loading
This is a instructable describing how to cumbersomely export your existing iTunes album art and arrange all the covers into a huge grid, leaving you with a gigantic, colourful and vibrant mishmash of popular culture ready for printing and, maybe later, your wall!
I decided I wanted to do this a couple of nights ago and now I've come up with a method, it's not really complicated but can be rather time-consuming depending on how large your library is.
I have around 800 albums with attached album art and it took at least an hour, granted most of that time is spent watching your computer doing all the work for you.
The process requires you to download some free applications (links supplied) and you also need a new-ish version of Photoshop (I use CS3) although I'll show you an alternate way of getting basically the same results with Google's free digital photo organizer, Picasa2.
So, for Windows only at the moment, but I'm sure some Mac user can come up with an easier and cooler way to do this. Damn you, I'm switching soon anyway.
More advanced users can check out Step 7 right away for a quick rundown.
Step 1: Locating Your ITunes Album Art
First we need to make sure you actually have some album art to work with.
There's several ways to go about this; you can import the covers automatically from the iTunes Store or you can painstakingly do it by hand for every album.
- Automatically
- By hand
I imported all mine into iTunes by hand, partly because I'm kinda picky and want them all the same size but mostly because I listen to weird electronic music that's just not available in the iTunes Store, forcing me to find the cover art from Discogs.com, Google image search and elsewhere.
Anyway, I will assume you have at least some album art in iTunes (the more the better) and move on.
So let's locate the images on your computer.
The problem, and the one thing that makes this instructable even worth sharing to begin with, is that the images are not readable by Photoshop as is and that they're all spread out into hundreds of strangely nested folders with strange names.
Therefore, we need to decode them and copy them all into one place.
The default folder for your artwork should be in "My Documents\My Music\iTunes\Album Artwork\Local"
If you can't find it there just do a search for the folder "album artwork" on your C: drive.
If you navigate around a bit from here you'll notice that it's very messy, so we have to find all the *.itc files (those are actually just renamed png images with some extra header data) that are thrown around in the myriad of folders and copy them into a new folder so that we can manipulate them without destroying your iTunes setup.
From the Local folder, click Search in your Explorer bar (CTRL-F) and search for any file that has "itc" in it's file name and after a while you should be presented with a list of all the cover art files.
Now, make a new folder somewhere else, maybe on your desktop, Select All the files (CTRL-A) and copy them into your newly made folder.
Make sure you copy the files, don't just move them or you will mess up your iTunes library!
Step 2: Converting the Files Into a Readable Format
Ok, here comes the tricky part. I was hoping there would be an easier way but so far I haven't found one.
Download Bitmaprip (Portable, 24KB ZIP)
Put the application from inside the zip file into the same folder as your itc files. This makes it easier for later but you can put it wherever you want if you know what you're doing.
Open up a command prompt - click on the Start Menu, choose Run, type in "cmd" without the quotation marks and click OK.
Navigate to your folder with the itc files and Bitmaprip inside.
- Beginners Guides: WindowsXP Command Prompt
In the command prompt, type:
copy /b * test.tes
This will combine all the files into one, named test.tes, you'll see why in the next step.
bitmaprip test.tes
Have a look inside your folder and finally you can see the decoded album art!
As for why Apple has chosen to hide the images so well there are many theories but we'll leave that for some other time.
You can now close down the command prompt and delete all the itc files, if you wish.
Step 3: Removing Duplicates
This quick step is optional but recommended since there will be one cover image for each and every track on all the compilations, various artists etc discs you have.
Download and install Duplicate File Finder (Installer, 1MB EXE)
Open Duplicate File Finder and click the check box next to the folder containing your images, leave the other settings untouched and click "Start Search".
Once the search is done, first click the fourth button from the left and then the recycle bin to the right of it, see attached pictures.
Confirm the deletion and exit Duplicate File Finder.
Did I mention I was a bit anal retentive? :)
Step 4: Scaling the Album Art to the Same Size
Another optional step, depending on which way you took when you imported your album art into iTunes.
I scaled mine to 200 by 200 pixels from the start but chances are there will still be some images with other dimensions and that will mess up the evenness of our final result.
Download and install Fotosizer (Installer, 1MB EXE)
When you install make sure you deselect the option to install the toolbar
The application is fine except for that.
Click Add Folder and locate your images, enter a custom size in the Width and Height boxes (I set mine to 200 x 200), uncheck the Maintain Aspect Ratio check box and finally select a Destination Folder, preferably a new and different one than the one with the unscaled images.
Click Start and wait, this should be pretty quick.
You can now close down Fotosizer and delete the old folder, if you wish.
This can also be done in Photoshop with Actions, if you know how. I just feel I can't spend even more time explaining how that beast works.
