loading
Step 7: Profiling - Basic Boomerang Aerodynamics
Back to the table. A boomerang is a set of wings put together in a certain way. Wings are profiled, and flattened towards their ends. To understand why and how boomerangs behave, you’ve got to know some basic principles.
Boomerangs do not just go away and come back. The main reason they do so is that they turn very fast around their axe after being thrown. While throwing a boomerang the right way, you’re giving it the necessary rotation. This movement is counterclockwise (for a right-handed boomerang), the leading edges (steep wing-sides) cutting the air, just like airplanes, birds etc. The rotation gives them uplift, and the setting of the wings causes a spin. This spin forces the missile to flow not just right away. Translated: your rocket is coming back home. Get these basics in mind while setting the profile or download the picture. This drawing-thing isn’t exact science, sanding and feeling will do the rest.
Shaping the profiles is sanding, sanding and especially sanding: heavy (electric) sanding with coarse grain at the beginning and manual sanding with finer grains to finish. This phase is pure instinctive, so try to make the best wing-profiles you can get. And take your time.
Note: I never throw away the sawdust and woodchips because it’s perfect stuff to smoke fish.
Thank you!
You're welcome!
That is really awesome! Beautiful!
Thanx micraman, nice to see that there are other beings to appreciate this kind of work ;-)
Oh, that is truly a thing of beauty.<br><br>Thanks for sharing!
Thanx Kiteman, the pleasure is mine!!!
Excellent!<br><br>I Always wanted to do something so, and always let the opportunity pass. I have also done many boomerangs, the former were galvanized, quite thick and extremely dangerous. I keep at the attic a &quot;trimerang&quot; done in plywood, 3 mm.
Thanx rimar! Making natural booms has become part of my life and a pocket saw is always in my backpack. Nothing worse then spotting an elbow and saying 'Oh god I forgot it at home!' ;-)
<p>Visually very appealing, and I agree about oil vs other finishes.</p><p>Add in that its a thrown weapon (of sorts) that comes back...boomerangs are AWESOME...</p><p>Looks like its time t o dust off the bandsaw and go cut some tree limbs into artwork... </p><p>Great `Ible!</p>
<p>Awesome to see that my first I'ble is still alive 'n kicking! Thanx for the compliment, go for that bandsaw and good luck with your search for elbows mate!</p>
<p>Hi Bricobart, very nice tutoral! I have to say you are wrong on 2 things. Drying an elbow for 1 year is not perfect. If you dry naturally, then it more or less takes 1 year per cm each side. If you were to slice the elbow in a 6cm piece it will take approx. 3 years to dry. It also depends in which period you cut the wood, winter is normally the best time. Also less than 100&deg; angle will result in less spin is not correct. A lot competition boomerangs have an angle much less than 100&deg;. It has more to do the kind of airfoil you give. I see you are from Belgium (I'm from the Netherlands). Would like to meet you one day and talk about boomerangs and woodcrafting :-) </p>
<p>I meant 1cm each side per year.</p>
<p>what is the angle of boomerang</p>
<p>Try to get something between 100&deg; - 120&deg;. Take less &amp; it won't spin, take more &amp; it will spin too slow to stay in the air. The only way to compensate the last problem is to make the wings longer, but then you'll have to throw harder. </p><p>Start &amp; practice wilh a small one - not bigger than 30cm diameter - and go bigger when you feel the moment right.</p><p>Good luck!</p>
<p>HI My compliments to you, I've made MANY boomarangs, but have never started at the tree, I can just imagine how much work this was, it looks awesome - what did the turning radius end up being? a Job very well done!! :-)</p>
<p>we are not mates</p>
Looks super and I plan to make one. Got a VIDEO to show how well yours works?
<p>no thanks</p>
Hi Stickmaker, thanx for commenting! I didn't test it yet but I'm planning to do so and I promise you there will be a video!
cool. you should ad a video of it in action
<p>ddadd*</p>
I will, I only have to find a soft underground like a football field for its maiden flight because I don't even want a scar on it ;-)
<p>Great Instructable, Bricobart... ;) A tip... Cut the fresh wood, and finish shaping... Then dry out the wood, in an oven,( at 100-150 degrees celcius...?)</p><p>Or, like the aboriginals, in the ambers from a fire, just wetting the boomerang frekvently, in a bucket of water... &quot;This make the boomerang last 100 years&quot;... Without waiting a whole year... But, do not scorch the wood, of cause... Just wet it, and heat for a couple of minutes, to dry surface... Wet again, and dry the surface... perhaps ten times, in ambers...</p>
Thank you very much for sharing and it looks really good
Thanx mate!
Very nice. Looking at the picture I want to hold one in my hands! Not to throw, just to enjoy the wood.
I have made 'rangs for 15 years. I make them out of &quot;Baltic Plywood&quot;. It is a 5 ply plywood; not the normal 3 ply. It is much easier if you are just wanting to fly them. They can be beautiful also. The wood can be bought at a specialty wood store and I have bought 6 pcs. of 2x2ft. on eBay for a good price. A jig saw is also a good tool to have to cut out the initial shape.<br><br>My biggest accident was when I threw two at once. One came back and I caught it. The other hit me in the mouth. I lucked out and did not get any broken teeth, just a small scar. They are worlds of fun.
Hello graydog! This kind of accidents happened to me as well, especially when throwing face to sun. I remember I boosted up a plywood boom called 'Beat's Mini' - still my favourite plywood boom ever - to a 'Beat's supermaxi'. This maximodel measured 60 cm (almost two feet) from tip to tip. It hurt me right in the front of my head and one eyebrow didn't appreciate...
