That's it, it couldn't really be simpler than that!
What you'll need:
- One hen's egg (free range) (or larger egg if you have it, duck, goose or even ostrich)
- Glue gun and a small amount of hot melt glue
- Spray paint, any colour will do, but black, red, green, gold or silver are the best
- a little bit of acrylic paint, for the distressing (black or dark brown)
It's a great project for Easter, or any other time of year when Dragon Eggs are in season.
Remove these ads by
Signing UpStep 1: Make a hole in either end of the egg
Please use free range if you can... help chickens have a better life. Don't worry about the waste, There doesn't have to be any. Once you have blown the eggs, you can always make scramble or an omelet from the contents of the egg.
So, first off, wash the egg quickly in cold, slightly soapy water. In a minute you are going to be putting your lips to that egg surface and you know the last place that egg was !!
Now, to making the hole; strangely, this is not as easy as it sounds. For those of you with Dremmels, or miniature drills, (or dentists even) then this should present no problem, but for mere mortals, the egg is surprisingly hard, and being... well, an egg shell, is also quite brittle.
To make the hole you get a very sharp craft knife. Put the point of the tip of the blade against the tip of the egg at one end and turn back and forth about 180 degrees each turn. You'll find it seems to take ages to get started. Don't be tempted to push to hard or you will break the egg. If you feel that you are not getting started, then carefully scratch a cross at the end and put the tip of the blade at the centre of the cross and go back to turning it back and forth.
Once you break through the going gets easier, but you still have to take care as the blade can bite in and chip or crack the egg. If you are patient (only 5 minutes or so of turning) then within a few minutes you will have a hole about the size of a drinking straw. In fact you are aiming for a hole, the diameter of anything between a cocktail stick and drinking straw. Don't worry if you do chip a little bit away, you will be covering that up with hotmelt in due course.
Make a hole like this IN BOTH ENDS.
Visit Our Store »
Go Pro Today »
What a nice job!
more on that. Being an ignorant in this matter: Dragon Egss.
Finally, I think I comprehend why the female dragons are so bad tempered!!!... :-)
Please, keep the good work!
This was an awesome Instructable. The idea itself is fantastic, and the instructions are stellar. Love your illustrations; you really make everything easy to understand, and that is a rarity in an online how-to!
I made (I mean found) a handful of eggs for my boyfriend's birthday a few weeks ago. One for each of the chromatic dragons in Dungeons and Dragons.
I used spray paint for the base coats, acrylic for the distressing, and nail enamel for the highlights. Also, I glittered the black and white eggs with coarse black and iridescent white for a little texture and interest as they didn't have quite as much contrast as the coloured eggs.
I really enjoyed making them, and my boyfriend loved them, though he says he's a little nervous that they might hatch in our lifetime. ; ) We have them displayed on the mantle, and they are too nerdy and cool for me. Thank you!
I used paper covered plastic eggs I purchased from a craft store. Paints are acrylics and I used puffy metallic paints for the silver gold and copper. I coated these in brush on glaze. I liked that I had much more control over the color by hand mixing and painting.
Thank you!!
Thanks
he wants mony ^^ v
http://craftsandcreationswithkathy.blogspot.com/2009/02/dragon-eggs.html
If you put WD40 on it, you can correct that by washing it off with white spirit and then detergent and warm water, let it dry and then spray it.
Cheers
That is tinfoil all scrunched up on a Cookie tray. With toothpicks (3 of them) holding up the egg in such a way that none of the hot glue is touched. Set it in your preheated oven, let it cook for a few minutes, or until the the glue has soothed out. Then turn off the oven Do not move the egg or touch the tray Let it cool before it you move it. Then paint it to perfection.
However, I did notice that this is copied directly from the dadcando website you linked to. Are you the same Chris Bernardo who owns the copyright to all these images? Just checking...
I'd love to see an instructable on how you make those beautiful illustrations though! :-)
Happy Dragon's egg making
Is there anything you can't improve with the addition of hot glue? ;)
