To set tool height on your CNC router/mill, you can easily make a spring loaded touch plate based on a “mini” momentary switch mechanism which provides the spring action needed. Rather than using the standard 'gage block and paper' technique that involves repetitive trials, the touch block will let you quickly set a cutting tool to an accurate distance from the work table surface. A basic continuity tester made from a battery and a LED provides a visual indication when the tool contacts the block.
The main component of the touch block is a simple momentary 'mini switch' with a removable push button which provides the spring plunger that the touch plate is attached to. Using parts I had on hand I was able to quickly build my touch block system for much less than commercially available devices, which may run $85.00 or more.
Remove these ads by
Signing UpStep 1Parts List
The project is actually two easy projects in one: 1) the touch block, 2) the continuity tester which powers the touch block and provides a LED indicator to show when the tool makes contact with the plate.
a) Continuity Tester parts. Skip this if you already have a continuity tester that is suitable for use with the touch block. Estimated cost: $10.00 or less before tax and shipping, if any.
1-ea 2-AA Battery Holder (enclosed 3.1v) Radio Shack # 270-408
2-ea AA Batteries
1-ea 5mm Red LED {2.5v or less} Radio Shack #2760041 or equivalent
1-ea Current Limiting resistor to match your LED (24ma or less) typically 27 – 56 ohm.
1-set Alligator Clip adapters
Note: you can determine the value of the resistor needed by going to: led.linear1.com and
entering the supply voltage (3.1), forward voltage of the LED (2.5), and desired LED current
(20ma)
b) Touch Block parts Estimated cost: less than $10.00. If you have a 'junk box' cost may be zero.
1 piece of 1/16” aluminum C-Channel 3/4” x 1.5”. I used a scrap of a 96” piece sold at Home
Depot # 030699-568703 selling for under $11.00.
1-ea 2-AA Battery Holder (enclosed 3.1v) Radio Shack # 270-408. I had a contact plate and
spring removed from the holder (left over from a previous project) that I used. If you don't
have something suitable on hand, just buy an extra one of these to cannibalize.
1 small piece 1/16” thick conductive stock that you can solder a wire to, such as copper, brass, etc.
I used a scrap of brass shim stock that I had on hand.
1-ea Mini SPST momentary switch (N.O.) Radio Shack #275-1556. The switch is only used to
provide spring loaded plunger for the plate.
1-ea 2” length of stranded hook-up wire (14-18 ga. OK).
c) Tools needed
* Drill & drill bits
* Soldering iron
comments
Add Comment
Confounded Machine
says:
Add Comment
