loading
Step 6: Making the 'handle'
Use electrical tape and wrap it tightly around the dull end of the knife to make the handle. Or, you can use some large heat shrink tubing and use that.
This instructable was made at <a href="http://acemonstertoys.org/" rel="nofollow">Ace Monster Toys</a>, an awesome hackerspace in Oakland, California -- if you're in the area please stop by sometime!
<p>Interesting.... the shape of the knive is so Amazing.</p>
<p>Wow. This is the most interesting for me!</p>
wouldnt the blade bend and flex? <br>
<p>It wouldn't, if you use a bimetal high-speed blade. Bimetals are little bit harder.</p>
great and easy thing to make
I suggest dipping the blade in water very often when grinding. Keeping the blade cool helps to preserve the temper and keep the blade as sharp as possible.
I couldn't sleep, so I made knives <br>in my case : <br>i couldnt get an airsoft gun so i made crossbows
lolz <br>same thing i was gonna write an instructable about <br>Nicely done i must say :)
The steel from these blades is very brittle and extreme caution should be taken while using them to avoid cutting your own hand if it breaks (because it will break).
You can also use plastic tool handle dip from hardware store.
About This Instructable
23,327views
172favorites
License:
Bio: Member of an awesome hackerspace, Ace Monster Toys.
More by davr.org:Make your own PCBs on an inexpensive desktop CNC mill 3D Scan and duplicate yourself (or anything!) Make a knife out of an old hacksaw blade
Add instructable to:
