3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a great heat pack for a quarter.
After watching my mom and sister spend $12 a pop on those store-bought disposable heat pads and around $30 or more on various gimicky microwaveable reusable ones, I stumbled upon this idea while marveling at how MUCH pee my nephew's diaper held.
A bag of 40 diapers costs about $10, so you will be spending about $.25 each. You can reuse these a couple dozen times easily, so figure on a penny per use (not including any energy cost for running your microwave, of course). Not bad, when compared to the $12 for one or two single-use disposable hot pads at the drugstore. These retain thir heat for a couple hours.
Step 1What you need:
What you need:
A clean, dry disposable diaper and a good sturdy freezer bag.
27 comments
Feb 25, 2012. 8:17 AMthriftynursewife says:
I love this! I'm using it as we speak! I thik I have acute sinusitis and since its the weekend the doctors office is closed, so I started looking up moist heat packs for home remedies and I came across this! It is really helping with my pressure and tooth aches! Thank you for sharing!
Feb 29, 2008. 2:44 PMDalya says:
Can I use a disposable pad? Well they are almost the same thing..but I'm wondering.
May 9, 2009. 10:07 PMPhixius says:
They actually do have gel. I learned this just recently when my water broke! Also, you can just buy the gel alone in most garden centers. It is called soil moist. The container may not look big, but it only takes a very small amount to puff up a LOT! I made neck coolers with these that just tie around like a necklace. For that project I only use 2 tsp. of the granules and it fills up the cloth. You can soak them in cool water and it keeps you cool while you work outdoors in the summer.
Oct 4, 2010. 7:41 AMPhixius says:
Well, I'm going to go ahead and point out, even though this was over a year ago now, that this comment was made by my wife who apparently didn't realize she was logged in as me. My water has never broke. I don't even have a "water".
Mar 29, 2008. 12:53 PMDalya says:
Disposable pads do have the same gel inside. It's like a powder at first, but then it turns into gel when wet. It's a very weird and toxic material. Some babies are even allergic to disposables, then they have to use cloth diapers. Heck, it's why a lot of women now converted to cloth menstrual pads. Lol. I'm one of those converts. heh! Thanks, I'll see if I can try :D
Oct 1, 2009. 9:30 AMjauncourt says:
Actually, babies are often allergic not to the gel but to the the scents used to cover the plastic smell of the shell material, or their skin is irritated by the "clothlike" material or by the non-breathability of the plastic shell materials.
The gel is really benign ... unless you eat or inhale it. Even skin-to-gel direct exposure does nothing more than dry the skin slightly. It eventually breaks down in normal environmental conditions, but the shells of these items (both the spun "cloth" material and the nonpermeable plastic barrier) do not.
Most women I know who have chosen to use cloth for babies or themselves have done so for environmental and cost reasons, because disposable options are both expensive and wasteful. These are much more compelling reasons to me that scaremongering about the absorptive material.
Jul 18, 2009. 10:36 PMporcupinemamma says:
I have surgery coming up. I know I'll be in pain. I'm going to try theidea in the cold form. clever Idea. thanks for sharing. Well done
Apr 16, 2009. 8:49 PMAzureEyes says:
I'm curious to know if you can reuse these, i would imagine up to a certain point, and yes considering that it would take a while for these to decompose, on another instructable is that you can take the filling out and put them into potted plants to help retain the water in the pot and use less water to keep it moist. : D there you have it...lots of ways to save money.
Oct 22, 2008. 4:49 PMbrabantia says:
Cunning plan! I've been looking for something less silly than the gadgets your mom fell for. I'm a bit concerned about using diapers though, it seems they take decades to decompose ...
Apr 8, 2009. 9:50 AMsarahfish says:
You can also use rice to accomplish the same goal... in fact, I think I'm going to instructable that tonight! Keep an eye out!
Apr 4, 2009. 9:45 PMaklyatne says:
The gel inside of disposable diapers is a kind of polymer that absorbs the water and then expands, forming a gel. Water does have a high specific heat capacity, but it's not the highest - not by a long shot. When heated, the water inside the gel heats up and the polymer insulates the water and keeps the heat in for a longer time - a side effect of this is that it keeps the gel at a decent temperature for a long time, and it's harder to burn yourself with it. It's close to the same as what commercial ice/heat packs do, but it evaporates, which is why it's a lot cheaper and less widely used.
Feb 14, 2009. 8:37 PMissaandbri says:
Can this be reused? If you let it dry out can you wet the gel again?
Mar 10, 2008. 6:38 AMworldhq101 says:
Hey Ms Rupa, what a clever idea ! I have lower back pain a lot and this seems to be just what I need ! You could use this same technique for a cold compress as well couldn't you ? . . . maybe use refrigerator instead of the freezer to keep them pliable. Whq101
Oct 1, 2008. 5:03 PMmakalove says:
I used to be a homebirth midwife, and we would have our clients soak a few large menstrual pads in water and freeze them in a "cupped" shape to use as icepacks perfectly suited to what they needed them for. This worked great and we got lots of thank-yous for the suggestion. Since diapers and most disposable pads have the same gel filling, it should work just as well. They do freeze pretty hard, but leaving it out on the countertop for a little while softens it up enough to be comfortable.
Apr 19, 2008. 3:20 PMsafyrmwn says:
Yes this is an excellent way to make ice packs also. The technique is basically the same except that I use 1 cup distilled water, 1 cup denatured alcohol, and 1 cup liquid dish soap. Freeze instead of microwave. The alcohol and dish soap keep the contents nice and pliable even after being frozen. Stays cold much longer too.
Mar 19, 2008. 4:59 PMiq_abyss says:
Someone aught to put some of this gel in a calorimiter and find it's specific heat (I'm guessing it will be above °C = 4.186 Julie/gram). It would be interesting to see the data (analyzed as well as raw.---I don't have the equipment otherwise I'd do it myself and post the data.....(I wish I had some funding :-(
Feb 9, 2008. 10:27 AMjoejoerowley says:
Cool! Thats a great idea! Well done. Kind of like a hot water bottle.
Feb 29, 2008. 3:55 PMjoejoerowley says:
Thats interesting, water has one of the highest specific heats around.
Feb 9, 2008. 1:04 PMGorillazMiko says:
Actually a smart idea. Very nicely done Instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:rupamagic
