loading
loading
Picture of Make a dazzling Butterfly Crystal Ring
Make this dazzling Butterfly shaped Crystal Ring for a friend or for yourself, astound yourself. Follow the easy steps to make this Crystal Ring. Made with Czech crystals on the base and the top made with Swarovski Crystal beads on top, see some of my other instructables for different version like the heart-shaped Crystal Ring.
Step 1: Items needed to make this Butterfly Crystal Ring:
Picture of Items needed to make this Butterfly Crystal Ring:
14-4mm Czech Beads (I used a bigger size for the example)
12-4mm in burnt orange Swarovski Crystal Beads (a)
6-4mm in lime green Swarovski Crystal Bead (b)
4-4mm in a dark shade of orange Swarovski Crystal Bead (c)
Seed Beads
Nylon thread in 0,20mm thickness or in fly-fishing line
2 Needles with big eye
Hypo-cement or glue
Step 2: Base of Butterfly Crystal Ring
Picture of Base of Butterfly Crystal Ring
1. Thread 2 needles with nylon thread; add 3 Czech beads on, crossing through the 3rd bead with both needles.
2. Add 1 Czech bead on each needle, cross through the bottom one with opposite needle.
3. Add 1 Czech bead on each needle again, cross the needle on the outer edge through the bottom bead.
4. Add 1 Czech bead on each again, threading opposite needle through same side as above that bead. Now repeat all the top 3 steps reversing, so it is identical to left hand side.
