If you have some experience with polymer clay it can be a first millefiori project. I advise to start with simple patterns, which already give a great effect
If you do not have experience with polymer clay, just take some time to get some feeling with the material and you will very soon be ready to start with millefiori. Check out some of the many online millefiori tutorial videos. I like the ones from fimosieraden.
As taking pictures of a polymer clay work in progress involves cleaning my hands thoroughly before taking the camera each time, I combined pictures of workpieces made at different times to cover all the steps.
Remove these ads by
Signing UpStep 1Materials and tools
- a USB flash drive. I prefer to work with the smallest possible, in order to end up with a small pendant. Sliding models, as opposed to those with a cap, tend to allow for an easier complete removal of the outer casing. You can also use the types without any cover.
- polymer clay of the brand and colours of your choice. I use Fimo "Soft" and Fimo "Effect", most often in a combination of three colours. Take care as polymer clay in unbaked condition is considered harmful to your health and to many plastic surfaces. I guess it's the softeners that do the harm. Check the instructions of the manufacturer. Avoid contact with anything not needed for the sculpting and wash hands, tools and working area thoroughly afterwards.
- some wood with a thickness close to the thickness of the USB flash drive without casing.
- a piece of lace and a catch of your choice
- some masking tape for option A, some thin double-sided tape for option B. I use the type meant for fixing carpets to the floor.
Tools
- a clean working surface suitable for working with polymer clay (the softeners tend to attack many plastics and paints, but not polyethylene and polypropylene).
- a razor type crafts knife
- a toothpick
- superglue
- a kitchen furnace (not shown) with good temperature control adapted to the polymer clay of your choice (110 degrees Celsius for Fimo).
very beautyfull
i really like it so much!
greets!
I use enough of the prepared clay to cover the complete shape with one layer. I am normally left with at least a little extra clay.
I use the part of the cane with the best cross sections to cover the shape. I use what is left to make something else, most often buttons: simple discs of clay cane pieces kneaded (with more or less "marble" effect), with two or four holes near the middle. These are not the strongest buttons, but you can use them as decoration or in applications with light loads on the buttons. You can see them used as eyes in some of my cyborg zombies: http://www.instructables.com/id/Cyborg-zombie-feeding-on-quotdeadquot-batterie/
But actually you can, another Ible describes you can bake a flash drive without destroying it. I tried it once, with succes.
A colleague of mine, an electronics engineer, told me he was not surprised at all this is possible, as the inner working temperature of those devices is quite high. What would be destructive is trying to bake it while it is powered up (both heat inputs adding up).
As I need a non sticking surface to obtain a removable "cap" piece anyway, I make a "core", thus avoiding any risks involved with baking the usb drive.
thank you for explaining that. =]
