Introduction: Make a Programming/test Clip by PCB
Picture of Make a Programming/test Clip by PCB
When I designed some small stuffs such as tiny robot, binary watch and so on. The program interface(e.g. ICSP) occupied much more space on the PCB and I have to unsolder the program socket or pins after debug done. So I made the CLIP to solve the problem.
The clip named by eClip has the follow features:
  • The eClip is made by two parts: the Base and the Function-board. You can design and use your own Function-Board.
  • Adjustable clamping range and force.
  • Here I designed 2mm and 2.54mm programming interface (2x4) with golden pogo-pins, which can be applied to ICSP and FTDI.
I think the eClip is an innovative programming/testing tool for electronic Makers.
The eClip is compatible with low-power controller(uHex) I had designed. Now, you can try to program uHex by eClip.
Step 1: Prepare Materials
There are many materials for make the eClip.
First you should make the PCB, you can use the attached file( eagel, in the zip).
Than you should buy other materials listed in the attached BOM file(libreoffice, in the zip).
Step 2: Prepare Tools
  • Abrasive paper
  • Small phillips screwdriver (M2 Screw)
  • Soldering iron
  • Soldering tin
Step 3: Make the Base - Prepare
Picture of Make the Base - Prepare
Step 4: Make the Base - Solder
Picture of Make the Base - Solder
Step 5: Make the Base - Assemble
Picture of Make the Base - Assemble
Step 6: Make the Function-Board - Prepare
Picture of Make the Function-Board - Prepare
Step 7: Make the Function-Board - 2.54mm
Picture of Make the Function-Board - 2.54mm
Step 8: Make the Function-Board - 2mm
Picture of Make the Function-Board - 2mm
Step 9: How to Use
Picture of How to Use
Step 10: Design Your Special Function-Board
You can design your special Function-Board based on the template. See the attached files( one is eagle, one is DXF).
Step 11: Where Can Get It
You can get eClip from DFRobot (http://www.dfrobot.com/index.php?route=product/pro...)
Enjoy DIY, Enjoy yourself.
SpencerF2 (author)2015-07-17
Wow - that is superb.
I recently made some simply by sticking 0.68mm shaft pogo pins directly into the IDC header ... but they can be hard to hold on the PCB. You have certainly solved that problem!
LeoYan (author)SpencerF22015-07-18
About This Instructable
1,417views
30favorites
License:
More by LeoYan:Make a shining Charm with Rainbow Loom Make a programming/test Clip by PCBMaking low-power(0.12μA) Arduino control board
Add instructable to:
