super cheap and reliable, $5 project.
Step 1Get your materials
Get your materials
-Depending on what you want to do, I suggest you pickup an alarm clock (with sound) or kitchen timer. Both were $1 at Dollarama!
121 comments
1-40 of 121next »
Jan 5, 2012. 4:51 PMJizdespenser says:
Should I just buy any type of alarm clock, what gauge nichrome wire would be perfect, do I need a specific kind of relay or is there a basic relay that would would work on any design. By the way I want to use fireworks instead of a personal alarm.
Dec 13, 2011. 6:41 PMbighead5454 says:
Would it be possible to change what is played when the alarm goes off? Such as changing it to sound an explosion for a prop?
Jan 11, 2011. 7:16 AMweezee02 says:
can i connect the alarm clock to a voice recorder so that whenever i set an alarm, it will playback my voice? thanks in advance, it is for our thesis.
Jul 3, 2009. 8:24 PMgedion4000 says:
I have a timer much like this one but when the alarm goes off it beeps, its not a continuous sound, will the current from the short beeps be enough to activate the relay? or does it need to be constant. i want a count down timer to power a relay to fire off a confetti cannon. i was hoping to use an electromechanical relay for its looks, but is there another one that might work better?
Jul 4, 2009. 7:24 AMgedion4000 says:
no i haven't gotten relays yet. i had actually looked at the latching relay option late last night. from what i can tell you need the charges to be reversed in order to turn it off again, any suggestions on that aspect? i was also not sure of how much input they typically need to switch. the alarm i currently have sweeps from .45 volts to .27 volts. about every second or so, but it beeps really fast so i think my meeter is a little to slow to get a super accurate reading.
Nov 23, 2010. 12:43 AMjpoopdog says:
heres a better idea, use a signal relay, with the source current (the sound output), passing through a low current high voltage (e.g A23, 12v) battery. signal relays can turn on high voltages with extremely low currents, such as mine which can turn on up to 15V 5A, using a current at least 5V 5ua (thats the next lowest form of miliamps), which is 0.005 or so miliamps. i have tested this instructable with my signal relays and they work fine, i also discoverd, with my cheap digital alarm clock, that on the microprocesor, or whatever the long black thing with all the pins has (i forgto the name), i remember if i shorted the first and second pins on one side while the alarm went off, or begun it with shorted, the alarm beep would be contant, and oddly become increasingly loud also, but only for 20seconds before it stoped.
Jul 4, 2009. 11:36 AMgedion4000 says:
thanks Matt, i didn't think about using a transistor to fire the relay, ill have to work something out like that if i cant find the right latch. i will also have to figure out some kind of switch to reverse the voltage, the cannon needs to be reset within a few minuets to be used over and over again
Jul 4, 2009. 8:34 PMgedion4000 says:
thanks, ill let you know how it goes.
Feb 7, 2010. 12:22 PMtdwp1122 says:
I don't know jack about relays-where did you get it and what type is it?
Oct 29, 2010. 5:28 PMgizmohalo says:
google it
May 29, 2010. 3:58 PMnturner says:
 how do you wire the relay? and can you use the same concept on a two way radio speaker for a detonator?
Apr 17, 2010. 2:36 AMakinich says:
dude i have the same alarm clock
i opened it up and the wire came of from the solder joint
i need ur help
akinich
Apr 8, 2010. 9:06 AMMinifig666 says:
 Leave this thing by the side of the road and the bomb squad will be all over it in second.
Mar 21, 2010. 2:31 PMdodo101 says:
check my kitchen timer video:
http://www.youtube.com/watch?v=gpegSBDOts0
Jan 23, 2010. 5:39 AMtcm84 says:
Wow! That purple touch sensitive explosive glued to the speaker is really great idea!
Jan 8, 2010. 7:13 PMjsaul2 says:
Hello-
Cool idea--- I'd like to use the guts of a digital, or even analog alarm clock to rig an old portable record player to work as a bedside alarm clock. This would have a record play as a wake-up in the morning... I think it may be a bit more complicated to rig the alarm circuit for this, as the device should still have an on/off switch for normal operation, plus an alarm activated "on." Not sure how to go about any of it- this would be my first such project. Any advice or ideas?
Aug 28, 2009. 1:37 PMrussiankid says:
well in the picture u dont have a seprate battery for the higher voltage of the personal alarm and that that doesnt look like relay can u help out
Aug 22, 2009. 6:10 AMLance Mt. says:
Hehehehe, although its not the most original i always had some fun with it when i was younger
Jul 28, 2009. 8:19 PMDraco6973 says:
In this photo you can clearly see a resistor- the dark, cylinder at the top/left -and a small transistor- a smaller dark shape- just below and right of the resistor. It is helpful for you to know the function of these components and how to connect them to accomplish the desired outcome of this Instructable. Don't give up! It can be done!
Apr 26, 2009. 8:36 AMe-vad says:
ok.. i am kinda new to this stuff. and i have worked with some basic wiring but when it comes to a relay i have no clue, so could some one maybe make an instructable or just tell me where to hook the wires up and where they are coming from.
Feb 15, 2009. 7:49 PMronnytehpir8 says:
i'd like the alarm to throw a 24 volt sprinkler valve. anyone know how?
Mar 21, 2009. 1:40 PMmortso says:
Hi... You need a relay to fire the 24 v. circuit which can be triggered by the small voltage coming out of the speaker terminals. You would hook the Relay between 3- 9v. batteries connected in parallel and then to your sprinkler valve, using the timer / relay to fire the valve.
http://www.radioshack.com/product/index.jsp?productId=2062479
This relay from Radio Shack should do nicely.
The batteries, while DC, work fine with the AC Sprinkler valves, Just don't hold the button down too long or it could burn out the wiring in the Valve.
Mar 22, 2009. 3:38 PMronnytehpir8 says:
thanks a million!
Mar 22, 2009. 8:05 PMmortso says:
Sure... I tried to send a diagram but something about formatting stopped it. Good luck and BE SAFE! Mark
Jul 9, 2008. 8:39 PMDELETED_evilfrogie says:
(removed by author or community request)
Dec 22, 2008. 10:31 AMAzor says:
You could add a switch to the circuit and just turn it off. (I think...)
Aug 13, 2008. 2:15 AMGavabc123 says:
Take the battery out?
Aug 13, 2008. 10:32 PMDELETED_evilfrogie says:
Mar 21, 2009. 2:22 PMmortso says:
A Safety Switch; It's easy to build a switch which MUST be held at angle or it won't fire. Most modern heaters have this mechanism in them, you could steal one from Mom's bathroom portable heater lol, just don't be shocked when it then falls over and burns the house down... It's probably easier to build a contact which to cut the power to the main timer / detonator if the unit falls over. Alternatively, and very VERY cheap, would be to take a reed switch, ( you can make from a tin can ) with springs to keep the switch closed. Then take a plastic "shim" or "connection barrier" and slide it between the reed switch contacts... attach a length of fishing line or twine and the thing can't go off until you pull the plastic "safety" off and activate the circuitry. This allows you to GET AWAY FROM THE DEVICE.
Mar 21, 2009. 6:41 PMDELETED_evilfrogie says:
Mar 23, 2009. 12:37 AMmortso says:
Frogie, You are Right. SAFETY is paramount. This is only a 2nd backup safety switch... the real important switch would be an "Attitude Switch" to stop the timer if the "project" fell over or otherwise got out of true 90 degrees. I just made one out of an "Airborne" bottle... and a lead ball 1/2" and two wires, some electrical tape. It triggers at 50 degrees tip. This makes it possible to have a non vertical launch without mods... but it triggers well dead on at 50 degrees. I'll try to post an instructable but the bloody Airborne bottles have changed... now they have a snap on cap! :—(
Mar 23, 2009. 11:53 AMDELETED_evilfrogie says:
Mar 23, 2009. 12:29 PMmortso says:
You need to check out the Australian Bottle Rocket gang...
http://home.people.net.au/~aircommand/index.htm
These folks have spent a lot of time making Rockets work.
Aug 14, 2008. 12:04 AMGavabc123 says:
Or that...
Sep 5, 2008. 4:03 AMDarkTrinity says:
I'd say running away would do pretty well heh.
Nov 30, 2008. 12:42 PMicemanx23 says:
I'm from iraq and i would like to ask "can i use this to detonate explosive?' Just kidding.
1-40 of 121next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:matt
I liked designing and building things long before I became an engineer, now I get paid to do it!
