Parabolic dishes to a point ONLY when they are pointed EXACTLY at the sun. But the sun moves and that point quickly spreads all over the place unless your are watching over your solar cooker all the time.
My conclusion after a couple of months of working with a prototype is that a parabolic dish is the wrong shape!
This instructable is about the shape I found to replace the parabola and how you can use it to make a simple reliable "Compound" parabolic solar cooker. Mine will focus the heat on your cooking pot for up to 3 hours without moving it!
http://www.youtube.com/watch?v=uX9Z-nsUHiA Here is a video link to help too.
You can skip to the 7th page if you just want to see a template for the cooker.
Use the template to make "petals" from any sheet material.
Then tape the template together with masking tape or duct tape and stick your reflective coating on it.
Finally a use for corrugated election signs when the election is over!
Remove these ads by
Signing UpStep 1Problems with parabolas!
The tracking solar accumulator
It was a solar cooker that consisted of a pot of material and a parabolic reflector that turned slowly to track the sun on an equatorial mount. This parabolic reflector was not the bottom of a parabolic bowl as most reflectors are but rather, a section from the side of the bowl.
I did this daily tracking with a low tech tracker that I made.
It was just an adjustable waterclock (also on instructables)
The sun moves higher and lower in the sky with the seasons and I intended to do this adjustment twice a week to keep my dish pointed exactly at the sun and the light exactly on my pot of food. I had to make a "mechanical mathematician" for making my section of a parabolic dish, and I had to make a low tech tracker too.
One problem was that every time I adjusted for the sun's change for the season, the center of gravity changed and I had to readjust the balance of the dish. Time consuming!
Another is that parabolic dishes are precision devices.
If you aim slightly wrong at the sun or if your tracking mechanism is slightly inaccurate, or even if you bump your dish a few times (as I did) you will not get the hoped for results.
This are some of the reason that I needed a more forgiving shape than the parabola!
This was the first test of the idea and the second test is beginning soon with completely redesigned equipment.
I would like to know the type of leaser level that you used for the that interesting compound parabolic experiment? can you also tell me what is the aproxx cost of that type?
Thanx for these interesting tips.
I am actually working on compound parabolas, but could not able to get it right...the compound parabola that you have shown is continuous.(above video).
but i have found few site in net that shows some different picture for it..
(url:http://www.fossilfreedom.com/increase-output.html)
I am totally confused can you plz help regarding this.
My thing was the first part of my attempt to turn that trough into a dish. (Because parabolic dishes have such a short time before you have to move them and because dishes have greater concentration.
So basically the bad news is that my stuff here is just part of the process to making a better dish. It is probably a bit better for solar cooking than a parabolic dish but it is not as good as I had hoped. My latest version is the clam shaped solar cooker. That should be best of all but I still have a LOT of work to do on it. So search "solar design t-square and clam shaped solar cookers" for my most up to date stuff. (And please be prepared to work on my foundations, and also be prepared for mistakes by me) I am not perfect and I do not have the math for this but the trial I made of the clam shaped solar cooker seemed to work pretty well.
If you want to go into the theory of troughs and compound parabolic troughs, send me a message and I can send you pdf's with the correct dimensions and with several other trough designs too. (the pdf files are not my work but were obscure yet very interesting stuff and helpful for the hobby trough and dish maker). You might never find them on your own. Hope this helps
Brian White
it would be good if u can send me the materials you mentioned above..
the problem is that i have already done experiment on compound parabolas and don't want to leave this work with out seeing its end.. so i will do it and lets see if i can make it a little efficient..
i just need your materials to study..
my email address:
anilkrishnashaw@yahoo.co.in
Regards,
Anil.
http://www.solreka.com/parabolic-solar-cooker-template-150cm.html
http://www.cockeyed.com/incredible/solardish/dish01.shtml
Enjoy...(Disfrutela)
Hope this helps.
http://www.sciences.univ-nantes.fr/physique/perso/gtulloue/conics/drawing/para_string.html
Brian
Another problem with the glass mirrors is the weight: one square meter of 2 mm thickness (the thinnest I can obtain and cut) it weighs 6 Kg, which obliges me to put a counterweight to balance the parable, and that at the same time obliges me to reinforce all the structure.
There are also light plastic mirror, but is very expensive for me. And besides the salesperson told me that it does not resist the elements a lot of time, it goes losing the shine quickly.
We continue insisting, that some day our efforts will be valued by who do not share the generalized attitude of spending and to waste the fuels.
if you want, you can see two brief videos of my first successful test of my arrangement of mirrors, winter 2006, in http://es.youtube.com/user/rimar2000 or, if you can't enter there, in http://es.youtube.com/watch?v=NAg16m_O0os and http://es.youtube.com/watch?v=Z08OqEaXS_M
