Make a remote controlled camera from a cellphone!
Want to know what your cat is doing while at work? Send a text message to your newly made surveillance-cellphone and receive pictures and videos seconds later. Sounds like a dream? Not any more!
This video explains how it works:
Step 1Parts and tools you need
A brave camera-cellphone (including SIM-card). I'm currently using a Sony Ericsson T630.
A microcontroller (I use a Picaxe 18x)
Solenoid relays
Photoresistor (LDR)
LED
A few resistors might come in handy
Wires
Soldering iron
Solder, cutters, tape etc.
Oh, and another working cellphone.
134 comments
1-40 of 134next »
Nov 23, 2011. 1:31 AMlongjasp says:
nice prject!! can i have the full schematic diagram? pls send me it here princessmalou.longjas@bohol.asia..... thnx n advance
Mar 16, 2011. 9:56 AMilpug says:
looks like a bomb though, but nice build.
Jul 6, 2011. 3:33 AMpjain7 says:
yup... at first it does look like a remote controlled bomb..
haha
great one man.. keep this goin on and on and on...
Jun 8, 2011. 12:36 PMflame boyyyy says:
So you technically have to pay for 2 phone bills? Because im pretty sure texting has to have a service to like connect to and stuff...just curious ;D
Feb 1, 2011. 3:01 AMciochinda says:
Hy guys! I'm from Romania (Europe)
- i'm new here (in fact i just signed up, because i had an similar ideea and i just had to tell it to somebody)
- I have got no electronic knowlege, but I had another ideea for this rig (and I say it's much smaler and kuicker to build)
- but i got to say i never tried to build it (is just an ideea)
- its probably more expensive (the phones i mean) but they both are perfectly usable (you don't mess with them in almost any way)
what you need:
- 2 phones (both newer models with 3G network (with video call available) - one electric motor
- one light sensor (posible from a solar garden lamp)
- a carboard box (around the phone and everithing ealse - exept for a little hole for the camera, ofcorse)
->for the power to the motor - you can use any old phone charger (or other tipe of ellectric power transformer)
-how does it work :
-first everithing must be in a box to be totaly dark inside
- when the phone receives the video call, -> the screen lights up
-> the sensor sees the light and activates the motor
-> which tries to spin, but it only pushes a little bit the little solid metal bar -> which puches the answer button
-> and you stick the box where ever you want the phone insaid to see (and show you)
- OK - how you build it - that's for everyone imagination to change - you buy a solar garden lamp (probably 1-2 $ ) - they all have a light sensor - you soulder a little electric motor to the terminals that lights up the LED (in the night time) [the thing is (and i don't konw exacly how it works) you will have to solder contacts inversed - or inver the contacts to the light sensor] - i don't know for sure - but you need the sensor to start the engine when is light not when is dark (as it does normaly) - and then you soulder again some kind of little stick (bar) of metal - to the head of the motor and positioned straight to the ansering button of the phone (in order to push the button when the motor tries to spin) - and thats the more complicated part - - now you will have to place the hole phone in an perfectly light sealed carboard box (with the execpt of the little camera, which needs to see outside ofcorse -you make the configuration to 3G network for both phones - in order to have a video call betwen them -how does it work - when the phone receives the video call, -> the screen lights up -> the sensor sees the light and activates the motor -> whic tries to spin, but it only pushes a little bit the little solid metal bar -> which puches the answer button
Jan 2, 2011. 2:56 AMgary.kam says:
can u plz mail me its schematics on (kam_gary@yahoo.co.in)plz.....regards
Sep 18, 2010. 10:16 AMRal6639 says:
Has anyone had any luck using the usb port on the mobile phone to communicate serial codes from the microprocessor? just a thought to clean up the design....
Sep 7, 2010. 5:32 AMmonishgogri says:
hi dude, i think u'r a genius, cud u just help me out, i got a prob wid ma bb 8900, d speaker doesnt ring
Sep 8, 2010. 2:01 AMmonishgogri says:
thnxx dude,
u noe mobile repairing??
