Introduction: Make a Shadow Box
You can use a shadow box to display your favourite decor accessories. To make a shadow box all you need are some pieces of pine or board and moulding for the front. My shadow box has a piece of glass to the front to make it more of a display box, rather than just a shelf.
If you prefer to have an arrangement of shadow boxes to serve as wall shelves, simply leave out cutting a rebate to add a piece of glass.
YOU WILL NEED:
2 pieces 80 x 300mm pine / MDF - sides
2 pieces 80 x 260mm pine / MDF - top and bottom
Length of pine moulding or extruded polystyrene
Wood glue
Picture hanger
Piece of glass, cut to fit
Masking tape, thin
TOOLS:
Drill / Driver plus assorted bits
Mitre box and backsaw or mitre saw
Optional: Router or router table
Step 1: Make the Box
1. Because I am fitting a piece of glass to the front on my shadow box, I used my router table to cut a 5mm rebate in the sides, top and bottom to support the glass.
2. The sections were glued and then clamped overnight.
3. The space was measured to have a piece of glass to fit the opening.
4. A thin strip of masking tape was placed around the edge of the glass. This will help when cutting the front frame to fit and allow the front frame to overhang on both the inside and outside of the box.
Step 2: Attach the Frame
5. Cut one end of the pine moulding or polystyrene cornice and place at the corner of the tape.
6. At the other end, mark where to cut. A little mark to indicate the cutting angles does away with any confusion.
7. Glue the front frame by applying a liberal bead of adhesive to the top edges of the box and also to the edges of the moulding. Press the frame or moulding firmly in place making sure the edges are nicely joined together.
8. Wipe away any adhesive that oozes out. You can also use the adhesive to fill any gaps at the corners.
GOOD TO KNOW:
Use a blunt knife to push back any masking tape that is visible on the front of the frame.
Step 3: Finishing
9. Use pieces of newspaper to cover the glass inside and on top to protect when painting with spray paint.
GOOD TO KNOW:
If you are using spray paint, apply a thin layer of wood glue to the cut edges to seal these.
Finishing
Spray inside and outside the shadow box with Rust-Oleum 2X Ultra Cover. I used satin Heritage White to spray the shadow box. You will find the full range of Rust-Oleum products at your local Builders store.
Attach a picture hanger at the back of the frame for hanging on a wall.
Visit me on www.Home-Dzine.co.za for more craft and DIY projects.
Shelving Contest
