3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a cool hologram illusion!
Step 3Display Setup
Display Setup
To keep from giving away the source of the image, adjust the brightness to the lowest setting and the contrast to the highest.
The goal is to make the background as dark as possible. Play the movie you want to use full screen, then adjust as needed.
For the cabinet configuration, suspend the LCD monitor above the viewing area. Then create a Halloweenish looking scene inside, and then place the glass over it at an angle that will reflect the image to the viewer.
For the windows configuration, set the monitor on the floor pointing up, create your scary scene, then place a much larger piece of glass over it at an angle that will reflect the image towards the window.
In either setup, the bottom edge of the glass should be as close to the bottom edge of the monitor as possible. That will make the image float in front of your scene, instead of behind it.
Adjust the angle of the glass to control the height of the floating head.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
96
Author:NK5