Sep 6, 2010. 2:32 AMagis68 says:
Where u got these relays????plz tell me
Sep 1, 2010. 6:12 AMbk-paradox says:
You can use a mosfet instead of the relays if you wanted to make it smaller. When the mosfet is on it is considered shorted with 1 ohm generally resistance. transistor wouldn't work due to current needing to flow. I like this concept alot.. taking existing hardware and modifying it for a new project. Lots of cheap cellphones around for projects like these. Thanks for the inspiration
Sep 3, 2010. 1:17 AMbk-paradox says:
The way the keypad matrix work is just shorting the 2 pads together using graphite which is in the key.. so by soldering a wire to each pad and then connecting one wire to drain the other to source.. applying voltage to the gate of an N channel enhanced mosfet will then connect the two pads ^_^ hope it works for you. Haven't done it for cellphones but have done similar for other projects
Sep 3, 2010. 9:43 PMbk-paradox says:
How do you think it detects the key press it connects 2 pads or columns and rows.
You are talking about DTMF keypad most likely Basically you have 4 rows and 4 columns (3 columns for a standard phone 4 for a test phone) and each one produces a frequency so when you press 1 you get a tone of 697 Hz mixed with 1209 Hz which tells the controller that you pressed that button.. So with 7 pins you can control the whole keypad or just send a tone using an ic which would be another viable option
a pic of a dtmf decoder
http://www.afiata.com/wp-content/uploads/2010/03/DTMF.gif
Hope this is the same as you are talking about?
Buy a keypad from an electronic store and see how it detects a press ^_^
Sep 4, 2010. 4:55 PMbk-paradox says:
an npn or pnp would fail because you need current flowing in order to use it as a switch which means the emiiter would have to be connected to ground so current can flow An enhanced mosfet on the other hand only requires a potential difference e.g. voltage potential to switch Have a look at the keypad matrix below it is from 3310. I think you got yourself confused.it's pretty standard Got to keep in mind all you do when you press any button is connect things together don't see how you can make it more complicated. but thats just my 2 cents.
Sep 4, 2010. 8:13 PMbk-paradox says:
Good to see you are a searcher ^_^
There are two ways to tackle this as I said before one is mosfet directly on the keys the other is an IC such as the picaxe feeding the key information to the phone.
here is the sample of the mosfet schematics.
Obviously not a full circuit.
When you set the pin high the button is pressed i.e the row and column are connected :)
If you put some logic probes on the rows and columns you can emulate the same on a picaxe or similar microcontroller.
Sep 5, 2010. 2:24 PMbk-paradox says:
Could I then suggest 1 alot more elegant approach just use 1 chip directly connected to the columns and row and using an oscilloscope which you can use your soundcard for (cheap but effective sometimes) and work out the signalling.
I would make a bold assumption and say it is dtmf because it's a phone. So then a picaxe to send that freq should work and would be very small indeed. Just got to make sure you have the right logic levels etc.
I think we both misunderstood each other lol ^_^
look forward to seeing what you come up with, as I'm overseas atm and can't do my own write up.
Sep 5, 2010. 6:46 PMbk-paradox says:
Can you upload your schematic please..
Sep 6, 2010. 4:33 PMbk-paradox says:
Already got the 3310 was talking about the instructable..
Was going to copy your schematic and port it to the mosfet so you can see
how a mosfet can replace a relay but meh..
Sep 7, 2010. 2:54 AMbk-paradox says:
Thats what I figured it would be...
Here is an image I found which shows what I was trying to say unsuccessfully
You can drive the mosfet with the logic level of a picaxe just got to read the
data sheet
Sep 7, 2010. 6:46 PMbk-paradox says:
they can share a common source that won't affect it at all.
Especially seeing as how you can only press one button at a time.
It acts exactly as a relay but instead of being open it just has a ridiculously high
impedance which for all intensive purposes is open.
Try it out with 1 button then chuck in the other should work fine.
I don't see trouble with it at all.
Really wish I was home at my workbench >_< lol
If you want I can find a suitable mosfet for this purpose
Would love to see this in smd form would be impresive could fit in the battery compartment and would be for all purposes just a phone to any1 seeing it
Sep 8, 2010. 4:54 AMbk-paradox says:
Ahhh I see I did say common source >_< my mistake your fault lol :)
Sep 8, 2010. 8:24 PMbk-paradox says:
You've confused your diagram..
if you look at the relay your coil has a common source..
A mosfet doesn't need that.. as it only had 3 inputs not 4
I guess you are a picture person so here you go
1-40 of 134next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
93
Author:tanntraad
