Make a huge printable poster from your iTunes album art!
This is a instructable describing how to cumbersomely export your existing iTunes album art and arrange all the covers into a huge grid, leaving you with a gigantic, colourful and vibrant mishmash of popular culture ready for printing and, maybe later, your wall!
I decided I wanted to do this a couple of nights ago and now I've come up with a method, it's not really complicated but can be rather time-consuming depending on how large your library is.
I have around 800 albums with attached album art and it took at least an hour, granted most of that time is spent watching your computer doing all the work for you.
The process requires you to download some free applications (links supplied) and you also need a new-ish version of Photoshop (I use CS3) although I'll show you an alternate way of getting basically the same results with Google's free digital photo organizer, Picasa2.
So, for Windows only at the moment, but I'm sure some Mac user can come up with an easier and cooler way to do this. Damn you, I'm switching soon anyway.
More advanced users can check out Step 7 right away for a quick rundown.
Step 1Locating your iTunes album art
First we need to make sure you actually have some album art to work with.
There's several ways to go about this; you can import the covers automatically from the iTunes Store or you can painstakingly do it by hand for every album.
- Automatically
- By hand
I imported all mine into iTunes by hand, partly because I'm kinda picky and want them all the same size but mostly because I listen to weird electronic music that's just not available in the iTunes Store, forcing me to find the cover art from Discogs.com, Google image search and elsewhere.
Anyway, I will assume you have at least some album art in iTunes (the more the better) and move on.
So let's locate the images on your computer.
The problem, and the one thing that makes this instructable even worth sharing to begin with, is that the images are not readable by Photoshop as is and that they're all spread out into hundreds of strangely nested folders with strange names.
Therefore, we need to decode them and copy them all into one place.
The default folder for your artwork should be in "My Documents\My Music\iTunes\Album Artwork\Local"
If you can't find it there just do a search for the folder "album artwork" on your C: drive.
If you navigate around a bit from here you'll notice that it's very messy, so we have to find all the *.itc files (those are actually just renamed png images with some extra header data) that are thrown around in the myriad of folders and copy them into a new folder so that we can manipulate them without destroying your iTunes setup.
From the Local folder, click Search in your Explorer bar (CTRL-F) and search for any file that has "itc" in it's file name and after a while you should be presented with a list of all the cover art files.
Now, make a new folder somewhere else, maybe on your desktop, Select All the files (CTRL-A) and copy them into your newly made folder.
Make sure you copy the files, don't just move them or you will mess up your iTunes library!
65 comments
1-40 of 65next »
Jul 18, 2011. 2:25 AMmonkeys98 says:
the one in this picture is so cool how did u make it like this
Jul 18, 2011. 1:57 AMmonkeys98 says:
there is no contact sheet in automate
Oct 25, 2010. 10:05 AMDrunkenTramp says:
Thanks for this instructables had fun doing this, just thought id mention to save someone the maths if they are looking to do the same thing I made a 1920 by 1200 background for my monitor.
360 albums, 24 columns, 15 rows
that makes each album cover 80 by 80 pixels and fits perfectly!
24 x 80 being 1920 and
15 x 80 being 1200
therefore 1920 by 1200 wallpaper
May 16, 2010. 10:35 AMNoteToYou says:
 Your link isn't working buddy. Try and update it, I can't find the programme.
Oct 19, 2009. 6:16 AMAfxTwn says:
Thanks very much for this instructable, it's great. My only real gripe is with using Picasa to make the poster. I have the latest version of Picasa (3.5) and it is the most infuriating program I've ever used.
Sometimes it finds folders of your photos but a lot of the time it doesn't and won't import them properly. I think I have narrowed this down to it not liking the pictures being resized to 200x200 pixels.
The pictures that it does import are bigger than that size (I'm talking about the original file sizes before re-sizing), hence it will actually show them. But as soon as you resize them to the smaller size then Picasa will not import them properly.
You cannot resize the pictures in Picasa as it doesn't allow you to do that.
Now the other annoying thing is that when you use the Photoshop method it displays the names for each individual picture in the grid. So there is a lot of messing about to do to get it to look just right. Sorry for the long post!
Oct 19, 2009. 7:46 AMAfxTwn says:
Yes! Praise the Lord it worked perfectly.
Thanks very much for that. I tried the remedy in photoshop also but I prefer to use the Picasa method as you can create a nice border round the pictures and easily add spaces between each picture to the size you want. I know I could probably do this in Photoshop but as you can see, I'm not very technically minded lol.
Thanks a lot for your help.
P.S. Richard D.James rocks!
Mar 23, 2008. 10:40 AMJoh(a)n says:
The Command prompt guide you linked too is dead. I tried working out how to navigate myself... but this is all that happened, even though I'm certain I Have the folder in the right place:
Oct 17, 2009. 9:54 AMmr.break_it says:
try using cd art, the folder must already exist.
Aug 27, 2009. 7:28 PMzafiros says:
How do you do this on vista? step two won't work and I thought it was because I'm using vista.
Apr 9, 2009. 11:09 PMGorillazMiko says:
Not bad, I like it.
