3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a permanent-marker-remover!
This instructable will show you how to make a permanent-marker-remover out of an empty text marker and some nail-polish remover.
With the power of nail-polish remover and the precision of a text marker, you can easily clean away any small permanent-marker stain!
Step 1What you need
What you need
For this project you'll need:
  • some nail polish remover
  • an (empty) text marker
  • a sharp knife or a hacksaw
  • some heavy-duty tape (electrical tape works fine)
  • a tissue or paper towel
12 comments
Oct 12, 2011. 7:30 PMpmarx-thompson says:
Or you could just go over the mark with another permanent marker and wipe them both off while it's still wet. Works every time.
Oct 2, 2011. 5:34 PMsbell16 says:
Neat idea, but I'd recommend using non-acetone nail polish remover. Or will it not work as well?
Oct 2, 2011. 5:33 PMjcheng3 says:
If you can refill it by holding the tip in nail polish remover, why do you have to cut the end off in the first place? Can't you just stand the tip in some nail polish remover for a while?
Oct 2, 2011. 11:18 PMerict says:
Neat idea, I use a dry erase marker. I draw over the permanent marker line with the dry erase marker and then wipe it off with a paper towel. Something in the dry erase marker seems to break up the permanent ink. Works really well on white-boards when the previous presenter was to lazy to check what kind of marker he had (ask me how I know)
Oct 1, 2011. 6:32 PMTheHawkeye says:
Cool idea, but wouldn't it be a better idea to use pure acetone (paint thinner) than nail polish remover? The problem with using the nail polish remover is that not everything will evaporate away. It contains acetone, along with other stuff like gelatin, etc... Acetone also evaporates very quickly and is good at replacing water, so it won't lave a wet patch all over your erased section. I don't think acetone would break up the paper into wet little balls like I predict nail polish remover might. Maybe I would recommend a highlighter case as well..
Oct 2, 2011. 8:23 PMtinstructable says:
Some nail polish removers do contain 100% acetone.
Oct 1, 2011. 6:38 PMTheHawkeye says:
Acetone is very volatile, meaning it will evaporate quickly, and you don't want to inhale to much. It's a good idea to keep it capped, but I'm unsure how airtight your cap is.
Oct 1, 2011. 11:08 PMKing Julien says:
Wow! Looks great! Too bad it wont work on paper!
Sep 30, 2011. 8:48 AMkillbox says:
Pretty cool, been popping out the cork in cheapo highlighters to extract the florescent dye, ive wound up washing the cartridges and tips on a few of these and thinking these should be useful for something.
and now I know one thing to try out in them! may try making another one full of goof-off or goo-gone.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:Candymanproductions
