Step 2Parts needed
sandpaper (180 & 320 grit)
wood glue (Titebond)
wood finishing supplies of your choice
sharp blade for cutting line (utility knife)
flame for sealing ends of line
something non-magnetic to use as a spacer
If you're starting with the kit skip to the next step, otherwise, read on for help getting your parts together. You'll need:
two 1/2" by 5" dowels
two 3/4" by 1 1/2" by 5" end blocks
one 1/2" cube magnet, part: CHa500D
one 1/2" by 1/4" disc magnet, part: D250D
one 3/32" by 3/8" rivet, part: MS20470AD3-6
one 1/8" by 3/8" clevis pin, part: MS20392-1C7
length of 100lb test braided Spectra fishing line
Go to your local big box home supply store for wood. You can use whatever you like, it's nice if the blocks and dowels match, and a hardwood will give you a nicer finished product. Walnut is used in the kit, you'll need to visit a woodworking store to find that.
The magnets are available from Amazing Magnets. Their part numbers are listed.
The rivet and clevis pin are both available from Aircraft part suppliers, such as Wicks Aircraft Supply. You can also check with your local surplus store, they usually have bins of small fasteners that you can search for something suitable. Remove some material from each side of the clevis pin in the area below the hole to provide clearance for the braided line when inserted into the cube magnet.
Spools of braided fishing line are available at sporting goods stores. You may be able to purchase it by the yard from a bait and tackle shop (they keep big spools on hand to load up reels). Spectra line is strong, abrasion-resistant, and has almost zero stretch, properties which make it useful for a lot of things other than fishing (e.g. kite line, r/c sailboat rigging).
Once you've got your pieces rounded up, drill the end blocks about halfway through with holes to receive the dowels. Drill the top block with a 1/2" by 1/4" deep hole for the disc magnet and use some glue to seat it securely. Optionally, drill a slightly undersized 31/64" hole and press-fit the magnet into place. Drill the other block with a 1/16" through-hole for the fishing line. On the side opposite the dowel holes, enlarge the 1/16" hole to within 1/8" of the other side, drill it out barely large enough to accept the body of the rivet with a single strand of fishing line in the hole (should be some resistance). Now enlarge the top of the rivet hole so you can countersink the head when assembled.
comments
Add Comment
Add Comment
