Introduction: Make a Simple Crochet Bow
Picture of Make a Simple Crochet Bow
This is a really simple pattern that you don't even need a needle to finish.
Step 1: Materials and Glossary of Terms
Picture of Materials and Glossary of Terms
What you will need
Worsted weight yarn
A size H crochet hook
Scissors
Terms
SC: Single crochet
Ch: Chain
Step 2: Beginning Rectangle
Picture of Beginning Rectangle
Ch 10
*Sc across, ch 1 and turn*
Repeat above until it you have 4 rows and tie off
Step 3: Adding the Middle
Picture of Adding the Middle
Insert your hook in ch 5 on the bottom and stitch 5 on the top.
make a slip knot with your yarn and pull through the two stitches
ch 1 and cut the yarn with a 12 inch tail. (exact length doesn't matter)
Pull the yarn all the way through the slip knot, tying off the yarn.
Wrap the tail around the middle.
To tie off, using your crochet hook to pull through the bottom, wrap the tail through the bugle 2 times
Depending on if you want to sew the bow on something or glue it you can leave a short tail.
Weave in all ends.
craftclarity (author)2014-05-30
Sure looks cute!
About This Instructable
318views
5favorites
License:
More by kayalishous:Make a simple crochet bowCrochet Shamrock GarlandCrochet Roses
Add instructable to:
