Make a simple battery discharger for NiCad or NiMH battery packs.
 by S1L3N7 SWAT
This instructable will show you how to make a simple discharger for your NiCad or NiMH battery packs for Airsoft AEG's or RC cars, boats, planes, whatever. Draining your NiCad battery packs is an important step in preserving the life of the battery, since NiCad's suffer from whats known as the memory effect. The memory effect is when a NiCad isn't fully charged on its first cycle, then depleted, and recharged again. However, it will not achieve a full charge because it's cells have adjusted to half capacity, or memorized half capacity. NiMH pack do not suffer from the memory effect and do not require regular darining, but if you plan on storing one for an extended period of time, you may wish to do so.
The design is not mine though, it is borrowed from this one here and here. I didn't see the point in paying $5 plus the shipping for something I could easily make for less that amount.
I bought all the supplies(2 12v bulbs, heatshrink tubing and tape) at Wal-Mart for a total of $5.63.
Price list:
2 Pack 12v Bulbs - $2.78
Heat Shrink Tubing - $1.96
Tape(you probably have it, but I happened to have ran out)-$.47
You may be able get spend less at other stores or if you already have some or all of the materials.
Step 1: Materials and Tools.
You will need the following...
1. Soldering Iron, and of course solder.
2. Electrical Tape
3. Heat Shrink Tubing
4. 2 12v Light bulbs, used for car tail lights and backup signals.
5. 1 Tamiya connector. I used a smaller one from an old charger that fits my battery. Yours may depend on the connector size of your battery.
6. Some 16 gauge wire or similar.
NOTE: Coffee pot not required :).
hansonsux says: Mar 29, 2010. 8:30 PM
The NiCad "memory" is a myth.  repeadedly discharging any battery will only use up it's cycle life faster.  There are however times where you could occasionally deeply discharge a battery - buy for memory is not one of them.
shannonlove in reply to hansonsuxMar 3, 2013. 1:17 PM
It's a myth with the technology used in the last 10-15 years but in the early 90s when NiCads were very new, it was a real effect. However, it was eliminated fairly quickly by the manufactures but somehow the concept really "stuck" with people.
m1sterb0b in reply to hansonsuxJun 15, 2010. 10:13 AM
actually, "deep discharging" a NiCd battery is bad for it. Most cell phones or devices that use NiCd have a circuit designed to only discharge it to about 90% on PURPOSE. ---->http://www.wppltd.demon.co.uk/WPP/Batteries/Memory/memory.html explains it a bit better!
hansonsux in reply to m1sterb0bAug 26, 2012. 12:20 PM
I know, repeatedly deep discharging is to be avoided, but there are times when it can be done. Cells have a certain number of times they can be "repeated" chemically, which equates to their cycle life. If the cells are deeply discharged, then it takes away more cycle life, or wears them out faster. But, deeply discharging occasionally isn't much harm. Of course, better quality cells can survive this "damage" better then cheap ones.
* Why people still continue to perpetuate the "memory myth" is beyond astounding. In doing so, people will heavily deeply discharge their cells believing their actions will make their cells healthier, but in reality they are doing more harm than good in the process.
m1sterb0b in reply to hansonsuxOct 16, 2012. 4:53 AM
I know part of it is to be blamed on ignorant people who work at stores that sell devices that use these batteries. I don't know how many times I've been in an apple store (servicing an ipod or getting a new one or something) and I've heard the "genius(s)" behind the counter talking to those who just got a computer/ipod, or those complaining of poor battery life to "completely discharge it until the computer shuts off and then plug it in and charge it back up". I know people who, after hearing that, do that once a month, and then in 6 to 12 months complain that they can't keep their computer on battery for more than an hour when they COULD leave it on for about 4 hours when they first got it!
Amperis says: Mar 5, 2012. 10:00 AM
great instructable, I leave a link on the common factors of the discharge of the battery: Description and treatment Of sulphated batteries: http://www.amperis.com/en/products/misc/battery-dischargers/
de0509 says: Jan 14, 2012. 12:58 AM
why not get a flashlight that uses what size batteries you want to discharge, then you can play with the flashlight all night long. it would be more fun. but still, whats wrong in making a new toy right? congrats for the project
rcisneros says: Sep 24, 2010. 7:10 PM
Wow. There are so many wrong things said, it would take to much time to correct them all. Go to http://www.batteryuniversity.com/ to get the whole truth about deep discharge, memory, etc. They go through each of the facts about nicad, nimh and lithium.
Macworldwizardz says: Jun 25, 2010. 7:28 AM
Thats Good. I bet you'd make a fourtune selling this.. :)
shad0w88 says: Jan 10, 2010. 5:32 PM
i have the same bulb, so ur saying that one terminal is the two points on the bottom and the other terminal is the outer shell?..
i've done this is it right?..
i plugged this into 7.2v battery and it wouldn't light up??
