3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a mini milling machine- manual or CNC!
Step 5Make the anti backlash screw blocks
Take the three pieces of 2 1/2" x 1 7/8" plywood (you could also use Delrin or MDF) and cut them according to the drawing. Drill and counterbore the holes for the mounting bolts. Drill and tap the 1/4" Aluminum rod for the 4mm bolts and insert them into the blocks (make sure you can see the threaded holes.) If you use Delrin to make the parts you can skip the Aluminum inserts and just thread the holes in the blocks for the 4mm bolts that hold the metal plate that retains the ACME nut.
My blocks were cut by hand- and it shows! The best way to cut the 1/2" wide slots for the ACME nuts is to make a jig and cut them using the router table. Clamp the screw blocks in the jig and then run the jig over the router bit to cut the slot. Don't try to cut the slot to full depth in one pass- just slowly increase the bit height and make multiple cuts until you get the desired depth. Cut the slot for the non spring side first and then flip the piece over to cut the other slot- that way both of the ACME nuts are guaranteed to be in perfect alignment.
Now make some 3/4" x 1 7/8" retaining plates for the front by drilling holes for the mounting bolts and a 5/16" hole so the ACME rod can slide through.
Check the fit of the parts by assembling it as shown in the drawing. The spring should be 1 1/4" long ( or close to that) before being compressed.
8 comments
Mar 23, 2010. 11:05 AMFlying_MashedPotatoes says:
where do you put the 1/4" aluminum rod in these???? (thread-less)
Mar 23, 2010. 12:50 PMFlying_MashedPotatoes says:
Are the bolts used to hold the Delrin slides and Delrin slide retainers also used to hold the Delrin slide to the Y-axis 12" x 4" plywood piece?
thanks in advance
Mar 23, 2010. 8:05 PMFlying_MashedPotatoes says:
could you please label your pictures as to show which bolts for which holes are located?
Mar 24, 2010. 10:59 AMFlying_MashedPotatoes says:
never mind, i looked at the pictures more and now i know how you have bolted everything together
Dec 3, 2009. 5:02 AMmadmaze says:
I was wondering what "anti-backlash" exactly refers to? I am by no means a Mech Eng. but If you could please what the problem is this is solving?
I assume that the sping gives it a little bit of play, but what happens if the spring wasnt there?
Dec 3, 2009. 9:52 AMmadmaze says:
never mind i understand it now, it has to do with the way the threads of the leadscrew mate with the threads of the nut.
more info:
http://www.cncroutersource.com/back-lash.html
how powerful of a spring is in there?
Dec 3, 2009. 11:07 AMmadmaze says:
hmm i guess im just gunna hafta see what i can find =)
Mar 15, 2010. 12:14 AMmorphious69 says:
my suggestion is you hit up CNC zone for questions on all of this. there are a lot of really nice people there that will do more than you can imagine to help out others in this hobby.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
621
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
