Step 1:
Using the carport's shape, cut wood to fit the frame. Most of the wood was from 2x6's cut in half long ways (ripped).
Although I used 2x6's across the front and back because it is a 9 foot span, since the window frame would support it, you could use smaller lumber instead. I used a 4x4 I had laying around for the side with the door. The ground here is at an angle and I wanted to be able to step on the door sill without it bending too much. The window frame is from 2x2's.
The 10 foot wide plastic fit perfectly with just a little trimming.
Remove these ads by
Visit Our Store »
Go Pro Today »
Unfortunately i just moved house to a new property and left an identical carport next to the rubbish bins for pickup.... and now we need a greenhouse!
Looking at the costs of purchasing a new greenhouse, using a carport frame as the skeleton shows a lot of ingenuity, i had a feeling it would have been worth saving our old one.
Also, although I don't know much about them, occasionally I see great deals on greenhouses from Harbor Freight that might be worth looking into if you have one nearby.
Good luck and thanks for the nice comment.
Good luck with your project. I love how mine turned out.
Lynne
I need a greenhouse at home myself, so this would be just the ticket, assuming I can find the necessary tubing. Thinking about it, if you found an old frame tent, that would work just as well I think? (Although that particular style would need a larger floor space than your design)
