Step 5Back to the Hood
I like to start here in the sewing process. It’s quick and easy unlike the process of creating that funny s curve in your pattern… Pin your hood right sides together and sew along that nice long curve that goes from the front of the hood to the back. For those new to sewing, this is where that seam allowance comes in. The ½” allowance tells you that you should be running the outside of the fabric along the ½” mark on your needle plate. If you have an older machine that doesn’t have markings on it, grab yourself a sharpie and measure from the needle out your seam allowance and mark it. Eventually it will wear off, but it should last a project or two.
Take your time sewing if you don’t have good control over your machine yet, go slow. It might seem a little tedious but you’ll be happier with the results in the end.
After you’ve sewn your first line, take your hood to your ironing board, and press that seam open. Back to the sewing machine and sew down both sides of that seam. I usually just run the seam along the left edge of my presser foot, which on most machines results in a 1/8” seam. This will make it a stronger seam, adds a nice little detail to the finished garment, and reduces bulk, especially if you are lining your garment. First piece done!
Add Comment