Step 5: Assembling the Poster in Photoshop
At last, time to reap the fruits of your labour! After some math, that is.
In order for the poster to end up symmetric we need to have a nice and even amount of images so if you have, say, 317 files in your scaled images folder, just delete 17 of them so that you have 300 left.
Or, if you have for example 355, you can delete 5 and let your finished poster be 25 down and 14 across. Experiment.
Open up Photoshop and make sure you have Pixels selected in Preferences->Units&Rulers-;>Rulers.
Go into the File menu and click Automate->Contact Sheet.
Click the Browse button and locate your folder with the scaled images.
Let Units be set to Pixels and then try figuring out the math. In my attached example the scaled images are 200 by 200 pixels and there's 50 of them, so I figured I try out an oblong poster.
10 rows times 200 pixels is 2000 pixels so the Width should be 2000.
5 rows times 200 pixels is 1000 pixels so the Height should be 1000.
5 times 10 is 50, so all the images will fit on one page, as you can see to the right in the dialog box where it says "Page 1 of 1".
Once you get a hang of it it won't need to be so difficult.
Now just press OK and leave the computer alone for a bit.
This example took around two minutes for me to render but once you start using several hundreds of covers the wait will be longer.
I can recommend assembling smaller chunks at the time if you have more than 400 of them and then putting them all together once the composition is done.
Hopefully you'll end up with something like the enclosed example, only larger.
Step 6: Assembling the Poster in Picasa2
Here's an alternative way to do the final assembly step in case you don't have Photoshop, it has less options and control over the final result but still leaves you with something you can use.
Download and install Google's Picasa2 (Installer, 5MB EXE)
Import your scaled images folder into Picasa2.
- Picasa Help
With the folder selected in the left pane, click the menu Create->Picture Collage, choose Picture Grid, click Create, wait a bit and you're done.
You end up with a square image that you can open up in Photoshop and crop/resize if need be.
Step 7: Summary and Some Final Thoughts
So, for the more advanced users, here's a quick rundown.
1. Copy all the itc-files from My Music\iTunes\Album Artwork\Local
2. Pipe all the files into one via copy /b * test.tes (/b is for binary copy)
3. Extract the png's using Bitmaprip
4. Remove duplicates with, for example, Duplicate File Finder
5. Scale all the images to the same size with for example Fotosizer or Photoshop Actions.
6. Use the Contact Sheet function in Photoshop or Picasa2 to assemble the images into a poster.
Wow. Such a long and convoluted walkthrough for something that should be so easy.
I'm pretty sure there are easier methods or maybe someone will just write a simple Python, ImageMagick or whatever script that does all this in no time.
But hopefully someone got some use out of this, if so I would love to see some examples of your finished results, be it a photo of your printed poster or maybe just a desktop wallpaper.
You can of course apply this technique to something else, like your collection of Russian propaganda art, or use the images to make a photo mosaic.
That's it, thanks and feel free to ask any questions or comment if I left something out.
<p>You can also create the montage image with ImageMagick like this:</p><p>montage test.tes.00* +frame +shadow +label -tile 5x9 -geometry 500x500+0+0 merge.png</p><p>Adjusting the tile value and geometry (size) as appropriate</p>
Like it. Shame it's not possible to do 'spines' - I always enjoyed looking at vinyl collections of friends or in shops to see if I could recognize the album by the spine. <br>There are scripts around that help export from the MP3 (I guess) <br>https://www.mail-archive.com/discuss@lists.slimdevices.com/msg87239.html and this thread might be worth investigating: <br>http://forums.slimdevices.com/showthread.php?44344-How-to-get-Artwork/page4&amp;p=282978#post282978 <br>
Thanks for posting this, really fantastic & just in time for Father's Day... It will make a great gift! Much appreciated bc I know it took a lot of time explaining!!
hollo <br>
nice Instructable. how do you decode the artwork on a mac (OSX lion)?<br>
the one in this picture is so cool how did u make it like this
there is no contact sheet in automate
Thanks for this instructables had fun doing this, just thought id mention to save someone the maths if they are looking to do the same thing I made a 1920 by 1200 background for my monitor.<br><br>360 albums, 24 columns, 15 rows<br><br>that makes each album cover 80 by 80 pixels and fits perfectly!<br><br>24 x 80 being 1920 and<br>15 x 80 being 1200<br><br>therefore 1920 by 1200 wallpaper
&nbsp;Your link isn't working buddy. Try and update it, I can't find the programme.
