Step 2Blow the egg
The whole blowing part is a good job to get the kids to do (a bit of at least), anything from about 8 -9 years old or onwards should be fine.
Collect the white and yolk in a suitable bowl or jug, and save for later conversion into scramble or an omelet (probably best if you do this the same day and once you have blown all over the egg yolk and white, I'm not sure how long it will keep). Also (not to be gross, but) all that blow / spittle that you might have got into the mix as a byproduct of all that blowing, might preclude the serving of said scramble to guests outside the immediate family!
Once all the egg white and yolk is (rather cathartically) evacuated, run the egg under the cold tap to clean out the inside as much as possible. If you can, it might be worth filling your mouth with water and blowing that through the egg. You don't want it getting smelly. I have to say that I have never had an egg prepared like this go bad.
comment
Add Comment
Add Comment
