Step 4Scaling the album art to the same size
I scaled mine to 200 by 200 pixels from the start but chances are there will still be some images with other dimensions and that will mess up the evenness of our final result.
Download and install Fotosizer (Installer, 1MB EXE)
When you install make sure you deselect the option to install the toolbar
The application is fine except for that.
Click Add Folder and locate your images, enter a custom size in the Width and Height boxes (I set mine to 200 x 200), uncheck the Maintain Aspect Ratio check box and finally select a Destination Folder, preferably a new and different one than the one with the unscaled images.
Click Start and wait, this should be pretty quick.
You can now close down Fotosizer and delete the old folder, if you wish.
This can also be done in Photoshop with Actions, if you know how. I just feel I can't spend even more time explaining how that beast works.
when using fotosizer do the settings FIRST before adding appropriate folder.
once the folder has been selected it automatically converts to the default custom size. if you have over 1500 files it takes a while and if you try to alter the settings as it runs it crashes.