&nbsp;Sorry this instructable is pretty old by now so some links are bound to be outdated. Try this alternative instead, should have the same functions.<br /> <a href="http://www.easyduplicatefinder.com/download.html" rel="nofollow">www.easyduplicatefinder.com/download.html</a><br />
Thanks very much for this instructable, it's great. My only real gripe is with using Picasa to make the poster. I have the latest version of Picasa (3.5) and it is the most infuriating program I've ever used.<br /> <br /> Sometimes it finds folders of your photos but a lot of the time it doesn't and won't import them properly. I think I have narrowed this down to it not liking the pictures being resized to 200x200 pixels.<br /> <br /> The pictures that it does import are bigger than that size (I'm talking about the original file sizes before re-sizing), hence it will actually show them. But as soon as you resize them to the smaller size then Picasa will not import them properly.<br /> <br /> You cannot resize the pictures in Picasa as it doesn't allow you to do that.<br /> <br /> Now the other annoying thing is that when you use the Photoshop method it displays the names for each individual picture in the grid. So there is a lot of messing about to do to get it to look just right. Sorry for the long post!<br />
Hello fellow Aphex Twin lover :)<br /> <br /> I think both your annoyances can be remedied. Inside <strong>Photoshop</strong>, make sure you uncheck <em>&quot;Use filename as caption&quot;</em> inside the <strong>Contact Sheet </strong>settings, as per my screenshot in the Instructable.<br /> As for the <strong>Picasa</strong> problem, select &quot;Small Pictures&quot; in the &quot;View&quot; menu.<br /> <br /> Let me know if this works.<br />
Yes! Praise the Lord it worked perfectly.<br /> <br /> Thanks very much for that. I tried the remedy in photoshop also but I prefer to use the Picasa method as you can create a nice border round the pictures and easily add spaces between each picture to the size you want. I know I could probably do this in Photoshop but as you can see, I'm not very technically minded lol.<br /> <br /> Thanks a lot for your help.<br /> <br /> P.S. Richard D.James rocks!<br />
The Command prompt guide you linked too is dead. I tried working out how to navigate myself... but this is all that happened, even though I'm certain I Have the folder in the right place:
try using cd art, the folder must already exist.<br />
How do you do this on vista? step two won't work and I thought it was because I'm using vista.
Sorry I wouldn't know. I wrote this guide for XP and I've since switched to MacOS X. I'm sure there's some way to do it on Vista though - what seems to be the problem?
Not bad, I like it.
I don't use iTunes, but wanted to do the same thing in ubuntu. I have my cover art set as a folder.jpg file in my mp3 folders. Most of my cover art is a 300x300 res jpg.<br/><br/>First I recursively searched for all jpgs in my folder tree that were above 10k using gnome-search-tool<br/>Saved the results as jpgs.txt<br/>Created a bash script to copy the jpgs to a folder with IFS stuff for dealing with white space<br/>#!/bin/bash <br/>SAVEIFS=$IFS<br/>IFS=$(echo -en &quot;\n\b&quot;)<br/>for file in `cat jpgs.txt`<br/>do<br/> echo &quot;processing $file&quot;<br/> cp &quot;$file&quot; $RANDOM.jpg<br/>done<br/>IFS=$SAVEIFS<br/>Then mogrified the jpgs to make sure they were all 300x300<br/>mogrify -resize 300x300! *.jpg<br/>Created many smaller montages, since 2400 jpgs will crash montage<br/>montage -tile 7x7 *.jpg montage.jpg<br/>Loaded all of the smaller montage pics into gimp and aligned them to grid to create a giant montage.jpg<br/>Converted montage.jpg to pdf so I could use pdfposter<br/>convert montage.jpg montage.pdf<br/>pdfposter -v -s 1 montage.pdf pdfposter.pdf<br/><br/>pdfposter dumps out a pdf a la rasterbator, so I can print out my 7.5 square foot poster on A4... without the rasterizing of rasterbator..<br/><br/>and that's that.<br/><br/>
great instructable! however, I don't have a credit card and can't sign up for an iTunes Store account, is there an easy way for me to get all my artwork, or will i have to look it all up manually?
.... you don't need a credit card to get an itunes account.... just check "none" when it asks u for payment method... : )
That's new to me, is that a recent change?
"none" isn't an option for me.... see the image i attached
Never Mind on That last comment ... this is how to do it without a card... ready .... ok First of all open itunes and go to the itunes store Now click on redeem code/card Enter this code X3P6XANELWXH Now it should say that it is expired and you cant redeem it DON'T WORRY this is supposed to happen .. Now go back to the main menu of the itunes store by pressing the little house button ... click sign in and now click create account .. enter all your info and when it comes to that payment screen ... just press none ... HOPE THIS HELPS !!! : )
hi, this looks great but im having problems at the start of step 2<br/><br/>i type in &quot;copy /b * test.tes&quot; but it says: <br/>the system cannot find the file specified<br/>0 file&lt;s&gt; copied.<br/><br/>please help!!!<br/>thanks<br/>
Wow, This is really cool, this is one of those things that you would hang up in an awesome Apartment! Nice Job! ~Shifrin
I can't figure out how to make it work in step 2! My PC doesn't recognize bitmaprip!
