Make a cheap electronic detonator! by matt
You can use this to detonate a sonic grenade, firework, lights, anything! Super cheap and reliable, $5 project.
Step 1: Get your materials
-Depending on what you want to do, I suggest you pickup an alarm clock (with sound) or kitchen timer. Both were $1 at Dollarama!
Aron313 says: Feb 29, 2012. 6:13 PM
Thats cool! I used a cell phone to detonate mine. I made it so that when you call it sets off the firework!
Jizdespenser says: Jan 5, 2012. 4:51 PM
Should I just buy any type of alarm clock, what gauge nichrome wire would be perfect, do I need a specific kind of relay or is there a basic relay that would would work on any design. By the way I want to use fireworks instead of a personal alarm.
bighead5454 says: Dec 13, 2011. 6:41 PM
Would it be possible to change what is played when the alarm goes off? Such as changing it to sound an explosion for a prop?
weezee02 says: Jan 11, 2011. 7:16 AM
can i connect the alarm clock to a voice recorder so that whenever i set an alarm, it will playback my voice? thanks in advance, it is for our thesis.
gedion4000 says: Jul 3, 2009. 8:24 PM
I have a timer much like this one but when the alarm goes off it beeps, its not a continuous sound, will the current from the short beeps be enough to activate the relay? or does it need to be constant. i want a count down timer to power a relay to fire off a confetti cannon. i was hoping to use an electromechanical relay for its looks, but is there another one that might work better?
matt (author) says: Jul 3, 2009. 9:24 PM
If your sound input is not continuous use a latching relay. This is essentially a flip-flop and a relay combination. Did you already buy relays?
gedion4000 says: Jul 4, 2009. 7:24 AM
no i haven't gotten relays yet. i had actually looked at the latching relay option late last night. from what i can tell you need the charges to be reversed in order to turn it off again, any suggestions on that aspect? i was also not sure of how much input they typically need to switch. the alarm i currently have sweeps from .45 volts to .27 volts. about every second or so, but it beeps really fast so i think my meeter is a little to slow to get a super accurate reading.
matt (author) says: Jul 4, 2009. 10:19 AM
There are many relays available. If you cant find one that has a very low turn on voltage, then buy a transistor with a low threshold voltage, or a low voltage relay. And have it connect a source that has voltage high enough to trigger your latching relay. Then your circuit will look like this: Timer signal--> transistor --> latching relay Yes reverse voltage is needed to switch the latching relay. But for your application, a one time firing confetti gun, nothing matters after its been fired. Just disconnect the power to the circuit and then use it again.
jpoopdog says: Nov 23, 2010. 12:43 AM
heres a better idea, use a signal relay, with the source current (the sound output), passing through a low current high voltage (e.g A23, 12v) battery. signal relays can turn on high voltages with extremely low currents, such as mine which can turn on up to 15V 5A, using a current at least 5V 5ua (thats the next lowest form of miliamps), which is 0.005 or so miliamps. i have tested this instructable with my signal relays and they work fine, i also discoverd, with my cheap digital alarm clock, that on the microprocesor, or whatever the long black thing with all the pins has (i forgto the name), i remember if i shorted the first and second pins on one side while the alarm went off, or begun it with shorted, the alarm beep would be contant, and oddly become increasingly loud also, but only for 20seconds before it stoped.
gedion4000 says: Jul 4, 2009. 11:36 AM
thanks Matt, i didn't think about using a transistor to fire the relay, ill have to work something out like that if i cant find the right latch. i will also have to figure out some kind of switch to reverse the voltage, the cannon needs to be reset within a few minuets to be used over and over again
matt (author) says: Jul 4, 2009. 12:43 PM
Heres an idea for the reset switch: From your battery source run a line, that goes through a push button, and a diode to your relay (make sure its reverse polarity). Then the button will be used to reset it. Also put a diode on the output from the transistor. The diodes will prevent the reverse voltage from going into and damaging your transistor and your power source. Good luck, let me know how you make out.
gedion4000 says: Jul 4, 2009. 8:34 PM
thanks, ill let you know how it goes.
tdwp1122 says: Feb 7, 2010. 12:22 PM
I don't know jack about relays-where did you get it and what type is it?
