Material list:
-dorm/bar fridge
-base from slow cooker/crock pot (found at dump)
-110V fan (though a 12V should work as well but then you'd need a power supply as well)
-thermostat assembly from an electric stove (found at dump) (save all the screws you take out to get the back of the stove and use them to mount the shelves etc.)
-neon indicator lights from same stove
-racks/shelves from old stove/fridge
-piece of aluminum angle cut into +/- 1" pieces for rack hangers
-on/off switch (a regular house light switch would work as well, but not as cool..)
-misc. wire, crimp terminals and wire nuts and misc. fasteners
-Mylar sheet/aluminum foil
-aluminum tape, duct tape
-screen material to cover vents and lay on racks
-And of course, some fruit to dry
Tool list
-wire strippers/crimpers
-screwdrivers
-drill, bits, holesaw
-utility knife
-And most important, basic common sense and the humility to ask for advice when needed.
Step 1: Remove freezer and controls
Cut around the door shelf to remove it and using a fishing wire leader or piano wire or a guitar string slipped in through the cut at the top, saw downward and cut the foam and remove door shelves.
Step 2: Install on/off switch and indicator light
I cut the inner plastic skin of the fridge with a knife, cut the foam with the hole saw then drilled the metal shell for the switch and the indicator light.
The switch is held in by a nut on it's shaft, the light clicks on to the inside of the indicator lens.
After mounting the switch etc. drilling through the foam from the back for the wires, I covered the switch back up and sealed the cut with some aluminum tape.
The wires run down to the base in back in a groove cut in the foam.
I covered the vent holes with some copper screen I had then duct taped the cover back on the foam on the back.
Step 3: Install fan and heating element
Step 4: Wiring in fan and heater
The wiring goes like this:
-the white from the power cord is wire nutted to the white of the fan, one wire from the heater, and to the indicator light.
-the black from the cord is tied into the wire to the switch which comes back down and (1) wire goes to the center terminal of the thermostat, the other switched wire goes to the black on the fan.
-the green/ground wire is re-attached to the base of the fridge.
I drilled a hole in the edge of the cabinet and zip tied the wires to make it all neater.
Step 5: The finished product!
I covered the door with some sticky back Mylar sheet I had around (doesn't everyone?), though I suppose one could use tin foil. After the test run, the heat had unstuck the sheet, so I'm glad I'd cut it big enough to tuck under the door seal. At some point I'll have to tack it down with something: stainless, aluminum or plastic as it is quite humid in there!
My first load was guava and pineapple, the second was bananas and the third shown here was pineapple and bananas. YUM!
I need to do some more R & D. I may add a second fan to vent the moist air, though I'd hate to lose the heat as well....I may use PVC pipe and run it back down to the lower vent hole with a Tee so that the warm air is drawn back in but the moisture which has condensed will drip out (not on the wiring, tho' !)
Visit Our Store »
Go Pro Today »
I intend to remove all the electrics, compressor etc. and install a 12v system comprising two 12v automotive lamps, a fan and a thermostat. I can then hopefully use this as a drying Jerky/Biltongbox.
I'm also considering adding an inlet pipe to connect an external smoke box to make this also useful as a cold smoker.
The moist air is actually bad for the process too - even 'finished' foods from this set up might grow mold if not eaten quickly after processed, due to the moisture.
A good way to do meats is to marinade/dehy at 140/155 F for several hours (dependent on the meat) then put into a preheated oven (275F) for 10 minutes, and then let cool to room temp. This dries your meats (jerky, etc) and then makes sure the internal temperature reaches 160F to kill any bacteria that could harm you later - as well as "finishes off" any lingering moisture.
