Once you have the idea of the wheels in mind, you will quickly see that you can make any type of train loco from diesel through electric to good old fashioned steam, using drinks cartons or cut down cereal boxes as the bodies.
As this is a model made from junk the exact components are open to what you have at hand, or can easily get, but ideally you will need:
- Bottle caps
- thick and thin cardboard
- coat hanger wire
- hot melt glue (ideally)
- set of compasses
- single serving
- drinks bottle
- black and one bright colour paint (ideally spray paint)
For all the rivet counters out there... this is only a model built for fun using junk and is NOT meant to be a replica of any particular engine ;-)
Remove these ads by
Signing UpStep 1Make the Wheels
(glue gun / hot melt is the best glue for this).
If you don't have any bottle caps, you can cut the middle disc of each wheel out of the same cardboard.
NOTES:
If you want to make a diesel or electric loco with a rectangular body, then you will probably only need four sets of large wheels, or 6 sets if you wand to make a mahoosive Union Pacific Locomotive (check out Google images for some reference). ON the other hand if you want to make a little siding shunter, maybe only small soda bottle top wheels are all you will need... scratch building - so many choices.
17
comments
Add Comment
Wasagi
says:
mary candy
says:
Kryptonite
says:
KaptinScarlet (author)
says:
says:
says:
says:
says:
Add Comment