gizmohalo says: Oct 29, 2010. 5:28 PM
google it
nturner says: May 29, 2010. 3:58 PM
 how do you wire the relay? and can you use the same concept on a two way radio speaker for a detonator?
akinich says: Apr 17, 2010. 2:36 AM
dude i have the same alarm clock
i opened it up and the wire came of from the solder joint
i need ur help
akinich
Minifig666 says: Apr 8, 2010. 9:06 AM
 Leave this thing by the side of the road and the bomb squad will be all over it in second.
dodo101 says: Mar 21, 2010. 2:31 PM
check my kitchen timer video:
http://www.youtube.com/watch?v=gpegSBDOts0
tcm84 says: Jan 23, 2010. 5:39 AM
Wow! That purple touch sensitive explosive glued to the speaker is really great idea!
jsaul2 says: Jan 8, 2010. 7:13 PM
Hello-
Cool idea--- I'd like to use the guts of a digital, or even analog alarm clock to rig an old portable record player to work as a bedside alarm clock. This would have a record play as a wake-up in the morning... I think it may be a bit more complicated to rig the alarm circuit for this, as the device should still have an on/off switch for normal operation, plus an alarm activated "on." Not sure how to go about any of it- this would be my first such project. Any advice or ideas?
russiankid says: Aug 28, 2009. 1:37 PM
well in the picture u dont have a seprate battery for the higher voltage of the personal alarm and that that doesnt look like relay can u help out
Lance Mt. says: Aug 22, 2009. 6:10 AM
Hehehehe, although its not the most original i always had some fun with it when i was younger
Draco6973 says: Jul 28, 2009. 8:19 PM
In this photo you can clearly see a resistor- the dark, cylinder at the top/left -and a small transistor- a smaller dark shape- just below and right of the resistor. It is helpful for you to know the function of these components and how to connect them to accomplish the desired outcome of this Instructable. Don't give up! It can be done!
e-vad says: Apr 26, 2009. 8:36 AM
ok.. i am kinda new to this stuff. and i have worked with some basic wiring but when it comes to a relay i have no clue, so could some one maybe make an instructable or just tell me where to hook the wires up and where they are coming from.
matt (author) says: Jul 3, 2009. 9:26 PM
ronnytehpir8 says: Feb 15, 2009. 7:49 PM
i'd like the alarm to throw a 24 volt sprinkler valve. anyone know how?
mortso says: Mar 21, 2009. 1:40 PM
Hi... You need a relay to fire the 24 v. circuit which can be triggered by the small voltage coming out of the speaker terminals. You would hook the Relay between 3- 9v. batteries connected in parallel and then to your sprinkler valve, using the timer / relay to fire the valve.
http://www.radioshack.com/product/index.jsp?productId=2062479
This relay from Radio Shack should do nicely.
The batteries, while DC, work fine with the AC Sprinkler valves, Just don't hold the button down too long or it could burn out the wiring in the Valve.
ronnytehpir8 says: Mar 22, 2009. 3:38 PM
thanks a million!
mortso says: Mar 22, 2009. 8:05 PM
Sure... I tried to send a diagram but something about formatting stopped it. Good luck and BE SAFE! Mark
DELETED_evilfrogie says: Jul 9, 2008. 8:39 PM
(removed by author or community request)
Azor says: Dec 22, 2008. 10:31 AM
You could add a switch to the circuit and just turn it off. (I think...)
Gavabc123 says: Aug 13, 2008. 2:15 AM
Take the battery out?
DELETED_evilfrogie says: Aug 13, 2008. 10:32 PM
mortso says: Mar 21, 2009. 2:22 PM
A Safety Switch; It's easy to build a switch which MUST be held at angle or it won't fire. Most modern heaters have this mechanism in them, you could steal one from Mom's bathroom portable heater lol, just don't be shocked when it then falls over and burns the house down... It's probably easier to build a contact which to cut the power to the main timer / detonator if the unit falls over. Alternatively, and very VERY cheap, would be to take a reed switch, ( you can make from a tin can ) with springs to keep the switch closed. Then take a plastic "shim" or "connection barrier" and slide it between the reed switch contacts... attach a length of fishing line or twine and the thing can't go off until you pull the plastic "safety" off and activate the circuitry. This allows you to GET AWAY FROM THE DEVICE.
DELETED_evilfrogie says: Mar 21, 2009. 6:41 PM
mortso says: Mar 23, 2009. 12:37 AM
Frogie, You are Right. SAFETY is paramount. This is only a 2nd backup safety switch... the real important switch would be an "Attitude Switch" to stop the timer if the "project" fell over or otherwise got out of true 90 degrees. I just made one out of an "Airborne" bottle... and a lead ball 1/2" and two wires, some electrical tape. It triggers at 50 degrees tip. This makes it possible to have a non vertical launch without mods... but it triggers well dead on at 50 degrees. I'll try to post an instructable but the bloody Airborne bottles have changed... now they have a snap on cap! :—(
DELETED_evilfrogie says: Mar 23, 2009. 11:53 AM
mortso says: Mar 23, 2009. 12:29 PM
You need to check out the Australian Bottle Rocket gang...
http://home.people.net.au/~aircommand/index.htm
These folks have spent a lot of time making Rockets work.
Gavabc123 says: Aug 14, 2008. 12:04 AM
Or that...
DarkTrinity says: Sep 5, 2008. 4:03 AM
I'd say running away would do pretty well heh.
icemanx23 says: Nov 30, 2008. 12:42 PM
I'm from iraq and i would like to ask "can i use this to detonate explosive?' Just kidding.
Armaggedon says: Nov 16, 2008. 12:10 PM
does it work?
jpgg92 says: Nov 6, 2008. 1:28 PM
how would i rig this up to shut something off ?
matt (author) says: Nov 6, 2008. 3:33 PM
use a not-gate (inverter)
omkar_hummer says: Sep 20, 2008. 1:42 AM
can u post a schematic?
nivaneus says: Jun 27, 2008. 3:58 PM
So the way this would make something explode is through the alarm system? Would the alarm generate enough energy to set off a fuse?
PyroManiac96 says: Jul 29, 2008. 10:56 AM
if you want to set off a fuse, use the process using nichrome wire in the last step. in this case, you would take out the alarm and replace it with the nichrome wire unit.
nivaneus says: Aug 5, 2008. 9:46 AM
Alright thanks.
jordanbrooks97 says: Jul 31, 2008. 6:01 PM
how would i wire to something like this but without a fuse
tippmannphreak says: Apr 23, 2008. 7:56 AM
I want to run into a mall with that piece hanging out of my backpack screaming "allah akbar!!" haha. I would never do that though. just thought it was a funny thought so i wanted to share it. De ja vu. wow. amen.
mannys9130 says: Jul 4, 2008. 12:37 AM
hahahaha so true. You WILL get shot if you do that. it would be funny if you actually rigged up a small charge, like a little firecracker, and let it out. would scare the crap out of people who saw the timer and saw you run down a hall or behind a corner, and then the timer went off denotating the little cracker. they would take a dump in their pants! and then homeland security would make sure that you "disappeared" without a trace. or maybe they would knock on your door and confiscate, your... egg timer, hahahahaha
Toni the rocketman says: Feb 14, 2008. 10:12 AM
yeah,where!?
spinach_dip says: May 15, 2006. 3:20 PM
I'm looking to cannibalize the mess of broken electronics in my attic, and need a suitable relay. Any idea where I might be able to pry such a model out?
ElectrodeMike says: Jun 11, 2007. 5:07 AM
Can I have some dip?
maker12 says: Nov 28, 2007. 9:06 PM
NO. oops i mean yes
ElectrodeMike says: Jan 10, 2008. 9:46 PM
so ur the new spinach dip?
maker12 says: Nov 28, 2007. 8:59 PM
LOL ROFLCOPTER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
curlyfry562 says: Feb 15, 2007. 9:27 PM
they have tons of cheap relays at
http://www.allelectronics.com/cgi-bin/category/500/Relays.html
My favorite electronics site
cpf says: Aug 10, 2006. 3:18 PM
Problem- With relays and a piezoelectric beeper this wouldn't work. The way the IC in the clock makes the piezo beeper beep is to send it effectively AC, and as you probably know, relays don't like AC.
James (pseudo-geek) says: Sep 17, 2007. 7:01 AM
actually that would be a pulsed DC, a little different from AC. all you need is a capacitor to smooth the signal out. in the event that is actually IS AC, the hook up a full-wave bridge rectifier (that has a name that makes it overrated) before the capacitor.
Ian01 says: Feb 24, 2007. 12:34 PM
Couldn't you use an AC relay?
James (pseudo-geek) says: Sep 17, 2007. 7:02 AM
no such thing. however, you could build a bridge rectifier, hook it up with a capacitor, and you'd be set.
klee27x says: May 26, 2006. 11:42 PM
Who needs a relay? What's wrong with a transistor?
cpf says: Aug 10, 2006. 3:21 PM
I dont think transistors would work either (see post below).
James (pseudo-geek) says: Sep 17, 2007. 7:03 AM
yes, a relay would word.
abend says: May 15, 2006. 6:38 PM
There is a low voltage relay in a lot of phones and modems. It is usually near the connectors for the phone line, and usually about an inch long. Other than that, it's a bit hard to describe, since it varies from phone to phone.
CameronC says: Aug 18, 2008. 12:47 AM
dude i got a 12v relay from radioshack yesterday for like $6
matt (author) says: May 15, 2006. 7:12 PM
I pulled a relay off an old fax modem, but you can just buy one from an electronics shop....... you can also use a transistor depending on what you want to accomplish.
spinach_dip says: May 15, 2006. 7:18 PM
Thanks! Now all I've got to do is find a screwdriver...
ElectrodeMike says: Jun 11, 2007. 5:08 AM
Screwdriver so you can reach the Dip?
maker12 says: Nov 28, 2007. 9:02 PM
OMG YOU ARE FUNNY!!!! LOL
ElectrodeMike says: Jan 10, 2008. 9:45 PM
huh? sarcasm?
Demented says: Dec 4, 2006. 7:23 AM
What am I supposed to detonate actually? And where do I hook up the wires of the explosive?
nkk07 says: Jan 4, 2008. 7:15 AM
its not HOW TO MAKE A BOMB instructable work it out for yourself
isnowhere says: May 15, 2006. 4:50 AM
its a couple of steps better than the knife or distillary... surely its aims are to find IPs of people who want things to go akaboom like all those previously blacklisted litrature items, by idealistic argentinians
maker12 says: Nov 29, 2007. 3:18 PM
wats "akaboom" LOL!!!
matt (author) says: May 15, 2006. 7:14 PM
Is it just me, or does this comment not make sense at all?
vrogy says: May 17, 2006. 1:57 AM
Where is akaboom anyways?
splat says: Jul 4, 2006. 2:05 PM
I think he ment kaboom
Rasmus0103 says: Nov 18, 2007. 8:15 AM
I can think of a problem that can ruin it. Most timers beep when a button is pressed of when its less then 10 sec left and if you connect it to fireworks it will detonate in your hands. Is there a electronic part that stops a current until you send another current in it and then sends it on?
Lithium Rain says: Mar 4, 2007. 3:30 PM
question: how would you defuse this? like if you hooked it up and then had second thoughts?
lemonie says: Mar 6, 2007. 4:56 PM
Cut the blue wire.
Lithium Rain says: Mar 14, 2007. 8:28 PM
Oh, okay. Is that supplying the power or what exactly does the blue wire do? Just wondering. : )
lemonie says: Mar 15, 2007. 1:50 PM
Step 3: the output to the piezo (blue) is used as the trigger in this device.
Lithium Rain says: Mar 17, 2007. 8:46 PM
Interesting... Is that the same principle you would use to de-fuse a bomb? Disconnect the trigger (I'm feeling slightly James Bondish today!) ? :)
James (pseudo-geek) says: Sep 17, 2007. 7:06 AM
movie-bombs are stupid. the hero always has to decide which wire to cut. its VERY VERY VERY simple. cut the wire going from the detonation device to the actual igniter. (I.E. nichrome wire, blasting cap, you name it.) or you could just pull the igniter out of the explosives themselves.
jongscx says: Oct 14, 2007. 7:43 PM
True... but if I were building one that I knew was going to be found, I would make put fail-safes against that... -have the timer turn OFF the normally closed relay... anyone cutting the wire would make it explode -install a secondary igniter that will detonate when someone touches the first one (ie pulling the igniter out) but, thats' IF I were building one...
cowscankill says: Oct 26, 2007. 6:43 AM
lol IF i were building one, i MIGHT use this idea.
Lithium Rain says: Oct 3, 2007. 3:53 PM
Oh. I think I understand now. Thanks!
