3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a pedal for rotating the Linux cube
Recently I posted an instructable about a footswitch to hide all the windows in Windows XP, but I spend most of the time in Linux programming drupal websites, so I made this one to be used "At work also" =P
The other day I found an old unused sports wheel, along with its foot pedals, I thought it will be nice to use the pedals to rotate the cube desktop in Linux, just to show off or impress some new customers... well not really.
I have configured my Linux Desktop Effects (I have installed Ubuntu 8.04) this way:
When you press Ctrl + Alt + Right arrow the cube turns right, and
When you press Ctrl + Alt + Left arrow the cube rotates to the left.
So we'll be making a switch to mechanically press the keys in the right order to achieve the effect
This instructable is VERY cheap, but it requires a little bit of work.
Thank you and have fun!
P.S. Some extra pics at: my blog
Step 1Parts needed
Parts needed
This instructable is ALMOST the same that http://www.instructables.com/id/Easy_stealth_footswitch_pedal_to_minimize_window/
so, most of the steps are the same.
Parts needed:
1) A computer with linux and the rotating desktop cube installed (I have installed Ubuntu 8.04)
2) An unused / old / not working wheel game with pedals, you will only need the pedals. I think it doesn't matter which model is, we will make custom switches
3) An unused old keyboard - for the keys functionality (I had A LOT of unused keyboards at home)
4) Some foamy sheet - I found one at a handcraft shop, you don't even need a full sheet, just a little bit square inches.
5) A multimeter - not a must, but it really helps to check everything OK
6) A soldering iron
7) A dremel tool
8) Some cable, about 10 ft.
9) Plyers, tape, solder, tin foil, scotch tape, etc...
10 comments
Jan 13, 2010. 9:07 AMmarshal says:
can you show me the electronic inside the pedals because i want to make a pedals to play games? thanks.
Jan 18, 2010. 5:54 AMmarshal says:
i'm asking to see the circuit component so that i can make one.
thanks
Oct 24, 2008. 6:39 AMPKM says:
I'd love one of these.. mostly for the gimmick factor but also because it would save time in photo editing. I have Ctrl+2 as "switch to workspace 2" and Ctrl+Shift+2 as "move this window to workspace 2"- I wonder if you can do key combinations across more then one keyboard? Hold shift and press a pedal to move a window...
Oct 24, 2008. 12:22 PMCameronSS says:
A computer with a manual transmission?
Oct 25, 2008. 8:15 AMPKM says:
Exactly- Ctrl and 2 under the switch, shift as an optional modifier to move the window rather than the view.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:eliastorre(My company blog!)
Hi there, member since long time ago, but just recently added something.