Apr 2, 2009. 11:24 AMbrainlock says:
I don't use iTunes, but wanted to do the same thing in ubuntu. I have my cover art set as a folder.jpg file in my mp3 folders. Most of my cover art is a 300x300 res jpg.
First I recursively searched for all jpgs in my folder tree that were above 10k using gnome-search-tool
Saved the results as jpgs.txt
Created a bash script to copy the jpgs to a folder with IFS stuff for dealing with white space
#!/bin/bash
SAVEIFS=$IFS
IFS=$(echo -en "\n\b")
for file in `cat jpgs.txt`
do
echo "processing $file"
done
IFS=$SAVEIFS
Then mogrified the jpgs to make sure they were all 300x300
Created many smaller montages, since 2400 jpgs will crash montage
Loaded all of the smaller montage pics into gimp and aligned them to grid to create a giant montage.jpg
Converted montage.jpg to pdf so I could use pdfposter
convert montage.jpg montage.pdf
pdfposter -v -s 1 montage.pdf pdfposter.pdf
pdfposter dumps out a pdf a la rasterbator, so I can print out my 7.5 square foot poster on A4... without the rasterizing of rasterbator..
and that's that.
Aug 7, 2007. 11:04 PMCraZyBob says:
great instructable! however, I don't have a credit card and can't sign up for an iTunes Store account, is there an easy way for me to get all my artwork, or will i have to look it all up manually?
Jan 11, 2008. 7:32 PM401446 says:
.... you don't need a credit card to get an itunes account.... just check "none" when it asks u for payment method... : )
Jan 11, 2008. 9:53 PMCraZyBob says:
"none" isn't an option for me.... see the image i attached
Jan 18, 2008. 6:53 PM401446 says:
Never Mind on That last comment ... this is how to do it without a card... ready .... ok First of all open itunes and go to the itunes store Now click on redeem code/card Enter this code X3P6XANELWXH Now it should say that it is expired and you cant redeem it DON'T WORRY this is supposed to happen .. Now go back to the main menu of the itunes store by pressing the little house button ... click sign in and now click create account .. enter all your info and when it comes to that payment screen ... just press none ... HOPE THIS HELPS !!! : )
Jan 12, 2008. 9:53 AM401446 says:
(removed by author or community request)
Jan 12, 2008. 8:41 PMCraZyBob says:
I figured it out
go here and use this code as if it were a giftcard under the redeem menu.
after that (whether or not it works [ie, you are Canadian like me]) you can choose the none option in your payment options.
hope that helps everyone
Jan 12, 2008. 12:11 PMdrummonkey92 says:
hi, this looks great but im having problems at the start of step 2
i type in "copy /b * test.tes" but it says:
the system cannot find the file specified
0 file<s> copied.
please help!!!
thanks
Jan 5, 2008. 1:29 PMShifrin says:
Wow, This is really cool, this is one of those things that you would hang up in an awesome Apartment! Nice Job! ~Shifrin
Dec 4, 2007. 3:08 PMTheBikemaniac says:
I can't figure out how to make it work in step 2! My PC doesn't recognize bitmaprip!
Dec 4, 2007. 3:10 PMTheBikemaniac says:
You might see better with this one :) PLEASE HELP ME!!!!
Dec 4, 2007. 4:40 PMTheBikemaniac says:
Thanks a lot! I realized that my bitmaprip was a separate folder inside the itc folder.
Aug 15, 2007. 8:12 PMHookahGuru says:
I just finished making one (actually 2) to fit on a 23" x 32" poster. I set it at 100dpi and each thumbnail at 200x200. Let's just say it took awhile to render but well worth it. Until I realized I had a few doubles. Even after clearing out most of the doubles there were still 3200+images. Thanks for this Instructable!
Nov 8, 2007. 4:36 PMHawaii00000 says:
That is awsome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sep 4, 2007. 3:41 AMffolliet says:
quick tip to add to this great instructables.
when using fotosizer do the settings FIRST before adding appropriate folder.
once the folder has been selected it automatically converts to the default custom size. if you have over 1500 files it takes a while and if you try to alter the settings as it runs it crashes.
Aug 1, 2007. 7:40 PMlostadventurer says:
CD Stacker is a different way to get the same result much more quickly and automatically for all those iTunes users - makes it desktop wallpaper instead of a print quality graphic though.
http://www.krrrk.com/downloads.htm
Aug 20, 2007. 11:16 AMthingstealer says:
This download is great for people like me who are too lazy to do it all themselves and just want a neat desktop background! Thanks!
Aug 20, 2007. 12:32 PMlostadventurer says:
Glad to hear that you feel that way. We are working on a drastically improved version to be released in a few more months which would include the option to create a photo quality print using the same method. Thanks for the positive thought.
Jul 30, 2007. 11:24 AMjoejoerowley says:
I just did it and it only to like a half hour. really cool. Now I will just use rasterbated to print it.
Jul 30, 2007. 10:04 AMksjlkdjlddj says:
It doesn't work for me with the duplicate file finder. I mean it doesn't filter all the duplicates out.
Jul 24, 2007. 7:39 PM- creative name - says:
that looks like fun. if only i had the attention spand to finish something like that.
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rauz