Bubomb says: May 30, 2006. 10:18 AM
Its impossible to tell tone of voice when you read a post like this on the internet, so I just wanted to say this ahead of time. This isn’t an angry rant. it’s a disappointed one… I think its sad how much we have forgotten about our own rights over the past few years. Every one is going so over the top with this terrorist stuff that we’re afraid to take a piss any more. We forget we have the right to say or write about whatever we want. Its Pop-culture that looks down on words like “electronic detonator” you wont get arrested for mentioning it. Theoretically I could post a How To on making a doomsday device that targets politicians and presidents and be in no trouble at all until I actually made or threatened to use one. As for this timer, this is nothing. I am a member of the Western Pyrotechnics Association and can tell you from first hand experience that devices like this are used during the most patriotic holiday of all; the 4th of July. The person who posted this project puts himself in no danger. Especially when you consider the fact that there are places on the internet that tell you how to make the explosives that would actually do any damage and even those cant be taken down until they meet incredibly specific criteria or your lawyer sucks. ;p
cowscankill says: Oct 26, 2007. 6:41 AM
since you're a member of the Western Pyrotechnics Association, i was wondering if you can help me with my detonatar, which has a timer, awesome for large mortar fireworks.
You can here, please, because i would love your help ;)
James (pseudo-geek) says: Sep 17, 2007. 7:10 AM
agreed. in fact it actually kinda scares me that this all is common knowledge.
jongscx says: Oct 14, 2007. 7:45 PM
Actually, what scares me is that it ISN'T common knowledge... how hard is it to wire a timer to a relay to trigger something else? and yet, if you ask someone on the street, they would be dumb-founded... But I won't get into a rant about the US education system... this isn't the place.
James (pseudo-geek) says: Oct 27, 2007. 4:38 PM
I meant it is common knowledge among hobbyists. I agree that more people should know how to work with electricity, but less should know how to make explosives out of household items.
the_pb_junkie says: Jul 1, 2007. 12:22 AM
hey can a wireless dorbell work to set off a fuse???? thanks
James (pseudo-geek) says: Sep 17, 2007. 7:07 AM
yes. quite possible. but you'd either have to have some with some expertise in electronics do it, or show them an exact diagram of the doorbell circuit and have them tell you what to do.
uzerzero says: Aug 13, 2007. 5:47 PM
Could you break open a lightbulb and pull the filament out and use that as an ignition wire, as a substitute for Nichrome wire? They both will heat up when a current is passed through them, although I don't know if the tungsten filament is hot enough to actually light something on fire. Just curious before I crack open a bunch of lightbulbs in pursuit of this theory.
James (pseudo-geek) says: Sep 17, 2007. 7:00 AM
seems possible. however, you can get nichrome wire out of any appliance with a heating element....curling iron, hair dryer, toaster, you name it. you want the wire that turns red when the appliance is on.
nikielectronics says: Sep 8, 2007. 2:19 AM
how to detonate?
roachmatt says: Mar 25, 2007. 8:27 PM
Would the wires from the alarm clock have enuf powere to detonate an explosive? Maybe if it was atached to the devices you place in the model rocket engines that detonate it?
ElectrodeMike says: Jun 11, 2007. 5:06 AM
Honestly did you read it??? You conect it to a low volage/low current relay. Then use the other wires of the relay to switch a higher voltage(4.5v) _
HOMEPIE64 says: Mar 9, 2007. 2:23 PM
this would be awesome to hook up to fire works on 4th of July
zecandyman says: Oct 6, 2006. 1:48 AM
i love the way he says "carefully smash open"
j.w_lewis says: Sep 26, 2006. 9:58 PM
haha im gonna put one in my class at school
rudybaylor says: Aug 6, 2006. 7:00 AM
I tried to do this earlier this summer before viewing this page... to no avail. The problem is that you cant just buy any timer. You must have gotten lucky with your timer, because the cheap 5$ timer I bought didn't put out enough current to do diddly squat with. Get this: it put out such a low current that adding any sort of connection (wire, relay, or transistor) between the leads of the buzzer would actually turn the timer off. It would reach zero, and turn off. Very frustrating. This is a simple idea, but not very reliable. I'm building a timer using a 555 timer circuit which is MUCH more reliable. Maybe I'll post when I'm done.
