Make a rain proof portable generator housing
 by kabira
Contest WinnerFeatured
I live in New Jersey and as I write this instructable on October 28, 2012, we are about to be pounded by hurricane Sandy,  To keep my sump pumps going, I decided to buy a portable generator in case the power goes out.  The only generator I could get my hands on is this behemoth 225 lbs Generac 5500 watts generator.  Keep in mind that I cannot run this generator in a covered open area.  First on all, other than my small covered porch I do not have any other covered open area, secondly with 100 miles an hour wind, there is no such thing as covered and open.  I had to make a cover which will protect the generator from rain and I will need to provide ample opening for it to breathe and dump its exhaust.
Step 1: The design
As I mentioned before, the generator needs to be protected from the rain.  It should be able to breathe.  The cover should be beefy enough to stay on the generator.  If I was a sheet metal guy like the Tuttles from The American Chopper, I would have done every thing in sheet metal with a cool paint job.  Unfortunately my skills are limited to some crude carpentry, so I decided to make a plywood housing with louvered vents for air circulation.  I did think of generator getting hot and found the hottest part to be the exhaust muffler.  I decide to put a aluminum sheet as a shield against the heat.
triumphman says: Nov 8, 2012. 2:24 PM
Are you Irish?
kabira (author) in reply to triumphmanNov 11, 2012. 2:40 PM
I could very well be! I like beer, I like whiskey, and I love (I mean love love) corned beef! I do attend St. Patrick's Day in New York off and on. I am sure there is more to being Irish, but I hope, what I mentioned above suffice. :)
coolbeansbaby68 says: Apr 18, 2013. 12:11 PM
nice
tbird481 says: Feb 16, 2013. 8:41 AM
Why not just get a GenTent? www.gentent.com a lot of people used them during Sandy and reviews are very positive.
Tom 7 says: Oct 31, 2012. 10:19 AM
it would be better to cut a larger top that covers and over hangs the side walls. that would help the structure last longer in the rain.
some padding inside to soften contact points with help sound vibration.
kabira (author) in reply to Tom 7Nov 28, 2012. 12:17 AM
I do have clearance of about 2 " on each side. However, it was my intent to keep it a tight fit because I did not want winds to turn the cover into a parachute. Sound insulation was not into consideration at all because the unit was outside, and I was constantly worried about the fire hazard due to excessive heat. However, I am sure there is soundproof insulation available which could be more temperature tolerant.
burntbob says: Nov 27, 2012. 5:49 PM
How did it work out? I know NJ really got hit bad and lots of damage near the water. Hope you got through OK!
kabira (author) in reply to burntbobNov 28, 2012. 12:14 AM
Considering that I live quite inland, there was no water damage. There was just damage to the roof due to winds. And, of course, we lost electricity, and that is where the generator came in handy.
poofrabbit says: Nov 23, 2012. 9:35 PM
Congratulations on being a finalist in the be prepare contest!
reddog92396 says: Nov 14, 2012. 4:50 PM
Step one should be "don't buy a generac". Just some advice for the future, they tend to crap out much more often than some other brands, although the other brands are more expensive. This is cool though! Thanks!
kabira (author) in reply to reddog92396Nov 15, 2012. 3:08 PM
Thanks Reddog! Beggars could not be choosers! There were only eight generators left in the entire New Jersey before the hurricane Sandy! If I had time, I would have purchased a generator which runs both on gas and propane.
swindmiller says: Oct 29, 2012. 7:23 PM
Hello from a fellow Sandy victim in Maryland...hope every one is ok and safe. I bought my first generator although I have been pondering the idea for months after our last 7 day outage.
This is exactly what I was looking for and was wondering how it was holding up. We are getting pounded as I type this so I know you are getting it worse :)
I have a gazebo that I had the generator under but as you said with the winds it got soaked anyway. I read mixed comments about people saying they leave their generator out in the rain and others saying to never use it in the rain. I had it out there for hours not running and just decided to bring it in the house (not running) until I need it, it was wet so I am drying it off now I will store it in the shed after the storm when not using it but think I need something like this for the rain and snow.
I was under the assumption that the whole thing got hot but you say just the exhaust gets hot? That's why you used the sheet metal, right?
Thanks,
Scott
kabira (author) in reply to swindmillerOct 30, 2012. 7:47 AM
Hello Scott,
I hope you are safe and dry now. As expected we lost power right when we needed it the most. The winds were very strong. I not only tied the housing to the generator and then tied the generator to my truck from flying away. Luckily nothing like that happened. The pumps worked constantly. We just got our electricity back. Damage wise, there nothing major except for a few missing roof shingles.
I hope we don't have to deal anything like that for a year or more.
Good Luck!
swindmiller in reply to kabiraOct 30, 2012. 6:37 PM
Great to hear!! How did the cover hold up? Did the generator get wet?
kabira (author) in reply to swindmillerOct 30, 2012. 7:00 PM
Thank God! It worked out very well. I tied the cover and tied the generator with my truck, just in case. However, I did not see any lift inside the cover because the louvered vents helped released all the air pressure.
How did you make out with the storm?
swindmiller in reply to kabiraOct 31, 2012. 5:30 AM
No issues, we got lucky.
Schmidty16 says: Oct 29, 2012. 6:02 PM
did u stain it
kabira (author) in reply to Schmidty16Oct 30, 2012. 7:42 AM
No, just sealed it using deck sealer.
Tupulov says: Oct 29, 2012. 8:36 AM
Quick and easy project. I was thinking about doing something like this for my generator and this was the idea I needed. I like the way it allows complete mobility of the generator. As for heavy winds, I'd sink a ground anchor on either side and use a tie-down strap to prevent the wind from causing problems. Well done.
pratchered says: Oct 28, 2012. 10:43 PM
Is there enough room for the power outlets? It looks like a tight fit. I might try to do something similar for mine. Nice job.
kabira (author) in reply to pratcheredOct 29, 2012. 6:08 AM
Hello and thanks for the comment. Actually my picture shows wrong measurement for the width. The genset is only 21 inches wide, which gives me almost 3" for the power chord plug and the bend of the chord.
MrOddjob says: Oct 28, 2012. 7:12 PM
Hi Kabira. A very nice neat job on the generator. I wouldn't worry too much about engine aspiration problems, with 100 mph winds blowing at it, it'll likely be turbocharged! However I do have concerns about it's ability to stay on the ground. I may be wrong but if winds of that speed get underneath that box, it's a good bet that it's going to turn into a flying machine.
I hope it doesn't happen and that you and your family come through unscathed.
Good instructibles though, I may use this in the near future. Stay safe.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
