note: silencers are most likely prohibited in your area without a special license. Check your local laws before attempting this. Also, this instructable is purely for informational purposes and could be dangerous and prohibited.
Remove these ads by
Signing UpStep 1Locate your Materials
In a post apocalyptic world, you are shopping in a supermarket with your high-powered sniper rifle slung across your shoulder. All of the sudden, alien invaders burst into the supermarket. You notice that the head honcho alien who's brain serves as a central brainwave server is among the intruders.
Seeing as how the aliens havn't seen you yet, you quickly devise a plan.
You grab the items from your cart and jump on top of the freezer isle behind the igloo coolers.
Your plan is to take out the honcho alien without revealing your position. Since your not super creative, you don't think of anything clever aside from shooting him. So! you need a silencer.
Among your grocery items you happen to have a newspaper, a 2 litre bottle of soda, and some electrical tape. Good! thats all you'll need... plus your trusty sniper rifle.
*Cut a hole in the base of the bottle abour 1/2 and inch bigger than the neck.
*Insert pvc pipe the size of the neck opening and the length of the bottle.
*In the space between the pipe and the edge of the hole (in the base) insert wire *wool.
*Pack it tight.
*Remove the PVC pipe.
*Attach to barrel.
I have made some suppressors, and suppressed pistols & rifles, .22 to 9mm.
The Tim Le France design of 3 1/2 spherical chambers is very efficient. If I did not have a "Ball end mill " of the appropriate size, I used a standard drill bit, with satisfactory results. Here in New Zealand, there are no leagal restrictions on suppressors, possession, or use. No longer shooting, previously had quite a few suppressed firearms. Cheers, diaden@ihug.co.nz
That's how effective this "silencer" design is. Dangerous and ineffective, but battling aliens usually is.
Here is a vid of a soda bottle suppressor that works.
http://www.youtube.com/watch?v=wAi9JFxLO3k
