3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a simple USB light
I've recently acquired a "high end" soldering station so I find myself enjoying soldering lately. That being said, soldering always needs good lighting. I almost always have my computer next to me when I'm working on something so I decided to make a simple little USB light that was easy to manipulate and put where it needs to be.
Step 1Parts needed
Parts needed
The parts list is simple and I had the materials lying around. You can probably get this from a Radio Shack for a few dollars or scavenge something broken.
Parts
-62ish OHM resistor***
-LED of your choice
-Old USB plug
-Twisted wire or hookup cable
-Relatively stiff wire (doesn't have to conduct electricity)
-Sugru (optional)
-Some tape (electrical is probably the best)
***Resistor may vary depending on your LED needs. Source voltage is about 5 volts from USB. I suggest this website if you don't want to second guess yourself: http://led.linear1.org/1led.wiz. I use it all the time because I doubt my math abilities.
Tools
-Wire snips
-Soldering tools
-Scissors/hobby knife
13 comments
Dec 22, 2011. 11:22 PMsnotty says:
Nice project.
It's screaming to be done with shrinky tube instead of tape.
Dec 21, 2011. 7:14 AMFrostytheswimmer says:
So I saw the part where it said "make the LED swappable" and so I said, Challenge accepted. All you need is an old strand of lights! clip one socket off and then stick some led's in the bulb housings and voila! Interchangeable lights! Thanks for the instructable!
Dec 12, 2011. 3:09 PMNoahtoyou says:
do you need the resistor?
Dec 12, 2011. 12:33 PMsoshimo says:
Just use Ohms law to figure out the resistor value. Find the voltage drop of your LED (it's on the spec sheet), usually 1.7 - 2.4v. Ohms law says I = V/R. You want about 20ma of current through the LED (more and you will shorten the life - a lot more and you will shorten it considerably and let out the magic smoke). So, given that .02 = V / R and we know that V will be supply minus the voltage drop across the LED, or V = Vcc - Vled. Let's use 2.0v as an example, so 5.0v - 2.0v = 3.0v dropped across the resistor. So now we know V, let's solve for R. R = V / .02 or 3.0 / .02, or 150 ohms. The next highest value that is standard is probably 220 ohms so go with that. Anything less and your LED will not last as long and/or you could fry it.
Dec 12, 2011. 2:10 PMsoshimo says:
I personally don't like those calculators. They tend to abstract what calculation is going on. Ohms law, KCR and KVR are all derived from Maxwell's equations. There is a reason why they work and understanding those ratios, at least at a higher level than Maxwell's stuff, is important when building circuits. Just my two cents. When I teach BEE I always stress learning Ohms law over using some calculator app. Will that app tell you how to bias a transistor for class A operation? Of course not, but Ohms law will! :)
Dec 10, 2011. 2:47 PMLolbert says:
Here's an idea! How hard would it be to replace the earbuds on a pair of headphones with LEDs so that the electricity going through the audio jack would make them flash along with any music you're playing? Would the audio cable not supply enough power? Of course, you would have to have a headphone splitter if you actually wanted to listen to the music at the same time.... It's a highly impractical project, but it might be fun for experimentation.
Dec 12, 2011. 2:22 PMmarmand says:
Sharpshot, you could hook something like this up but in all likelihood it wouldn't be nearly that simple. To begin with, an analog audio signal like the kind coming out of an audio jack is AC, whereas an LED (by definition of being a diode) only allows current flow in one direction, and so would really only work (or would work most practically) with DC, so you'd need some rectification circuitry to accommodate that so it would accurately reproduce the sound as flickering light. Additionally, the voltage level of that signal is in all likelihood very small, in the millivolts (mV) range, whereas supply voltage and current for an LED would need to be much higher than the signal would provide, so you'd need some amplifier circuitry to step the signal up to the required level.
So yes, it would be possible, just not as simple as your initial thought. If you're interested in finding out more about it you can always play around with it yourself, or check out the link at the bottom, its a similar concept to what you're thinking.
http://www.radioshack.com/product/index.jsp?productId=11007963&CAWELAID=711102272
Dec 9, 2011. 12:55 PMLed Man says:
question. where do you buy Sugru at?
Dec 12, 2011. 1:12 PMbrianfss says:
you can also make your own. There are several Instructables that tell how to do it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:CaptPikel