You might see better with this one :) PLEASE HELP ME!!!!
Hi! I think it might be because bitmaprip is not in the same folder as the one you're working from. Put it inside the "itc" folder and try again.
Thanks a lot! I realized that my bitmaprip was a separate folder inside the itc folder.
An easy mistake, bonne chance!
I just finished making one (actually 2) to fit on a 23" x 32" poster. I set it at 100dpi and each thumbnail at 200x200. Let's just say it took awhile to render but well worth it. Until I realized I had a few doubles. Even after clearing out most of the doubles there were still 3200+images. Thanks for this Instructable!
That is awsome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
3200 images, that great! Thanks for sharing.
quick tip to add to this great instructables.<br/><br/>when using fotosizer do the <strong>settings </strong>FIRST before adding appropriate folder. <br/><br/>once the folder has been selected it automatically converts to the default custom size. if you have over 1500 files it takes a while and if you try to alter the settings as it runs it crashes.<br/>
CD Stacker is a different way to get the same result much more quickly and automatically for all those iTunes users - makes it desktop wallpaper instead of a print quality graphic though.<br/><a rel="nofollow" href="http://www.krrrk.com/downloads.htm">http://www.krrrk.com/downloads.htm</a><br/>
This download <sup></sup><sup> is great for people like me who are too lazy to do it all themselves and just want a neat desktop background! Thanks!</sup><br/>
Glad to hear that you feel that way. We are working on a drastically improved version to be released in a few more months which would include the option to create a photo quality print using the same method. Thanks for the positive thought.
I just did it and it only to like a half hour. really cool. Now I will just use rasterbated to print it.
It doesn't work for me with the duplicate file finder. I mean it doesn't filter all the duplicates out.
Try using one of the other File Comparison Methods, like "Contents Only". Look in the top right corner of the screenshot in step 3 of this tutorial.
that looks like fun. if only i had the attention spand to finish something like that.
*knock, knock* Hello, Ve are from ze RIAA. You are in violation of a future law prohibiting ze enjoyment of components of an entertainment package protected by as yet unspecified laws. Ve will be confiscating ze ink tanks from your printer. Have vun nice day.<br/><hr/>Seriously, great idea. Do you mind if I steal it to make a poster of miniature movie posters?<br/>
Omaga - I will comply! Please supply bank account numbers asap ;) "Steal" all you want, would love to see what you come up with! And what a cool idea, you should come up with some way to scrape IMDb for posters from the top 250 movies or something.
I made one on mirosoft word you cant use the whole page but you can fill in the background with awesome designs.coll instructable btw
Very quick OS X instructions: First, copy all the artwork to a folder on the desktop using the following Terminal commands: mkdir ~/Desktop/itunescovers find ~/Music/iTunes/Album\ Artwork -type f -exec cp \{\} ~/Desktop/testtest \; At this point you have all the files in a single folder named "itunescovers" on your desktop. iTunes stores the images embedded in mpeg containers so we need to extract the images from the .itc mpeg files. The easiest way on a Mac is
&quot;The easiest way on a Mac is...&quot;<br/><br/>Doh! Don't keep us in suspense! =O<br/>
My bad... the cut and paste went wonky.<br/><br/>The following is the remainder of that comment:<br/><br/> iTunes stores the images embedded in mpeg containers so we need to extract the images from the .itc mpeg files. The easiest way on a Mac is to download File Juicer (http://echoone.com/filejuicer/) then run File Juicer and drag-and-drop the files in the itunescovers into File Juicer.<br/><br/>A short while later you will have a &acirc;&euro;œJuice&acirc;&euro; folder on your desktop that contains a &acirc;&euro;œpng&acirc;&euro; folder. Inside the &acirc;&euro;œpng&acirc;&euro; folder are all your Album images.<br/><br/>You can now use Photoshop to scale the images to a common size and layout the images using Photoshop or Picasa2 as explained in steps 4, 5 and 6 of the Instructables instructions.<br/><br/>After writing this up I discovered the &quot;iTunes Album Art Extractor&quot; project (http://sourceforge.net/project/showfiles.php?group_id=194469) which does the extraction and poster creation automatically.<br/>
Thanks for the link!
When I got my finished product all of the file names were included under the album art. Any ideas about why this might have happened?
About This Instructable
87,086views
126favorites
License:
More by rauz:A great technique for scanning your inked drawings Make a huge printable poster from your iTunes album art!
Add instructable to:
