3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Living Severed Hand!
Step 7It starts coming together
Now that we have the two main components of the glove, it's time to begin the assembly!
First, glue the last three fingers of the glove together using hot glue (pinky, ring, and middle finger). You are going to want to avoid glue being seen on the outside (knuckle side) of the glove.
Next, you are going to lay down a line of hot glue just below the fingers on the palm of the glove and affix the stump. Be careful! You only have one shot at this! With the palm of the glove, the fleshy end of the stump should be facing outwards (the side of the pinky of the glove). The open end of bottle should line up with about the center of the middle finger.
After you have done, hot glue the fingers (only the 3 that are glued together!) to the stump.
As a final shaping structure, we then cut a piece of scrap cardboard, such as a cereal box. I folded the cardboard so that it was doubly-thick, and then cut it at an angle roughly the same as the slant of the knuckle-line on the glove.
The piece of cardboard is inserted into the glove, on TOP of the foam chunks, but below the flaps of your glove's palm. It is then glued into place. Remember the fill in the thumb of the glove? This will also prevent that from coming out. If you really want to go above and beyond- you could cover the cardboard in fabric.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:a grain of alt.
Jus' living the good life.
