Make a Small Vacuum Cleaner at Home
Published
Introduction: Make a Small Vacuum Cleaner at Home
You can make your own portable vacuum cleaner using the following steps. Its very easy to make using basic electronic components and mechanical items.
you need:
1> Electronics: one 3V dc motor, one switch , one AAA battery holder. and wires to connect them.
2> Mechanical, one small plastic container, plastic propeller, one small pipe (1cm dia, 1cm long), 6 pcs of small plastic spices ( 5mm x5mm), aluminum wire to make a clamp, and a long plastic or aluminum rod to make a handle.
Step 1: Spec by Step Video Insctruction
click here ( video )
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    11 Discussions
    Without the handle, this would be great for gathering crumbs from a kitchen work surface.
