Remove these ads by
Signing UpStep 1Stuff you need
Some wire
A male headphone jack
A breadboard or experimental circuit board (optional)
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
If you were to boost the power, you would then be subject to FCC rules.
Thanks!
thanks!
thanks!
thank you! :)
marC:)
Section 15.219 Operation in the band 510 - 1705 kHz.
(a) The total input power to the final radio frequency stage (exclusive of filament or heater
power) shall not exceed 100 milliwatts.
(b) The total length of the transmission line, antenna and ground lead (if used) shall not exceed 3
meters.
(c) All emissions below 510 kHz or above 1705 kHz shall be attenuated at least 20 dB below the
level of the unmodulated carrier. Determination of compliance with the 20 dB attenuation specification
may be based on measurements at the intentional radiator's antenna output terminal unless the intentional
radiator uses a permanently attached antenna, in which case compliance shall be demonstrated by
measuring the radiated emissions.
The above "jives" with what I have read on the topic since 1968. Fairly restrictive, doesn't allow for a very effective antenna in the AM broadcast band
