3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a mini milling machine- manual or CNC!
Step 13Mount a motor! (or a spindle and motor)
  • last photo ←
I used an old Aluminum block I had in my scrap box to mount the Foredom handpiece. The handpiece has a 1" OD and the block I had was for holding bicycle fork steerer tubes during cutting so it was a perfect fit. You could also use a hardwood block with a hole bored in it with a Forstner bit. The holes in the center of the block are for tightening/loosening the collet.
I drilled a couple of holes in the block and mounted it to the Z axis plate with two bolts. The motor mount was a piece of bent steel that came from an electrical box. The motor is connected to the handpiece with a small timing belt that came from an old copying machine, but I've found that large "O" rings do a good job as well- so do vacuum cleaner drive belts. The end cap of the handpiece is removed and a timing belt pulley is fitted to the handpiece shaft- the shaft is 1/4" diameter. I'm currently working on speed control for the motor and will post an update when that's finished.
I found a similar motor to the one I'm using here. It's a 12v motor like the kind used in a cordless drill. They tend to be very durable and have a wide voltage range. Miniature timing belts and pulleys are available here .
The other option is to simply mount a Dremel tool- no need to worry about belt tension!
Mount some rubber feet to the bottom of the mill and you're done!
I did add some stick on metal ruler scales to the Aluminum channel for each axis- it makes it really easy to get rough measurements. I also made a dial indicator holder that is positionable so I can get really precise measurements from each axis. The indicator in the photo measures in .0001" increments.
I'll be posting the CNC conversion soon along with several handy tools like an indexing fixture and milling vise so stay tuned....
6 comments
Nov 4, 2009. 11:46 AMjonjon1978 says:
Wicked project. Its the first one ive done so im strugling with getting some of the parts needed e.g. motor coupled with not having all the right tools aswell e.g. Router. so im going to concentrate on getting all the right tools and materials before i start with the critical cuts and drilling. i have seen the prices of the delrin and thought it would be cheeper to sub it with pieces of laminate floor or do you think it would be better to use delrin? Also im thinking of salvaging a motor out of a hoover but would have to slow it down some how? Do you think this would be ok to so? Many thanks. jonjon1978
Oct 18, 2009. 3:24 PMkmorgan54 says:
Was it easy to remove the top cap of the handpiece? I have a Foredom #44 handpiece, and I'm unable to remove it. At least, it seems that I would have to destroy it to do so.
Aug 20, 2009. 10:11 AMstalker1973 says:
nice project, can you explain how did you make the spindle ( the inside ) I follow your projects Greetings Barry the Netherlands
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
621
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