ll.13 says: Jun 1, 2006. 1:53 PM
yo people take a chill pill it is not worth getting worked up about
trekinhipe says: May 30, 2006. 2:23 PM
I agree completely with the 'pro info' posters, in factI have used similar detonators in one of my ex-hobbies...High powered rocketry as second stage ignitors and recovery 'chute ignitors, as well as the sonic alarm as a recovery device for finding my rockets in trees and large fields. One of the reasons it's an ex-hobby is that BATF is now requiring explosives use permits and fingerprinting in order to buy some of the larger motors and chemicals needed to 'roll your own'. It used to be a hobby, and now it's gotten to be a BIG hassel and no fun anymore. But, that being said, you can find all kinds of information on any one of a million rocketry sites on related subjects. If you think the 'terrorists' don't already know all this, then you're living in a dream world.
bildnething says: May 28, 2006. 6:15 PM
just to let you know..incase you didnt catch this...your essentially taking apart and alarm clock to make another alarm clock...lol...i like the bomb ignition better...spend your time writing bout that then i'll come back
saites2001 says: May 29, 2006. 11:54 PM
But it's a louder alarm clock :) . . .
saites2001 says: May 14, 2006. 8:26 PM
Is it really such a good idea to post bomb instructions (step 4)? Interesting article, though.
xsmurf says: May 14, 2006. 10:49 PM
Would this project be any different if he was hooking up a relay & toaster to the clock? Not at all. Science really isn't about what it is, but what you make of it! If your stupid enough to make a bomb, then I hope you blow yourself up trying. There has been instructables about phone bugs and other potentially malicious stuff. They do all share one thing in common, they were posted for the sake of discovering how stuff works. This project is not different, imho.
godsdog says: May 14, 2006. 11:57 PM
Agreed...Technically, this is no different than posting instructions on how to sharpen a knife, or how to make your own micro-distillery (anyone...nudge, nudge...) It is what you make of it.
jcrae says: May 24, 2006. 11:45 PM
www.homedistiller.org (the Bible of hobby distilling)
saites2001 says: May 15, 2006. 3:49 PM
Point taken.
stourleyk says: May 23, 2006. 11:50 AM
"Is it just me, or does this comment not make sense at all?" -It's just you. See comment below. "Where is akaboom anyways?" -Playing stupid doesn't make your point of view accurate. "this doesn't carry the current needed to fire off an Estes rocket, much less what you are freaking about." -Just plain wrong. "if you want to go muckin' around with fertilizer and sulpher it's your own silly fault" -And the fault of those who aided and abetted you. "Get real, this is such a non-issue. This project is so obvious anyone who couldn't figure it out couldn't make an explosive device to hook it to anyway." -If it's not an issue you wouldn't have posted. And if the project were so obvious it wouldn't have been posted, either.
jridley says: May 17, 2006. 4:45 PM
Get real, this is such a non-issue. This project is so obvious anyone who couldn't figure it out couldn't make an explosive device to hook it to anyway. Hell, I built a more complex remote detonator than this for a prank at my high school graduation, and it only took about 10 minutes.
jridley says: May 17, 2006. 4:54 PM
BTW I wasn't ragging on the project, it's cool. I was talking about the people who somehow think this is going to enable terrorism. Yeah, because everyone knows that terrorists are too dumb to attach a low voltage relay to a clock without instructions.
Elcubanito says: May 16, 2006. 2:21 PM
Someones going to get a Anal Exam from the FBI!
xsmurf says: May 17, 2006. 4:49 PM
The polite way to say this would be "Full cavity search"!
davidh says: May 16, 2006. 11:07 AM
What next - mix your own explosives? Ever seen what a home made bomb can do to a subway train ?
jtobako says: May 16, 2006. 9:29 PM
explosives are easy, detinaters are difficult-and this doesn't carry the current needed to fire off an Estes rocket, much less what you are freaking about.
ll.13 says: May 17, 2006. 2:46 AM
jtobako absoloutly old boy and anyway if you want to go muckin' around with fertilizer and sulpher it's your own silly fault.(there are a lot of decent pyrotechnic websites around (but it's up to you to find them) ) This guy was only stating what the detonater MAY be able to do (he only posted it for the public interest (weel i think so but i may wrong))
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
