3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make electronic widget frames from old computers
Step 3The software
The software
  • last photo ←
I use a boot floppy disk to run the computer, because it is the only way to boot the laptop that has no more hard drive. I wrote a small program in QBasic to animate the clock and that starts at boot time.
You can see the result here
To use the provided file, you need to create a boot disk with the format wizard of your floppy drive, remove every file and replace them with the files contained in the zip. Then restart your computer. Check for virus first, you use this software at your own risk. There will be no problem, but I recommend you only use this on a computer with no important files. I will not be responsible for problem you could have with this software. This is for non commercial use only. Feel free to contact me for feedback...
I finally found the sources, on my previous computer... enjoy
12 comments
Aug 31, 2009. 12:58 AMemilsegna says:
Can i boot the "program" from an cd? First download clock.zip then unpack it then move the folder to the cd? or what... i only have 1cd left and the laptop has no floppy
Jul 23, 2009. 7:22 AMrensjuuuh says:
Is this program in English or in French??
Nov 27, 2008. 7:21 AMrotamagic says:
great job.... is there anyway to change the settings besides BIOS?
May 4, 2008. 6:43 AMyeddi says:
I've taken the HDD out and tried booting up with my floppy but get the error message: Erreur: un gestionnaire de mémoire étundue est déjà installé. Le pilote XMS n'est pas installé. And the computer just sits, I can't seem to do anything. Any Advice? If it matters: I created the disk with Windows XP and it is a Toshiba 1730 notebook. Also: I had Linux installed on the laptop, but since I removed the HDD I can't imagine that's an issue..
May 6, 2008. 1:32 AMyeddi says:
Okay, I managed to get it working:
I used the Windows 98 bootdisk from http://www.bootdisk.com/bootdisk.htm instead of the one that I was creating through my OS (XP) Everything now works. However, is there any way to adjust the time and date or do you have to do that through the BIOS?
Dec 8, 2007. 7:41 AMtopsycrets says:
I tried to run the file in an old compaq 1220 lap top, which doesn't have a hard drive and all I got was CHGE BIOS ( CHanGE BIOS For_ What do I do next? Frustrated I put the floppy with this downloaded file into a toshiba satellite 100CS which I never knew what was wrong with it in the first place it just shows the MS Windows '95 logo, but when I put the 3.5 floppy disk in I get the following CHGBIOS (CHanGe BIOS Utility for TOSHIBA) V5.10 Erasing and writing BIOS Data Please push the RESET SW (or turn AC power OFF/ON) to restart ROM Write Successful! Utility finished! BIOS ROM : 100 V5.30 FIOS File : 100 V5.30 I have to let you know that when I was given this particular lap top I could never get it past the MS 95 windows logo, so I can't get to any programs or other functions, Can anyone help so that I may load the Clock file described herein?
Nov 25, 2007. 4:24 PMMr.Fun says:
the software you have on here, i put it on a floppy and booted from it and nothing happened? any advice? Thanks
Nov 28, 2007. 3:39 PMMr.Fun says:
Thanks for the advice ill try Mr.fun ;-)
Nov 14, 2007. 9:46 PMEmperor Dane says:
when you slide your hand behind the display, what are you pressing to change display modes? awesome work! -Dane
Nov 11, 2007. 7:16 PMWallaceTheSane says:
QBasic RULES. You are my brethren.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:tonypascal
