Remove these ads by
Signing UpStep 1: Parts needed
Parts
-62ish OHM resistor***
-LED of your choice
-Old USB plug
-Twisted wire or hookup cable
-Relatively stiff wire (doesn't have to conduct electricity)
-Sugru (optional)
-Some tape (electrical is probably the best)
***Resistor may vary depending on your LED needs. Source voltage is about 5 volts from USB. I suggest this website if you don't want to second guess yourself: http://led.linear1.org/1led.wiz. I use it all the time because I doubt my math abilities.
Tools
-Wire snips
-Soldering tools
-Scissors/hobby knife
Visit Our Store »
Go Pro Today »
It's screaming to be done with shrinky tube instead of tape.
I made sure to point out different diode ratings. I've blown a few in the past assuming they needed the same power.
So yes, it would be possible, just not as simple as your initial thought. If you're interested in finding out more about it you can always play around with it yourself, or check out the link at the bottom, its a similar concept to what you're thinking.
http://www.radioshack.com/product/index.jsp?productId=11007963&CAWELAID=711102272
https://sugru.com/us/buy
