How to make a mini milling machine- manual or CNC!
Step 14CNC conversion
CNC conversion
  • last photo ←
For converting the mill to CNC you need to make some stepper motor mounts and motor couplers. I made each motor mount from two 2 1/2" square 3/4" thick plywood blocks that are glued together (you could also use Delrin and make it as one piece.)
The mounts are very simple- just two 7/8" holes bored through them using a Forstner bit -one (on the end view of the drawing) is for the motor coupler to slide through and the other is so you can tighten the set screws on the motor coupler after the motor is mounted. There are four holes for mounting the motor and an additional two holes for screwing the motor mount to the mill.
The motor coupler is just a 5/8" diameter Aluminum rod with a 1/4" bore through it and a couple of set screws to fasten it to the stepper motor shaft and the ACME rod lead screw. Note that the dimension shown on the drawing for the length of the motor coupler is incorrect- it should be 1 1/4" long. You can buy the motor couplers here if you don't want to make them yourself.
The mounts are designed to accept a standard sized NEMA 23 stepper motor. These are very common and are easily obtained. I bought mine surplus for $15 each ( I don't remember where). The stepper motors shown are:
Superior Electric Slo-Syn
Model #M061-FD02
35oz in.
5v 1A
200 steps per revolution
I haven't yet decided what CNC controller I'll be using but I'm leaning toward either the Linistepper or the HobbyCNC ProDriver.
Both controllers are capable of driving a fourth axis (something I plan to add later on) and have had very positive reviews. The Linistepper is an open source controller and there are a couple of different versions of it floating around.
As soon as I can afford a controller I'll have a video of it making some cool parts!
10 comments
Dec 5, 2010. 8:12 PMsavant77 says:
Awesome mill Honus! Did you figure out how accurate it turned out to be? I imagine it is only as accurate as the tools you used to build it with. I already have a tabletop manual mill, now you gave me the idea to try and make it a cnc mill for easy operation. Thanks so much for taking the time to document this for the community.
Mar 19, 2011. 2:43 PMhightekrednek2396 says:
how much did the linear rails cost
Dec 18, 2010. 1:26 AMsaurav.maepal says:
gud work dude......m also going to make dis......hope i'll make....
Jan 29, 2010. 4:20 PMnickmiletich says:
Honus, can you build it for me and send it to the address below... lol.  Great work and amazing sketches!  I look forward to seeing your V2 cnc mill.  Thanks for sharing!
Oct 4, 2009. 1:51 AMBlackice504 says:
this is a great instructable professional plans but i am sure if i build this my house may detonate or catch fire lol. if you looking for a cheap stepper motor controller you might be able to cheat. if you can get your hands on a plotter controller board they have very large stepper motors and you should be able to use them and just draw and then Print.
Aug 7, 2009. 8:51 AMMaddMann says:
Dude - really nice, and a great job on the 'ible. So, does it work well? Can you post some pics of some of your milled creations?
Aug 19, 2009. 6:45 PMWoodie49 says:
Are you going to post the new machine?
Apr 26, 2009. 2:33 AMjuliceci says:
can you please send me the parts list and all information about the motors etc on the email below jultajess@gmail.com
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
588
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