S1L3N7 SWAT (author) in reply to shad0w88Jan 11, 2010. 1:32 PM
The bottom terminal should be the positive (+) end. The side should be the negative (-). Although, it really doesn't matter what the polarity is because it's an incandescent bulb. Maybe your battery is to weak to light the bulb. Also, check your solder connections. It's most likely a bad connection, those things are difficult to solder to. Or, your battery is too weak.
arvindhimalayan says: Aug 29, 2009. 7:11 AM
time pas
knight2067 says: Aug 19, 2008. 3:29 AM
Because incandescent bulbs use resistance to generate light, polarity doesn't matter. With an LED, it does.
Derin in reply to knight2067Jul 22, 2009. 2:40 AM
Press the reply button.
petederidder says: Dec 11, 2008. 2:21 PM
Pete says: I used one std. 12v auto bulb and discharged some 700mAh RC packs. It took about 30 minutes to discharge to 1.05v/cell with a peak temperature of ~91 degrees F. With two bulbs the dishcarge time was ~13 minutes and I got a peak temperature of over 120 degrees. Use one bulb and be kind to your batteries.
kanamin in reply to petederidderJun 26, 2009. 11:42 AM
I'm guessing the temperature is coming from the internal resistance of your cells dissipating heat. RC packs with larger cells typically have a lower internal resistance, and you can discharge at higher current. Most RC dischargers I've seen use 10 of these bulbs.
fwjs28 in reply to petederidderMar 5, 2009. 12:11 PM
tehehe...you said std...lol
Derin in reply to fwjs28Jul 22, 2009. 2:39 AM
HAWKOHAWKOHAWKOHAWKOHAWKO
S1L3N7 SWAT (author) in reply to DerinJul 22, 2009. 6:02 PM
What???
fwjs28 in reply to S1L3N7 SWATJul 22, 2009. 6:58 PM
lolwut?
fwjs28 in reply to DerinJul 22, 2009. 9:30 AM
S1L3N7 SWAT (author) in reply to fwjs28Mar 5, 2009. 1:50 PM
He meant "standard", but I guess you already know that.
fwjs28 in reply to S1L3N7 SWATJul 22, 2009. 9:30 AM
mhm
joinaqd says: Dec 29, 2008. 10:09 AM
why dont you use a JOULE THIEF instead?its better,plus you can get the light on for longer...
S1L3N7 SWAT (author) in reply to joinaqdDec 29, 2008. 2:40 PM
Because the the purpose of this is to drain the battery to ready it for a recharge, not to draw out all the remaining energy, like a joule thief. I suppose it would work, but would likely take longer and do damage to the battery, like reverse charge or something. Thanks for the suggestion though.
IX Smith XI says: Jul 21, 2008. 8:17 PM
how long do you have to wait to discharge
S1L3N7 SWAT (author) in reply to IX Smith XIJul 23, 2008. 4:21 PM
Not too long. You just have to watch it till the lights go dim, it shouldn't take long.
hp79 says: Jun 2, 2008. 6:28 PM
If you keep this on until light is completely dead, it'll cause a reverted voltage on some of the lower capacity cells in your strip of the battery pack. Then you have a bigger problem. It would be okay for a parallel hooked single cell though.
theRIAA says: Apr 25, 2008. 4:02 PM
nice! i've seen these online for like $20, way to stick it to the man. just be sure you know what they're for before making one.
S1L3N7 SWAT (author) in reply to theRIAAApr 25, 2008. 6:10 PM
WOW $20!! That must be for the ones with like 6 bulbs. But yeah, make these only if you intend to use them to drain battery packs, or if you want a crazy bright hand held flood light! I plugged in mine and was blinded for like 5 minutes lol.
richms says: Apr 24, 2008. 8:37 PM
Unless the pack is matched, this will allow the cells to be damaged thru reverse charging unless you are there to monitor it via a volt meter and disconnect it when the voltage drops below what indicates that at least one cell is down.
S1L3N7 SWAT (author) in reply to richmsApr 25, 2008. 12:47 PM
Yeah, its a matched 7 cell pack. This thing is supposed to leave less than 1v in each cell. You unplug it when the light gets really dim.
nf119 says: Apr 24, 2008. 7:16 PM
Isn't the memory effect only on the NiCd? I am not sure but I think it doesn't help to fully discharge NiMh, it may actually shorten their life by wasting charge-discharge cycles.
S1L3N7 SWAT (author) in reply to nf119Apr 24, 2008. 7:20 PM
Yeah, I think your right, but it may help if someone wanted to drain one for long term storage.
nedfunnell in reply to S1L3N7 SWATApr 24, 2008. 8:20 PM
It's best to store NiMH at around 80% charge.
S1L3N7 SWAT (author) says: Apr 24, 2008. 7:24 PM
Ah, what the heck. I submited it to the contest anyway.
joejoerowley says: Apr 24, 2008. 6:54 PM
Cool! Great Instructable! You might be able to enter it into the go green contest because allows batteries to last longer. Idk though. Thanks Joe
S1L3N7 SWAT (author) in reply to joejoerowleyApr 24, 2008. 7:05 PM
Yeah, I was thinking about that but since its not really my design it may be inappropriate.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
