Remove these ads by
Signing UpStep 1
Using the carport's shape, cut wood to fit the frame. Most of the wood was from 2x6's cut in half long ways (ripped).
Although I used 2x6's across the front and back because it is a 9 foot span, since the window frame would support it, you could use smaller lumber instead. I used a 4x4 I had laying around for the side with the door. The ground here is at an angle and I wanted to be able to step on the door sill without it bending too much. The window frame is from 2x2's.
The 10 foot wide plastic fit perfectly with just a little trimming.
Good luck with your project. I love how mine turned out.
Lynne
I need a greenhouse at home myself, so this would be just the ticket, assuming I can find the necessary tubing. Thinking about it, if you found an old frame tent, that would work just as well I think? (Although that particular style would need a larger floor space than your design)