Hi bartolo, I can appreciate waiting for the wood to dry. I make walking canes as well from Bois D'Arc (pronounced &quot;bo-dark&quot;, a very hard dense wood also known as Osage Orange). &nbsp;<br> <br> You can see one here: &nbsp;<a href="http://http://walkingstickscanes.blogspot.com/" rel="nofollow">&lt;Blogspot&gt;</a><br> and here: <a href="http://reviews.ebay.com/MAKING-BOIS-D-ARC-WALKING-STICKS?ugid=10000000002188165" rel="nofollow">&lt;eBay review&gt;</a><br> <br> With this wood, I cut off a 3 inch lower horizontal limb and the tree sends out a new shoot that grows 8 or 10 feet in one year, making an elbow. I can then cut this off and cure it for one year. It makes a one piece cane and handle that is very strong. Bois D'Arc cannot be stained, but can be carbonized with a torch and then polished to a shiney black finish. Nice article. Beautiful boomerang. Have fun.
At the risk of offending I would like to direct your attention to an old Ray Wylie Hubbard song called 'Choctaw Bingo'. <br>If moderate vulgarity offends you please just forget I ever said anything. . . . <br>If you are not easily offended and want to hear B'dark wood mentioned in a country song you may be pleased.
Very nice! And I never heard about your 'Bois d'Arc'. I didn't some research yet but did you know that the translation of Bois d'Arc 'Bow wood' means? Any relation with bow-making? <br>I'm always interested in what I call 'Yak-Proof' wood and I guess your wood deserves this adjective ;-) You know, I love making knives as well and recently I discovered that one of the hardest wood species in Europe not Common oak or whatever oak is but a shrub: Erica arborea or Tree heath or 'French bruy&egrave;re'. This plant produces extremely hard and heat-resistant roots, often used to make smoking pipes. I'll use it to make knife handles. Found one two months ago and it's patiently drying...
Bois D'Arc was (and is) used for archery bows. My dad had fence posts made of it that were 60 years old and so hard you cannot drive a staple into it. I have several of these trees on my 15 acres. The only problem is they have a 1 inch thorn that will puncture ANY tractor tire. They have a green fruit, called a hedge apple. People use them inside houses to repel roaches and other bugs. Look on eBay for &nbsp;<a href="http://www.ebay.com/sch/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=osage+orange&_sacat=See-All-Categories" rel="nofollow">&quot;Osage Orange&quot;</a>, The wood is cheap on ebay.
I've never had a chance to throw a real boomerang, but from my knowledge they're dangerous yet extremely fun. How fast does something like this go when thrown?
Depends on the type &amp; the force at which it's been thrown. I've got some models who are really smooth and easy to catch. In all those years I've been throwing I only got two accidents: one by playing at sunset - the sun &amp; the boom right in my face! - and another one with a boomerang who ripped my fingernail off with a bad catch, awww!!!
ouch
This looks lovely. I was thinking though, for anyone who might try this, if it doesn't quite work out don't despair. You might not have an aerodynamic rang, but you could have a very effective throwing stick. &quot;Rabbit sticks&quot; I think they're called. Just an idea.
It may be redundant, but the saw to be used in this case, cutting WITH the grain, should be a rip style saw. There should be no angles on the teeth, called FLEAM. Rip saws &quot;chisel&quot; their way through the wood, while crosscut style saws actually slice across the fibers.<br> <br> <a href="http://www.vintagesaws.com/library/primer/sharp.html" rel="nofollow">http://www.vintagesaws.com/library/primer/sharp.html</a><br> &quot;All about Fleam&quot;&nbsp; Around 1/3 down the page...
Never thought about that, but I'll try it that way next time and tell you about the difference. Thanx for the tip!
The Aboriginies of Australia normally use Mulga wood, especially where a root travels along just above the ground and a fire has killed the tree. That's how they taught me and that's how I make 'em. I dont use your modern tools and I find that the Kali (Boomerang in Imanpa, an Aboriginal tongue) I make with only wood and stone are fantastic. Try Fig, it is a very good timber. I have used it to make traditional Boomerangs, Shields and also, when the root shape is right Damned fine spear shafts (of course the spearhead is still made from fire-hardened Mulga)
Hi down under! Show us some pictures, I'm curious to see them!<br>You know, we have a poor boomerang history in Europe, so it's not that bad I use modern tools ;-) I understand that on your continent you're treated as a demon when you're not using stones ;-) Interesting story, by the way!
Very nice! I so want to attempt this with Mountain Laurel, Rhododendron, and Dogwood. (for starters, ha!)
Very good idea, especially the Rhododendron! I regret very very much that a long time ago - say 15 years - I wasn't yet fan of natural booms because in the Everest-region were many huge Rhodo's! <br>Say... lucky I wasn't, because they would have called it 'deforestation' there ;-)
Nicely done. How does it fly?
Thanx, I haven't tested yet but I keep you informed. Its quite heavy so I guess it will rather be a large range boomerang that can be thrown in heavier winds. I'm sure it's perfect for hunting ducks ;-) ;-)
I don't even care if it flies. That is the most beautiful boomerang I have ever seen.
Thanx whiteokart, I'll communicate your comment to the tree who produced it! ;-)
Ww! Very Beautiful Boomerangs. I've been plannign to make one myself.
Go for that, it's really great fun!
This method is great and looks like it produces durable, and beautiful boomerangs. I just hate that I have to wait a year for the wood to dry :(
I know the feeling mate! That's why my very first boom was made out of a Y cut from a dead tree. For 'Mireval' it took me one year of nailbiting! ;-)
About This Instructable
154,580views
476favorites
License:
Bio: I made a beer mug with only a knife & a hatchet. I think that says a lot about me.
More by bricobart:IKEAK - soft floor survival kayak A Day in the Life How to say thank you to your followers
Add instructable to:
