3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a parabolic solar dish from an 8 by 4 sheet of plastic (without too much waste)
I need to make a half parabolic dish for a solar cooking project and I am trying the "cone method" .  Basically my dish will be made from concentric cones to mimic a parabolic dish and  to give the desired concentration of light.  For me a 6 inch ball of fire at the focus should work.
I am cheap and lazy  so I want to get maximum use from an 8 by 4 sheet of plastic without having to cut it into a thousand petals and still have it work with the rest of the design.
 What I came up with will probably work for me.
But I wanted to share the method so that it can work for you, and perhaps for disaster relief too.
Brian
Step 1Design of the parabolic curve
I did this with an improvised t-square and basic technical drawing tools,wrinkled paper.  and a calculator. So there are probably Measurement errors a plenty.
However the method is valid.
I will leave the image notes to explain things for the moment.
I start with the mirror straight across from the target ball because  if you start anywhere else, it is hard to figure out how big your dish will be.
There are 2 ways to do the mirror angle.
The mirror is set up at half the angle of the light hitting the mirror and the light bouncing away from the mirror.   The parallel lines method is much quicker than measuring angles but you need to check as errors creep in.
I never learned cad.
I am sure this will be perfected on computer aided design programs.
4 comments
Jun 24, 2011. 8:17 AMrimar2000 says:
Your design will prove to be good only if you can cook normally during a cold and windy day. I get the impression that this configuration will not succeed. Too many wrinkles. And 112º C is too low, specially in summer.
Jun 23, 2011. 7:37 AMrimar2000 says:
Brian, your result is good, but it would be better if instead of thin film you use thicker, about 0.03 cm of metalized acetate or polypropilene. It makes much (but much!) less wrinkles.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
74
Author:gaiatechnician
I am a stone mason. My hobby is making new solar cooking and gardening stuff. I have used solar heat to cook soil for a couple of years. In mother earth news in January, i read that their compost expe...
more »
